Winter One -- V11 (Kickstarter is HERE!!!)
Link To Kickstarter
Link to Website (For More Information!)
V11 Case Dimensions:
L 322mm
W 160mm
H 302mm
Volume: 15.6L
V11 Changelog:
1. Slight Volume Increase from 15.4L >> 15.6L
2. Added Dual 280mm Radiator Support (Up to HWL GTS280!)
3. Added 30mm Radiator + 25mm Fan Support! (56.5mm *total* fan+rad clearance!)
3. Increased GPU Length to 315mm (3090 FE is now Supported!)
4. Increased CPU Cooler Height to 70mm (Support for Noctua NH L12S)
5. Created a Pump Bracket for mounting liquid cooling pumps, supporting 9 different orientations, and a variety of pumps.
6. Switched Fully Machined Exterior (better tolerances & finish)
7. Tweaked Holes on Side Panels for another 4% cooling capacity
8. Added mounting support for AquaComputer Quadro (micro fan/pump controller)
9. All Beta Feedback Incorporated. QoL changes, major improvements, part redesigns (See Table Below).
Beta Testing Progress:
☑ Build Process Testing
☑ Part Compatibility Testing
☑ Airflow Testing
☑ Thermal Testing
☑ Acoustic Testing
☑ Dust Buildup Testing
☑ Rebuild / Disassembly Testing
☑ Thread Wear Testing
☑ Manufacturing Fit and Finish Testing
BETA Feedback Changes (Detailed Changelog for Item #9)
Thermal Testing
These are the direct readouts from a Liquid Cooled Winter One Beta Unit:
A Few Beauty Shots
360º Orbits of CFD
And of course, there's a lot more information on the Website.
Older posts hidden below. I'll try to stick to this format for updates!
Link To Kickstarter
L 322mm
W 160mm
H 302mm
Volume: 15.6L
V11 Changelog:
☑ Airflow Testing
☑ Thermal Testing
☑ Acoustic Testing
Issue Raised | Issue Fixed |
Side Panel Laser Cutting and Bending Tolerances remain difficult to control, causing issues when sliding them into case. | Switch to machined panels. Significantly increased quality of panel construction (to level of top / bottom panel), and employs far tighter tolerances. |
Front and Rear Panel do not always stay parallel, and the case arms will angle slightly downward (~5º degrees). This also makes sliding in panels much harder | Lower arm (that holds both Motherboard and GPU Riser) will be extended to attach to the front panel at 2 points, to better support front and rear panel, keeping them parallel. Should make building in the case far more pleasant. |
Color Mismatch on Side Panels and Front / Rear Panels | Due to trialing various suppliers for Beta Run, not expected in final production |
Finishing Flaws, Burrs, Slight Warping, and Out-Of-Tolerance Bends on Side Panels, may cause difficulty sliding them in | Supplier for these particular side panels failed their evaluation, and will not be used again. However, Panels need a rework, as even after evaluating other suppliers, this issue is not resolvable with the current design. |
Foot Washers are slightly loose | Off-Shelf washers will be replaced with custom-made washers |
Power Switch is spaced with 2 nuts, as appropriate spacers were not available on time. | Custom-made Spacers for power switch bracket. |
Sharp point on Fan / Radiator Plate | Remove Sharp Point. |
GPU holder has a gap on one side (clearance with arm). Needs to hold onto GPU far better. | Replace with a thumbscrew system |
Fan / Radiator Plate is slightly bending under heavy loads Large Copper Rads) | Use Tempered Aluminum for Fan / Radiator mounts. Add 33% more thickness. Confirm with FEA + RWT in final validation Prototype |
Motherboard Mounting Arm Standoffs are Too Short. Need to use 6.25mm or longer standoffs on the ARMs. Old ATX / ITX standard used, does not account for motherboards with thick backplates. | Will provide 7mm of standoff height in the final version, clearing the latest ATX and ITX specification of 6.25mm minimum standoff height. Issue was not caught due to outdated test parts from before when motherboards had backplates. |
RTX 3090 FE will not fit in Beta Unit (8mm too short) | Dimension adjustment by 6mm to accommodate RTX 3090 |
30mm radiators and 25mm fans will not fit in Winter One. Due to stock/ supply issues with <30mm radiators, this is being changed. | Expanding Case Height slightly to accommodate more slim radiators, as sub-30mm radiators are difficult to find. Support for 280mm radiators coming. |
Some Slightly Loose mounting on the power supply bracket | Increase threading depth and thicken PSU bracket to add more margin |
Front Panel Drive Cage Threads are slightly shallow | Extended the depth of the tapped threads |
Slightly shallow threading on Upper and lower ITX Arms | Increase thread depth by 1.4mm |
Fan / Radiator Plate needs channels for better positioning 140m fans and limited 280mm radiator support | Redesign Fan / Radiator Mounting with longer channels to accommodate the mounting of 280mm radiators. |
Power Cabling on rear panel is Occluding other Screw Holes | Shift rear panel power connector. |
Power Supply Bracket bending slightly with very heavy PSU. | Increase thickness of the PSU bracket by 33%. |
Some GPU Sag when using very heavy copper blocks. | GPU holder >> Thumbscrews. GPU Arm attaches to front and rear panels. Add Small Support Bracket for GPU. |
Power Supply makes Removing Motherboard Harder if needed to service the case. | Lengthen Case by >5mm (already being done for 3090 FE Support) |
Cable Routing can be difficult with some cables getting caught in fans during assembly. | Lower Beam that connects front / rear panel will have slots that allow for zip tie or velcro strip cable management, to control the nest of wires. |
PCIE Riser Cable sometimes touches a fan mounted near the Upper Arm | Shorten Riser Cable Length by 1cm. |
Thermal Testing
A Few Beauty Shots
360º Orbits of CFD
WINTER ONE - V1.0 UPDATE
Big Updates:
WINTER ONE IS DESIGN COMPLETE!!!
