Production Gemcase C9 4.4L - density and сoolness - 4060 LP and HDPLEX
What's stopping you more from preordering?
  • Production time
    Votes: 4 12.5%
  • Advance payment
    Votes: 6 18.8%
  • Price
    Votes: 6 18.8%
  • Design
    Votes: 6 18.8%
  • Shipping from Ukraine
    Votes: 9 28.1%
  • Ready to preorder!!!
    Votes: 10 31.3%
  • Total voters
    32
hamed
Gemcase C9
We are happy to announce our case Gemcase C9 this is a mini ITX PC case with external volume ~4.4L. The case is designed for a full-fledged computer(internal PSU and GPU) as of workstations or gaming it features space for two full sized 92mm case fans helping to draw cold air into the case not only for CPU but also for DDR, SSD(nvme) and all in case components to maintain a more stable temperature while creating minimal noise. Also our case features the ability to be installed horizontally(HTPC like) and vertically(PC like usual).
Technical characteristics:
Size(Height x Depth x Width): 210mm(8,27") x 208mm(8,2") x 101mm(4")
Weight: 0,8kg
Motherboard: mini ITX (incompatible ASUS ROG STRIX B660, B760)
CPU cooler clearance: 37mm (with 4mm clearance to grille)
DDR clearance: 46mm
Graphic card: low profile(Width 70mm), two slot(Height 40mm), Length 182mm(Gigabyte GeForce RTX4060 Low Profile, RTX A4000 SFF, RTX A2000, GTX1650, GTX1050ti, RX6400)
Storage: only NVME SSD
Power supply: Flex ATX, HDPLEX 250W
Case fans: 2x 92x25mm(top placement - exhaust)
Materials: stainless steel and steel powder coated; front panel - oak(maple) wood with oil coating
Package content: Case, power button, front USB 3.2 Gen2 Type C, screws(including screws for HDPLEX and FLEXatx fixing), rubber feet both for HTPC and PC orientation.
Riser requirements: 180 degrees double reverse riser with riser cable length 18,5cm or full riser length 20cm
Case price - 140€(150$)
If you want to purchase a PC case, you can contact us by email venturedecades@gmail.com, private conversation on the SFF forum or Discord.
Noise reduction
During the development of the case, we also measured the noise generated by the fans, because we wanted to be sure that case doesn't significantly increases noise.
The graph shows measurements of our first prototype and second prototype after the changes were made.
During measurements, the microphone was in close proximity to the fan, so the noise level values can only be taken into account relatively, which means that the difference in level can be taken into account and the order of noise reduction can be accurately determined from this curves.
Also graphs allows us to visually assess and calculate the difference in level and, based on this, accurately determine the order of noise reduction. On average we get 4 dB reduction in noise level, which is significantly noticeable by ear, In numerical value 4dB is equal to 1.58 times which can be expressed as 63%.
Quietness and coolness
First screen - case fans off 10min cpu burn, cpu fan 40% constantly
Second screen - case fans on(curve regulated) 10min cpu burn, cpu fan 40% constantly
We have -9 degrees Celsius difference in CPU temperature, that's impressive! Also what graphs don't show how slowly CPU gets hotter with time(when case fans- on) it is twice as slower comparing to turned off case fans.
Using GPU with open radiator(like RTX 4060 LP) or fan modded RTX A2000(4000) will improve GPU cooling too.
Shipping details
We publish information about our delivery partners around the world, where you can also calculate the cost of delivery.
We are located in Ukraine, but by following our partner links you will understand that at the moment there are no borders for delivery :)
Novaposhta
Ukrposhta
If site is on Ukrainian, please use a translator.
Just to be sure u have all tools that u need currency converter.
For example shipping from Ukraine to Germany by Novaposhta will cost ~14€
P.S.: also we can use any of this delivery services Meest Globalpost
Feel free to ask a questions we want community to take part in:)
Update 30.07.2023
Hello world:)
In an upcoming announce of our new Case and while preparing drawings for production, we have approached the issue that we would like to solve together with the SFF community, through voting.
As I mentioned earlier we working on 4L PC case with PSU, GPU, 2xCaseFans and want to ask community for help.
Thank you all in advance.
Update 08.09.2023
Update 12.09.2023
First prototype already assembled and released, acting according to plan, heading towards final release. Share your opinion.
Front panel exclusive - two color walnut.
Update 18.09.2023
Preorder STARTED!
Preorder ends 30.10.2023.
Pre-order is organized in the set of 10 orders(funding), after which production will begin.
If you want to purchase a PC case, you can contact us by email venturedecades@gmail.com or private conversation on the SFF forum.
In a separate post we will keep track of the number of applicants and the number of remaining order till production start.
Let me explain:
1. First, you contact us to clarify the details of the order and take one case for yourself and at this stage you do not pay anything.
2. After receiving 10 orders for a case, we re-contact everyone to confirm the order and pay for it. Payments will be made via PayPal.
3. Launching production - the cases will be ready till 24.11.2023.
4.Delivery will be carried out worldwide, using delivery services, the cost of delivery will be agreed at the stage of accepting orders.
Update 30.09.23
It’s always a big question not just to buy a cool PC case but also to deliver it.
For this reason, we publish information about our delivery partners around the world, where you can also calculate the cost of delivery.
Novaposhta
Ukrposhta
Update 11.11.2023
Production will fully start 17.11.2023 after two weeks there will be 4-5 cases available for shipping without preorder.
Hi, Can we still buy the case?? if yes without a gpu can I use a 7950x cpu in this?!
Animag771
30
34
I don't think I'd run a 7950X on a 37mm CPU cooler. Coolers of that size are typically installed on 65W TDP (88W actual) processors; the 7950X is 170W TDP (230W actual). You'd have to heavily undervolt and power limit the CPU in order to keep the temps down, which will come at the cost of multi-core performance. It can be done but compromises will have to be made.
I have an L9a (37mm) on my 5700X and it struggles to keep up at 90W. I'd highly recommend getting a case that can support at least 70mm if you want to get the most out of a 7950X.
Reactions: hamed and GEMCASES
Victordruiz12345
I would like to order case I have the velkase case I don’t like it because it scuffs my computer desk it doesn’t have the rubber feet and wood panels which would match my computer desk
GEMCASES
GEMCASES
Jul 23, 2023
73
81
Hello, you can place preorder at our discord channel, we would love to make one case for you:)
Invitation link:
Order link:
https://discord.com/channels/1161172626115407923/1207340855023632505
GEMCASES
GEMCASES
Jul 23, 2023
73
81
Hello, we now have cases in stock. If u interested please follow to our Discord or PM me.
