GPU Review: Low Profile & Single Slot RTX 4060 (Frankenstein) from Taobao
Gingerbeer
142
128
While it isn't a perfect example, I had this discussion a while back about the 3060's 12GB being a gimmick, but now it looks like it was a decent investment. Take a look at HUB's STALKER 2 GPU benchmarks the 12GB 3060 regularly outstrips newer/faster GPUS with 8GB VRAM.
I get the argument that, at the likely performance level of the A2000, you'll hit the sheer GPU grunt limit long before you fill the frame buffer (although I did make that very same argument about the 3060). However, if I was in the market for a used A2000, I'd definitely be looking for a good deal on the 12GB model.
Reactions: Arboreal
1,254
My understanding was for the A2000 specifically- the 6GB version typically performed marginally better in gaming scenarios. I wonder if maybe the larger chips used a fraction more power which left a tiny bit less for the GPU chip??
That may change with some of the newer games but you’ll likely hit the limits of the chipset’s performance before the 6GB becomes the main concern.
For CAD obviously more VRAM the more betterer.
::EDIT:: hadn’t seen Arboreal or Revo’s posts oops- interesting if the 12G 3060 is better than “faster” 8GB cards! Will have to check that out
b_force
78
31
for Gaming, 6GB is enough IMHO for a 1080p GPU
for other workloads it might be another story (I got the 12G for CAD)
I got and use yours 6GB A2000 also mostly for CAD, and seems to be fine for majority of workloads I am doing :)
Mostly working with PTC Creo here, almost daily at this point.
The VRAM question is more focused on the trend that seems to be happening in recent games, like ;
Although this example is pretty extreme (read: terrible), I have seen other games that just don't flow all that well with less than 8GB anymore.
At the same time I have a feeling that some cards seem to be crippled this way.
Reactions: SFFMunkee
b_force
78
31
For example it also reminds me how much worse the 6GB RTX3050 performs compared to the 8GB.
In this case the 8GB uses quite a bit more power.
But just from a price perspective they costs basically the same.
ayuready
OK, I checked with Huitong... the 4060m sold by them has another VBIOS and is locked at 70W TDP so that it does not need the additional power connector - but it also only scores around 7500 Timespy GPU points, which is 2000 points lower than the prototype I tested with 90W TDP
I assume they will select GPUs based on silicon lottery and use the "better" chips for the 70W TDP version, so people can put the card in the Minisforum MS-01 and Thinkstation.
will you know for such power limit card, can the usual undervoltage and OC via MSI Afterburner still work?
will such tinkering cause the 70w limit to be removed accidentally and render the card useless as PCIE can't support the original watts and there not power 6/8pins connector to add in additional power.
be cool if we can squeeze out further performance by OC/UV the 70watt card further.
REVOCCASES
REVOCCASES
2,237
3,651
www.revoccases.com
you can set a custom V/F curve in afterburner but not change the voltages
in other words: within the power limits (e.g. 70W) you can play around with higher / lower frequencies but don't expect too much from overclocking
Reactions: ayuready
custom90gt
I appreciate the OP for the review.
I just purchased one of these used from taobao (used because I couldn't figure out how to purchase from the company directly with superbuy). I really needed a single slot solution, SFF is a potential benefit in the future. Having said that, does anyone know if there are any full length brackets that would work with this?
Lucius2612
I have one from a Chinese friend but I have no working driver could you supply me a link? also I had some full height brackets supplied with my gpu
custom90gt
I still haven't received the card. Once I do, I can try to make some modded drivers if it doesn't come with one. I was hoping someone here could chime in with their experience.
LukeD
Case Designer
Jun 29, 2016
525
1,337
Interestingly, my A2K 6G performed better in games compared to my 12G ... Not sure why... Silicone lottery or the VRAM eats up more power XD
Could be harder to cool more memory modules and keep clocks high if you have limited cooling surface and possibility.
LukeD
Case Designer
Jun 29, 2016
525
1,337
@REVOCCASES curious how you went with the card ?
I just purchased the 4070 variant via SuperBuy so it will be here in a few days.
A part from having to use custom drivers, were there any other challenges you ran into ?
REVOCCASES
REVOCCASES
2,237
3,651
www.revoccases.com
No issues - I still use the card in my HTPC - it's really a fine card if you can live with the modded drivers
Reactions: LukeD
LukeD
Case Designer
Jun 29, 2016
525
1,337
@REVOCCASES Have you, or has anyone else tried modding the bios and reflashing it with a difference device id thats currently supported by Nvidia drivers ?