1. The version number indicates the 10 iterations... almost 1 year of design work. About 46GB of simulation data on airflow...
It was an absolute herculean effort to do so while *improving* airflow performance in the case... I think in the last 4 weeks, alone I've dedicated nearly 250 hours to the project ?
2. A huge part of the focus from v0.8 --> v0.9 --> v1.0 was tolerances, airflow tweaks, and cost savings without affecting quality. I'm happy to report that we somehow got (TENTATIVE-- ALL PRICES SUBJECT TO MINOR CHANGES) our target price from the 400+ range at the beginning of the project, into the lower 300's and might even be able to offer a $315 early bird special on the Kickstarter
3. At just 1000 rpm with 2x intakes / 2x exhaust NF A12x25 fans in the vertical config with "solid" side panels, airflow in the case is up from 60cm/s to about 90cm/s. Nearly a 1.5x airflow improvement over 2 iterations.
This means the case is cycling through all the air contained within, about 5x per second.
This is significantly better than many other cases on the market and I'm confident this thing is going to cool whatever parts you put in here *very* well.
4. PRODUCTION PROTOTYPES ARE ON THE WAY!!!
(they've already shipped... There's going to be a Beta Program, where I will be selecting 3 people to do some test builds!!!) -- applications will open **later this week!!** so keep an eye on the subreddit.
5. The Semi-Passive Heat Sink Kit (SPK) is very expensive to develop. It will cost about $30,000 in terms of further R&D and tooling to set up for manufacturing. However, the company I'm working with to make the SPK make some particularly well-regarded Fans and Heatsinks (in fact, I've been modeling airflow in the case with their fans, hint hint).... **The SPK is slated to come out late next year (tentative!!!), but I promise you, it will be worth the wait. Despite it being expensive, it is a thing I want to do, as it will set this case apart from a lot of others in the market. **The SPK will be compatible with v1.0** and is being developed around this design.
6. Following the Beta Program, **the Kickstarter will open before the end of August!!!**, unless there are some unforeseen issues with the production prototypes, in terms of QC or tolerances, or some other error / concern / issue discovered by the Beta Testing team.
7. Of the 5 prototypes being made, 3 will be sent to a few users who apply to the Beta Program. The other two units are going to be reserved for reviews and personal testing on my end. (More details will be posted soon).
Design Goals
The case was designed to hit a balance between 4 main goals:
What niche does this case sit in?
Winter One sits on the opposite side of the cooling vs compactness tradeoffs we usually see in the SFF market (cases typically forego fan mounts, radiator space, and good airflow in order to shave down to sub-10L). Silent Winter is a CFD-Driven, airflow optimized take on the premium SFF case, with maximum compatibility in mind. Even if it makes the case slightly bigger (14L vs sub-10L), the benefits of better airflow are hard to argue with: More air lets you handle hotter components, gives you more OC headroom, or allows for lower fan RPMs, and therefore a quieter system.
The linear airflow path (bottom >> top), and a design that emphasizes low air resistance in this case allows for natural convection, as well as maximizing airflow at lower fan RPMs in semipassive or active cooling setups. This design enables an *entirely silent* passively cooled mid-range system (3700X + 2060 Super) or a whisper quiet high end system (3950X + 2080Ti) using 4 case fans and huge heat sinks. In Active Air-cooled mode, you can maximize part compatibility (Something like a 3800X + 2070 Super) for a reasonably quiet and very flexible system.
