Cool. thanks. Can the wideo card go in like any other sandwich case (the back of the card facing the back of the case)?On the bottom on the motherboard side.
page 14.
page 14.
Thanks! I contacted Michael and he's already helped me out.Something like this:
Or ask @VELKASE Michael for help![]()
Sliger Cases/Lazer3D LZ7 and LZ7 XTD/NFC Skyreach 4 Mini 16mm Anti-Vandal Switch Power Button
16mm Anti-Vandal switch power button replacement for Sliger SM Series & SV590/Lazer3D LZ7 and LZ7 XTD/NFC Skyreach 4 Mini. Button is illuminated with your choice of a white, blue, or red LED. Switches are made 380mm in length. Installation is a quick process for all cases, simply unscrew and...www.pslatecustoms.com
How are you dealing with GPU backplate and the riser cable in velka 7 (2.0)?
I got a Gigabyte 3060ti and the card fits snugly length-wise, but with the backplate and the fold of the pci extension, it seems that there's not enough room and the bottom of the card tries to stick out. I had to unattach the riser socket from the motherboard structure because its pcb was bending.
Should I just remove the card's backplate or it should be enough by trying to flatten the fold? (I'm hesitant about removing the backplate because it's attached to the heatsink)
Is it actually physically broken or does it just not work? If it's the seconds, make sure they cales didnt slip out.Does anyone know where I can find a replacement power switch? I broke mine![]()
I have a quick question about the enhance flex psu. I was looking at using the 600W Enhance PSU, but it only has one PCI-E 8 pin that splits into 2 8 pins. Am I right in thinking that this would be dangerous for powering the 2 8 pins of a 3080? Appreciate the help.
They should be in stock and available for order later this month. There will be more information as it gets closer to becoming available and there will also be a notice a few days in advance.Another question, I am interested in still buying a 7660b PSU in black. Will these be available for pre-order separately or will they just show up once in stock on your website?
This is probably a silly question, but would any of the current lineup work with pci-e bifurcation or are they just too small for that?
I don't think this layout and structure would make any sense at that size. This would add 84 mm to the width, increasing volume to 10 L but likely more to make space for tubing. It would also be prohibitively expensive to make if using the same materials and keeping the expensive riser and display extensions.Velka 7 would be a perfect competitor with the Corsair One if was a bit wider to accommodate 240 radiators & slim fans on both sides. Velka 9?
Velka 5 V2 was specifically created to address the ITX length graphics card availability issue so it's important for it to stay
- Velka 5 V2 gets ditched (full-length-2-slot GPU + Flex ATX PSU is pretty unpopular). The successor of the Velka 7 will become the Velka 5 V3 (SFX PSU, 2-slot GPU).
Larger cases are in the works but with no ETADo you have any plans for Velka 9?
