The purpose of this design is to be a console-style case that can accommodate high-end hardware more quietly than other cases in its size category, and support vertical and horizontal orientations so that it can be used anywhere: in a TV cabinet in the living room, on a desk, etc. At the same time, it is to have a transportable size of around 7-8 liters to further set itself apart from cases made by larger companies.
The current model simply takes the structure and appearance of the Velka 3, 5, 7, and applies it to a different layout. It is not representative of the final product which will not be part of the Velka series and will instead have a different name, appearance, structure, size, and so on. I am looking for feedback to help make some design decisions as this product moves along the development.
How to get an early version of the case:
Feedback needed:
Features of the current design:
Both the feet and stand mount to moveable stainless steel inner plates which can be attached anywhere on the vents, offering some flexibility in their positioning
Multi-orientation feet
Vertical round stand
Fully concealable USB 3.0 ports using swappable top and bottom panels
Variable graphics card clearances with two different power socket mounting locations
Extra card width: 300 x 127 (+19 for cables) x 63 mm
Extra card height: 297 x 146 x 43 mm OR 300 x 127 (19 for cables) x 43 mm
2.5" drive mount in front of graphics card
- 25 units from a test batch are available for purchase here for those who like the design in the current state and would like to provide feedback
- Enter password test22 to view the page and check all info carefully
- Please note that the official release will have a different appearance, structure, size, etc. to set itself apart from the Velka series. If you want something in the same visual style as the Velka 7 but in the slim console layout, then this will be as close as it gets
Feedback needed:
- Is there anything you want this case to do better than the Velka series and other console-style cases?
- Preference for the bar feet or round stand. Which would you use?
- Front I/O and what you would use it for (ex: wireless adapters, charging, etc.)
- Should case length be increased to fit graphics cards longer than 300 mm?
- Anything else that you want to mention?
- 1.0-1.2 mm steel and 5 mm aluminum construction, thicker than what is used in other cases in its class
- Transport friendly volume of 7.2 liters
- CPU cooler clearance of 50 mm for slightly reduced operating noise with 47 mm tall coolers
- Variable clearance for graphics cards with plenty of space in front of fans for lower operating noise. Mount the power socket in front of the graphics card for extra card height or below the graphics card for extra card thickness up to 3 expansion slots.
- Compact round vertical stand for vertical orientation and multi-orientation CNC aluminum feet which can be swapped between vertical and horizontal orientations
- Perforation on 5 sides, including both sides of the graphics card area for pass-through airflow.
Dimensions: 309 x 70 x 332 mm
Weight: 2.1 kg
Volume: 7.2 L external, 6.8 L internal
Materials and finish: 5 mm anodized aluminum front panel, 1.2 mm powdercoated galvanized and stainless steel body and interior, 1.0 mm powdercoated galvanized steel side panels
I/O: 2x USB 3.0 optional if not using SFX-L PSU
PCIe riser: guaranteed compatibility with PCIe gen 3.0 x16. May support PCIe gen 4 based on internal testing, but without guarantees.
Weight: 2.1 kg
Motherboard: Mini ITX
PSU: SFX, SFX-L (without front USB 3.0 ports installed)
CPU cooler: 50 mm. Alpenfohn Black Ridge and other coolers with an overhang over the motherboard PCIe slot are not compatible
Graphics card clearance not including cables. Cables require 16 mm minimum:
dual slot 297 x 146 x 43 mm OR dual slot 300 x 127 (+19 for cables) x 43 mm OR triple slot 300 x 127 (+19 for cables) x 63 mm.
Memory:
55 mm
Storage:
2x 2.5” HDD or SSD
Sum of graphics card thickness and 2.5” drive thickness must not exceed 62 mm
Drive mounts are in front of graphics card fans, therefore it is recommended to use M.2 drives, especially with graphics cards wider than 43 mm
Memory:
55 mm
Storage:
2x 2.5” HDD or SSD