In Active Liquid Cooled mode, dual 240mm slim (30mm or thinner) radiators ensure gobs of overclocking headroom even on high end components (9900k OC + 2080Ti OC) for the hardcore enthusiast. If you don't want to go semi passive, or liquid cool, Winter One also supports a 67mm CPU cooler heights, and triple slot GPUs -- at the same time!!! Toss in some 140mm fans (maybe the NFA14x25's when they come out!) and you'll be well on your way to an impressive stock air-cooled build.
Physical Dimensions
Length: 31.5 cm
Height: 31.5 cm
Width: 15.5 cm
Volume: 15.38 L or 15,380 cm^3
Part Compatibility
Motherboard:
Mini ITX with dual rad & quad fan
{!}(Air Cooling Requires 3 fan headers on Motherboard)
{!}(Liquid cooling Requires 2 fan headers + 1 pump header on Motherboard)
{!}(Semi-passive Mode Requires 2 fan headers on Motherboard)
{!}(Fan headers on your motherboard should support 2A in order to use a splitter)
CPU Heat Sink:
67 mm max height.
GPU:
300 mm x 54mm x 150 mm max (3 slot thick extra-tall)
170 mm x 54mm x 150 mm max {!}(Short GPU REQUIRED with pump/res)
{!}(Perforated Side Panel Option is Recommended, if you are using a 3-slot card)
Radiators:
Dual 240mm (300mm x 140mm x 30mm) dimensions, paired with 15mm slim fans. (NF A12x15 recommended)
Dual *slim* 240mm (300mm x 140mm x 20-25mm), paired with 25mm fans. (NF A12x25 recommended)
Fans:
Quad 140mm x 25mm fans (In anticipation of NFA14x25)
Quad 120mm x 25mm fans (NF A12x25)
Quad 120mm x 15mm slim fans (NF A12x15) {!}(needed with "standard height" 30mm radiators)
Pump/Res:
Recommended Pump/Res Dimensions: (113mm x 100mm x 48mm)
{!}(with Full Length GPU)
Maximum Pump / Res Dimensions: (209mm x 76.5mm x [300mm-GPU L]mm
{!}(with shorter GPU)
Alpahcool Ice Station DC-LT Solo Top (50.62 x 50.62 x 37.2 mm)
Alpahcool Ice Station DC-LT40 (60 x 40 x 40.48 mm)
Alpahcool Ice Station DC-LT 80 (50.62 x 50.62 x 77 mm)
EK-Quantum Kinetic FLT 120 DDC (120mm x 105mm x 51.2mm)
EK-XTOP SPC-60 PWM (62mm x 62mm x 51mm)
Swiftech MCRES MICRO REV2 RESERVOIR (101mm x 103mm x 38mm)
Swiftech MCP35X Micropump (59mm x 92mm x 62mm)
Swiftech MCP35B Micropump (59mm x 92mm x 62mm)
Swiftech MCP355 Micropump (44mm x 87mm x 61mm)
Alphacool DC-LT Pump w/ FrozenCPU Res (49mm x 49mm x 65mm)
Lightobject DC24 Straight-through brushless pump (116mm X 50mm X 50mm)
{!}(Pumps Typically mount under the GPU, to the front panel)
{!}(Check GPU & Pump/Res dimensions carefully!)
Power Supply:
SFX (100 x 125 x 63.5 mm) or SFX-L (125 x 125 x 63.5 - not recommended, but okay)
Power Button:
Kailh Box LtBlue with custom round aluminum keycap (changeable for modding).
{!}(Changeable by the user. Keycap Modding will also be possible)
SATA SSDs:
Room for 4 x 2.5" SSDs or HDD's. (100mm x 70mm x 6.8mm)
{!}(Mounting Extra Drives will Require the Drive Cage add-on
{!}(Drive Cage changes Bottom 240mm radiator compatibility --> 120mm)
Renders
FAQ's
Why Slim or only 30mm radiators?
Thicker radiators are less volume efficient, in terms of cooling performance. If you take a single 30mm radiator in push configuration, and compare it to a 60mm radiator, the 60mm radiator in push/pull, is only about 30-40% better. However, Two 30mm Radiators (not double stacked) in push configuration, will be 2x better than a single 30mm radiator, despite taking up the same space as the 60mm radiator + push/pull.
Will the SPK be available for other cases?
It's very large. It's a 210mm tall heatsink... stretching into the radiator area of this case, above and below the motherboard / GPU. This is necessary because semi-passive and passive heat sinks have widely spaced fins to better facilitate natural convection.
Will you be making the CFD data available?
