Kimera Industries Project Nova: 17 liters of 5-slot mATX goodness
Status
Not open for further replies.
4,796
The slot pattern extends the whole length of the bracket in the production design. I had to leave room for the hinges and front lip though so it's only 245mm from from end of the slots to the other. Not quite enough for dual 140mm but you wouldn't be able to fit two 140mm fans with a PSU installed in either position anyway.
WiSK
Water Cooling Optimizer
May 10, 2015
51
The Netherlands
I see. Would that still leave space at the lower front for a 120 mm fan and would something thicker like the XT45 fit?
Thicker is not always better with radiators. At "quiet" fan speeds the ST30 performs better than the XT45. Only when you get up to 1200rpm does the XT45 even equal the cooling performance of the ST30.
Tygon E1000 is a good example. It was/is praised for being plasticizer free, but it's official operational range is -59C to 51C. Not something I'd personally be comfortable running at 70C for lengthy periods of time.
I've never seen the coolant in a watercooling loop reach 40C, let alone 51C. Even in my FT03-mini build with a single AX120 cooling both CPU and GPU.
E1000 is advertised as plasticizer free by Sidewinder and FrozenCPU. Clearly they misunderstood the datasheet. The carciogenic phthalates were removed from E1000 at the behest of the food industry, and replaced with ... a different type of plasticizer. St.Gobain do make plasticizer-free tubing, but it's not very aesthetically pleasing, cloudy looking. Use Acrylic of PETG if you want crystal clear tubing that doesn't leech.
veryrarium
144
44
Japan
Thanks Aiboh, that's good news for me that the slot pattern extends the whole length, even if it spans only 245mm. I assume this is not just for 140mm but also for 120mm fan mount slots, correct?
WiSK
May 10, 2015
51
The Netherlands
Do you happen to know anything about Mayhem's "Ultra Clear Tubing"?
No, sorry. I stopped buying any "clear" flexible tubing after seeing so many types dull, cloud, or yellow (within weeks usually). You always hope the next one you buy will be different :)
4,796
The handle itself looks fairly robust assuming it has a metal core to reinforce it.
6,123
5,031
Belgium
Yes, I'm hoping so too. I'm convinced Silverstone could do better with some competition.
4,796
skukza
38
I've gone with a itx GPU so what I'm really hoping I can squeeze a EK Predator upfront, if not im sure the termaltake should fit on either the bottom or front easily enough.
6,123
5,031
Belgium
But um, we haven't seen news in what seems like ages. Something must be delayed or proven to be difficult, but is there nothing that can be shared to quench our thirst ?
Status
