News Gigabyte RTX 4060 Low Profile
GucksTV
217
436
www.youtube.com
Funfact, I've ordered the GPU first on Amazon US for ~390€ with shipping to Germany and shortly after that the card was listed on Amazon DE for 367€ with shipping through Amazon US...so I've canceled my first order and got the one directly from Germany. (still the delivery is set to be between 04-13.10.2023) But the MSRP seems to be 329$ which is great! 🥳
Stifle
39
62
Stifle
39
62
Got my card yesterday, playing around with my current build before I went to work today. A few items to note, along with a few bad pictures (sorry).
The card is longer than 182mm stock, maybe just a hair over 182 'without' the bracket attached, 183+ with the IO bracket attached
The end of the card is very busy, less room for a power connector than I thought, but it does step in from the end to allow some extra room.
Only 4 screws hold on the fans/shroud. One screw is a bit of a pain to reach, flat screwdriver to loosen then Philips to finish
Fan header looks to be a CRJ Micro PH 4-Pin PWM style, one connector for 3 fans.
The top of the heatsink is flush from end to end
The card is silly small,
Ask me anything you would like to know, I can likely get more pictures after work today.
robbee
n3rdware
809
1,188
This is how length of GPU's is measured, starting from the inside of the PCIe bracket, not the outside.
344
Wow that is TOIGHT - doesn't fit with the shroud or was this the plan?
Stifle
39
62
I thought it would just fit but I'm going to need to do something to modify the shroud mounting or shorten it by 1mm or so
Since there is a little play in the shroud to the heatsink, I decided to open up the screw holes on the heatsink frame a little and remove a little material from the inside of the shroud for the heatsink tabs and the heatpipe. This should be just about enough to fit the shroud inside my 182mm ID case without any visible modification.
Snerual
120
132
Found a first "review" on YouTube
He manages to undervolt it so it only draws 100W with practically no performance loss! With that undervolt the GPU sits at 67C with fans spinning at 70% speed on an open bench. This looks very promising.
Now I am really considering ordering it from Amazon US (at a 70EUR premium over a "normal" 4060) because it's still nowhere in sight at European retailers 🥲
robbee
n3rdware
809
1,188
I'd hold off a little while longer. Looks like Amazon US still doesn't have any stock either so the delivery date is an estimate. Their global shipping is super fast, so you won't loose a lot of time if you wait for stock before ordering.
I'm seeing the card pop up in stores in the Baltic so it should arrive in western Europe soon I hope.