CFD informed cooling configurations will be recommended in the manual, so that first time builders, experienced builders new to SFFPCs, and even experienced SFFPC enthusiasts, can be confident that they have the best layout (fan orientation, and panel choice) for their chosen cooling setup.
There may be some edge cases where a particular combination of parts might out-do a suggested setup, but for the most part, these recommended configurations will give you the best possible CPU / GPU thermals in Winter One
However, we will not be directly making CFD data available to the public.
Is there a way to get notified?
Yes!
You can Sign Up Here to receive update emails for when the website goes up, the Beta Program goes live, and the Kickstarter is launched
Big Updates:
Design Goals
- Premium build quality, look, and feel with a machined, Anodized, bead blasted Aluminum enclosure, and a power button that *actually* feels great to press.
- Focus on proper cooling capability, with **Viable** options for liquid and air cooling, as well as semi-passive (case fans + heat sinks), and passive (heat sinks ONLY) cooling.
- Compatibility with widely available parts (ITX motherboards, low profile CPU coolers, full length 2.n slot GPUs, off the shelf SFX power supplies, 240mm radiators)
- Around 15L so it’s squarely an SFF case. (not toeing the 20L line).
Physical Dimensions
Length: 31.5 cm
Height: 31.5 cm
Width: 15.5 cm
Part Compatibility
Motherboard:
CPU Heat Sink:
67 mm max height.
GPU:
Radiators:
Fans:
Pump/Res:
Power Supply:
Power Button:
SATA SSDs:
Renders
FAQ's
Yes!
Winter One -- v08 Update
Last Changed: 25 May 2020, 12:30 am
So it’s been 4 months since I showed off the v05 design. Since then, there have been 3 iterations on the case, each one with a different focus:
* v06 — Cost Savings & Manufacturability, Exterior Redesign, Exterior Airflow Studies (outer panels)
* v07 — Final Dimensions, Interior Layout, Design Unification, Interior Airflow Studies
* v08 — Accessories, Detailed Tolerances & Dimensioning, 3rd Pass of Airflow Studies
There’s also a survey later in the post because I want to gauge the community’s opinion on a few things before I finalize for production
A. Concept & Goals
Winter One was designed to hit a balance between 4 main goals:
1. Premium build quality, look, and feel with a machined, Anodized, bead blasted Aluminum enclosure.
2. Proper cooling capability, with *viable* options for liquid and air cooling, as well as semi-passive (case fans + heat sinks), and passive (heat sinks ONLY) cooling.
3. Compatibility with widely available parts (ITX motherboards, low-mid profile CPU coolers, full length 2.n slot GPUs, SFX/SFX-L power supplies, 240mm radiators)
4. 15L so it’s squarely an SFF case.
B. Case Specifications:
Case w/ Feet in Vertical Position:
* Length: 31.5 cm
* Width: 15.5 cm
* Height: 31.5 cm (+2cm from feet)
* Volume: 15.38 L
Case w/ Feet in Horizontal Position:
* Length: 31.5 cm
* Width: 17.5 cm (+2cm from feet)
* Height: 29.5 cm
* Volume: 16.26 L
C. Part Compatibility
Motherboard:
Mini DTX with Single rad & quad fan
CPU Cooler
67 mm max height
GPU
300 mm x 54mm x 136 mm max (2.7 slot thick, power connecters on "top")
300 mm x 54mm x 157 mm max (2.7 slot thick, extra tall) {!}(Power connecter on back - ie, Kingpin 2080Ti)
170 mm x 54mm x 136 mm max (2.7 slot thick) {!}(Short GPU REQUIRED with external pump/res)
Radiators
Dual 240's: (310mm x 144mm x 30mm) {!}(with 15mm Slim Fans)
Slim Dual 240's (310mm x 144mm x 20mm) {!}(with 25mm Fans)
Fans
Quad 120mm x 25mm fans {!}(with 20mm radiators)
Quad 120mm x 15mm slim fans {!}(with 30mm radiators)
Pump/Res
130mm x 130mm x 55mm (NEED Short GPU) {!}(Check GPU & Pump/Res dimensions carefully!)
Suggested Pump / Res {!}(NOT CONFIRMED)
Power Supply
Power Button & Switch
Custom round aluminum keycap (Switch is changeable for modding)
Kailh Box Navy Switch (3.6mm Travel | 60g Actuation | 90g Bottom Out)
Keycap design CAD files will be available for modding <3
Additional Storage
Room for 4 x 2.5" SSDs or HDD's (100mm x 70mm x 15mm)
{!}(Requires use of a 120mm Rad on the bottom, and a drive cage)
D. Design:
Exterior
Interior
E. CFD and Airflow
For Winter One, CFD was focused on:
1. Airflow through the top/bottom plates and side panels
2. Airflow inside the case, (maximizing flow, and eliminating dead zones)
3. Airflow related to the semi-passive and passive cooling modes of the heat sink. (Can't show these yet, sorry. They're being designed in conjunction with a company, and there's some NDA’s in place about not showing pre-production stuff)
CFD Images
Results and Improvements due to CFD:
* Increased hole size to make A/P > 0.3
* Panel Thickness tuned to D/L of 5
* Feet Height set at 2cm for adequate flow
* End Plate redesigned to improve outflow, reduce rebound flow.
* Drive Cage Optimized to Not Hinder Airflow Into Case
* Dead Spot of Air b/w GPU and Central Spine and PSU eliminated.
* Airflow Velocity within case above 30 cm/s at all times (typically b/w 50-90 cm/s)
* For Water cooling, operate fans / radiators in 4-exhaust mode, or 2-push/2-pull with lower temp loop at the Inlet.
* For Air Cooling, operate the case in 2-push/2-pull to ensure best airflow over heat sinks.
F. User Survey
This survey has some questions about pricing and options you’d like to see in the case. It should only take 2 minutes to complete.
LINK TO SURVEY
G. Future Timeline
(End of May) full scale 3D printed model
(Early June) Beta Program - testing the case, and checking hardware compatibility and doing some real life temperature / airflow testing (Let me know in the survey if you're interested)
(Late June) Kickstarter will go live & Beta *reviews* will drop.
(July) If the Kickstarter is successful, I’ll submit the orders for the production run!
(August-September) Deliveries!
H. Live Stream + Q&A
If you want to ask questions, or check out some of the CFD, come hang out in the Live Stream!
Live Stream Link
Date: Monday, 25 May 2020
Time: 3pm PDT / 6 pm EDT / 10pm GMT
Come hang out, ask questions, and more. If you can’t make it, don’t worry, the livestream VOD will be uploaded to This Channel on YouTube. Head over there to see it later this week
View this post on [H]ardforum
Check out this post on Reddit!
A. Concept & Goals
* Length: 31.5 cm
* Width: 15.5 cm
* Volume: 15.38 L
* Length: 31.5 cm
* Height: 29.5 cm
* Volume: 16.26 L
Motherboard:
CPU Cooler
67 mm max height
GPU
Radiators
Fans
Pump/Res
Power Supply
Additional Storage
D. Design:
Exterior
Interior
E. CFD and Airflow
CFD Images
F. User Survey
LINK TO SURVEY
G. Future Timeline
Live Stream Link
Hello friends!
Happy New Year! Since this past October, I’ve been hard at work on my CFD-driven airflow focused SFFPC case. The first shots I showed you back then were simple concepts exploring the inner layout, and possible construction methods. The design has since evolved and matured. **I’m now ready to share a little bit about v0.5**, which is the latest iteration.
Let's get into the main design!
Renders
Case Concept
The case was designed to hit a balance between 5 main goals:
1. Design driven by functionality and an Understanding of Fluid Dynamics.
2. *Viable* variety of options for cooling high end components. (Liquid *and* Air cooling, including semi-passive, and passive configurations)
3. Compatibility with off-the-shelf parts (ITX motherboards, low profile CPU coolers, full length 2.n slot GPUs, SFX power supplies, 240mm radiators, AIOs, etc.)
4. Premium Look and Feel (Design driven by functionality does not *have* to be ugly)
5. Sub 15L so it’s squarely an SFF case.
Silent Winter sits on the *opposite* side of the cooling vs compactness tradeoffs we usually see in the SFF market (cases typically forego fan mounts and venting to shave down to sub-10L). Silent Winter is a **CFD-Driven, airflow optimized** take on the premium SFF case, with **maximum compatibility** in mind. Even if it makes the case slightly bigger (14L vs sub-10L), the benefits of better airflow are hard to argue with: More air lets you handle hotter components, gives you more OC headroom, or allows for lower fan RPMs, and therefore a quieter system.
More details about the Semi-Passive Kit will be coming soon, but they’re currently pending another round of CFD studies.
Silent Winter v0.5 Case Specifications: (subject to change)
Physical Dimensions:
Parts Compatibility:
Semi-Passive Kit (SUBJECT TO CHANGE)
Passive Cooling Projection: (Assuming 5CFM natural convection) [2] [3]
* CPU: up to 100W (~85ºC max)
* GPU: up to 150W (~85ºC max)
Semi-passive Cooling Projection: (Assuming 30 CFM fan airflow) [2] [3]
* CPU: up to 170W (~85ºC max)
* GPU: up to 335W (~85ºC max)
[2] TDP's here are rough preliminary calculations based on expected heatsink volume and area, and 23ºC / 73ºF ambient air. These are obviously subject to change, as the designs are not final. I cannot stress this enough.
[3] Numbers are based of REAL power consumption, NOT TDP. TDP is largely a marketing term, and it's highly advisable to base cooling off Package Power Consumption (Courtesy of Anandtech) as almost all power consumed by a chip (aside from rounding errors) is dissipated as heat. Neither Intel nor AMD provide accurate TDPs for their chips... (See chart for listed TDP vs Real power consumption). Keep this in mind when considering hardware to use in this build.
Layout, and Structure
With v05, WinterCase had fundamental changes to the structure. In previous designs (v03 and before) the top and side panels attached to an internal frame. In v04 and v05 this internal frame was removed, and now the *panels* themselves are the main structural component. This was done to maximize *internal* volume.
The inner layout is a sandwich layout (popularized by the Dan A4) with the PCIE riser bridging the GPU / Motherboard. While this is typical of a Sub10L case, Traditionally, cases above 10L have a “standard” PC layout (such as the NCase M1). However, there are problems with this design in maintaining a *linear airflow path* (which is crucial for passive cooling). The “traditional” PC layout creates dead zones in airflow when passively cooling a case.
The linear airflow path and unique vent pattern emphasizes low air resistance in this case, allowing for natural convection, and maximizing airflow at *low* fan RPMs in semipassive or active cooling setups. This design enables an *entirely silent* passively cooled mid-range system (3700X + 2060 Super) or a *whisper quiet* high end system (3950X + 2080Ti) using 4 case fans and huge heat sinks, giving you the reliability of air cooling with the performance of water cooling. In Active Air-cooled mode, you can maximize part compatibility for a reasonably quiet and very flexible system. In Active Liquid Cooled mode, **dual 240mm slim (30mm or thinner) radiators** ensure gobs of overclocking headroom even on high end components (9900k OC + 2080Ti OC) for the hardcore enthusiast.
Closing Comments
This is a late design prototype. It’s about 80% complete. Most of the slots / cutouts / standoffs / dimensions are finalized. Some things remaining include:
* Baseplate - will attach to the rectangular section on the bottom (so the case doesn't topple)
* Carrying Handle - (raised rectangular section up top will house this, should sit flush)
* Tempered Glass Side Panels (optional, but widely requested)
* Final Screw Placements / Assembly
* Airflow related tweaks (currently running CFD on this)
* Heat Sink Design tweaks (pending more CFD)
Once I finish the detailed design, I plan to make a physical prototype and validate my numbers, make some revisions, and lining up production. Then, comes crowdfunding and actually starting production. I *hope* to get these in people’s hands by August 2020.
Thank you for taking the time to read over this and check out my design. Feel free to ask me questions in the comments here. **I want to know your thoughts about this design, and where you think I could improve things.** <3
Timeline
1. Finish Semi-Passive Kit (SPK) CPU and GPU heat sink design + CFD (by end of Jan 2020)
2. Update and finalize first CAD for first physical prototype (v06)
3. Create First Physical Prototype (via local machine shop) by (Early Feb 2020)
4. Do physical testing in normal, semi-passive, and passive modes, with real hardware and analyze data, update CFD models. (Feb 2020)
5. (As necessary) modify designs and repeat steps 3-6. (Feb 2020)
6. Update for manufacturability (v07)
8. Finalize Designs and prepare for crowdfunding. (hopefully by March 2020)
9. Crowdfunding + Manufacturing (March-April of 2020)
10. Delivery of case (hopefully by August 2020)
Renders
Case Concept
- Length: 30.5 cm
- Height: 30.5 cm
- Width: 15.4 cm
- Volume: 14.33 L or 14,325 cm^3
Code:
Motherboard:
CPU Sink: 60 mm max height
GPU: 295 mm x 48mm x 150 mm max (~2.5 slot)
200 mm x 54mm x 150 mm max {!}(Short GPU REQUIRED with pump/res)
(Note: 1S = 18mm, 2S = 36mm, 3S = 54mm)
Radiators: Dual 240mm Radiators: (290mm x 140mm x 30mm) dimensions
Fans: Quad 140mm x 25mm fans (In anticipation of NFA14x25)
Quad 120mm x 15mm slim fans {!}(with radiators)
Pump/Res: 130mm x 130mm x 55mm (NEED Short GPU) {!}(Check GPU & Pump/Res dimensions carefully!)
(If you decide to not use a pump-block combo on the CPU/GPU)
Power Supply: SFX (100 x 125 x 63.5 mm) or SFX-L (125 x 125 x 63.5 - not recommended, but okay)
Power Button: Kailh Box Navy with custom round aluminum keycap (changeable for modding)
SATA SSDs: Room for 3 x 2.5" SSDs (100mm x 70mm x 6.8mm) {!}(SHORT GPU required)
Closing Comments
Timeline
Hello friends!
While I'm relatively new to this forum, I've been part of the SFF reddit community for a long time. I've hinted here and there that I've been working on a case design & prototype for the last few months. I'm finally at the point where I'm happy with the v0.3 concept (0.1 and 0.2 were different designs that I ended up tossing out) and would like to share it with you!
Without further ado, let's get into it!
Case Concept
Silent Winter sits on the opposite side of the cooling vs size tradeoffs we usually see in the SFF market (where cases typically forego fan mounts, filters, or venting to shave down to sub-10L). Silent Winter is an airflow optimized take on the premium SFF case, with maximum compatibility in mind. The benefits of great airflow are hard to argue with, even if it makes the case *slightly* bigger. More air through the radiators lets you handle hotter components, gives you more OC headroom, and allows for lower fan RPMs, and therefore a quieter system. By having large vents and support for quad 25mm x 120mm fans, along with a linear airflow path will give you serious air push/pulled through this case. With Dual 240mm slim rads, the case is more than capable of cooling a 2080Ti + 9900k overclocked build. (A CPU Pump Block will likely be needed, though you may be able to cram a pump/res below some GPUs). The case has support for liquid *and* air cooling.
Semi-Passive Kit?
While the case supports dual 240mm radiators, I realize that not everyone has the desire to water-cool their system. For those who like the simplicity and extreme reliability of air cooling, I'm designing a Semi-Passive Kit that will come along with this case. The goal is to perform on-par with liquid-cooling in this case. I have a feeling that some people will happily forego the hassle of liquid cooling if they had a thermally comparable option. Currently, these heat sinks extend all the way from top to bottom, nearly touching the fans on both sides to maximize heat transfer area. (I'm still working on the design, currently doing some CFD runs on a few concepts, which is why a design hasn't been shown yet). When using the SPK, the "dead space" left by foregoing radiators won't be wasted. The SPK can be used in Passive *or* Semi-Passive mode.
In passive mode (NO FANS), according to rough calculations (subject to change) it should easily cool a 65W CPU and 155W GPU. In Semi-passive mode, where the only fans in the case are four 25 x 120mm fans on the end pieces, rough calculations show the capability to semi-passively cool 200W for the CPU and near 400W for the GPU. This opens the door to totally silent mid-tier (Ryzen 3700X + 2060Super) builds, or near-silent high tier builds (9700k + 2080 Super), if you keep fans at ~ 1000 RPM. Should be fine as long as you can provide around 30CFM of airflow. The machined end-pieces on this case create a large ventilation area in the highest flow region (outside 1/3 of the fan), and there is about a 25mm gap between the fans inside the case and the end plate, making it easy to move air through the case, whether naturally via convection, or using case fans.
Silent Winter v.03 Case Specifications: (subject to change)
Passive Cooling: **/***
Semipassive Cooling: **/***
** TDP's here are rough preliminary calculations based on expected heatsink volume and area. These are obviously subject to change, as the designs are not final. I cannot stress this enough.
***It should also be noted that these are TDP's at boost clocks. Keep in mind Intel calculates their CPU's TDPs at base clocks (a 9700k will exceed the 95W it says on the boxunder boost) while AMD calculates TDP at boost clocks (Ryzen 3700X will output 65W at boost, like it says on the box).
Visual Design and features
The case is built around a "double halo" mainframe -- two rounded rectangles connected to each other with 2 vertical beams. The casing is a rounded rectangular aluminum tube, which slides off to provide 360º access to the internals. This means there are no exposed screws on the exterior.
Here's the Imgur Album, including a video orbiting the case, so you can see all around
Now let's get into some details!
A backlit Kailh WhiteCherry MX Blue Switch with white LED is used as the power button, due to the construction of the case. You must depress it before sliding the outer shell off the mainframe, and a keyswitch had the travel necessary for this application. It also has the nice touch of having incredibly long service life and is easily replaceable. There is an extra benefit of allowing people to make custom keycaps for tastefully modding the power button.
The panel cover being wider than the case may feel like a waste of space, but it's functional - it allows for larger components in *every* case, as it relaxes fitment issues around things like square edges radiators, and doesn't force people to use low profile fittings for water-cooling. For those of you who air cool, the relaxed dimensions eliminate turbulence from any heat sink fans being too close to the wall, so your components get proper downdraft while hot air is quickly evacuated from the case. Parts compatibility listed above is purposely underestimated by about 5mm on all sides. Building in this case should be a pleasure.
There are two somewhat heavily machined pieces that fit into the halo (which I call end-plates), holding the air filters and fan/radiator mounting. You can see them more clearly in the image below. They are designed to hold the weight of the entire system, and will be secured as such (expect 12 screws here). This allows for the mainframe to be simpler and less expensive to make. The inside mounting plate for the CPU/GPU/PCIE riser/PSU is likely be folded powder coated steel (trying to keep costs reasonable here), bolted onto the mainframe. Reaching inside the tube will allow people to lift the case easily, as *everything* is connected to the double halo frame.
Development Timeline
1. Finish V0.4 and V0.5 CAD drawings by end of October 2019 (lots of finishing stuff like exact sizes of slots and screw holes and so on), CFD for airflow + liquid cooling configurations, exploring side panel perforation)
2. Finish Semi-Passive Kit (SPK) CPU and GPU heat sink design + CFD by end of November.
3. Consult with local machine shop and modify particular parts for manufacturability, build CNC files. (V0.7)
4. First Physical Prototype (via local machine shop) by Jan 2020
5. Get SPK prototype made by Jan 2020.
6. Do physical testing in normal, semi-passive, and passive modes, with real hardware and analyze data, update CFD models.
7. (As necessary) modify designs and repeat steps 3-6.
10. Delivery of case (May 2020)
Once design are finalized, I'm hoping to send out some prototypes to maybe Optimum Tech, LTT, BitWit, Jayz, and Science Studio, so people can see what builds in this thing will look like, and I'll post a build guide / video of my own.
Crowdfunding will open around the same time. Once crowdfunding is started, My *only* goal will be to ensure that cases are made correctly, packed, and shipped out to everyone, until all orders are fulfilled.
After all crowdfunding orders are fulfilled, It'll be waiting to hear feedback from users, and look at doing more batches of low volume production, assuming demand is there, so we'll have cases on hand for those who want to order.
Closing Comments
This is still an early design prototype. There is a lot of very specific work left to do, as I work on the details of the design. Things like screws, mounting holes, brackets, and making various things to "industry standard" dimensions. That's why this is v0.3 is still lots of "volume" placeholders that are exactly to dimension, but very low detail. The careful and detailed CAD work with some actual specs and parts will happen in the coming weeks. I wanted to make sure that the overall design and layout were good first. Once I finish the detailed design, I plan to take these files to a local machine shop and see if we can make a physical prototype, or I might just generate a .STL and get the rough prototype 3D printed... then take the iteration of that design to a machine shop.
Thank you all for taking the time to read over this and check out my design. Please feel free to ask me questions in the comments here. I want to know your thoughts about this design, and where you think I could improve some things.
I want to know a bit more about custom heatsink manufacturing, and custom case manufacturing, so if you have experience with either of those, please reach out to me. I fully intend to take this case to production, and give back to this wonderful community.
<3
Edits:
Case Concept
- Premium build quality, look, and feel - Anodized, bead blasted Aluminum enclosure, and "double halo" frame.
- Focus on proper cooling capability & airflow (plus filtration)
- Compatibility with widely available parts (ITX motherboards, low profile CPU coolers, full length 2.n slot GPUs, off the shelf SFX power supplies)
- Sub 15L (fell slightly short of this goal during compatibility efforts, but the tradeoffs are *well* worth the extra 0.3L!)
Semi-Passive Kit?
- Depth: 33.16 cm
- Height: 33.18 cm
- Width: 13.94 cm
- Total volume: 15.3 L or 15337 cm^3
- Motherboard: mini ITX with dual rads, mini DTX with 1 rad
- CPU Block : 67 mm max height
- GPU: 300 mm x 60mm x 130mm max
- Radiators: Dual 290 x 130 x 30 mm (including 'boxy' rads with square corners)
- Fans: Quad 120mm x 25mm fans (including air filter)
- Power Supply: Standard SFX (100 x 125 x 63.5 mm) or SFX-L (125 x 125 x 63.5 - not really recommended, but not impossible)
- Power Button: mechanical keyswitch (Kailh box white) with backlight + aluminum keycap (Keycap design will be open sourced for modding)
- Hard Drives: None currently (I am exploring options!) Use M.2 for now.
- CPU: up to 65W TDP
- GPU: up to 155W TDP
- CPU: up to 175W TDP
- GPU: up to 420W TDP
Closing Comments
<3
Edits:
- fixed media links.
- Changed Cherry MX Blue to Kailh Box White
- Added a Timeline for Case Development
