Velka series cases are focused on delivering class-leading space efficiency for portability and reduced desk clutter. Available at velkase.com
VK-3-RL: An APU case with support for stock AMD coolers
Price: 79.99 USD
VK-3: Supports discrete graphics and internal power supply under 4 liters in volume. Uses a half-sandwich layout with a ~17 cm graphics card chamber and Flex ATX power supply for maximal size reduction.
Price: 159.99 USD or 279.99 USD with 600W PSU
VK-5: Supports full-length graphics cards and internal power supply under 5 liters in volume. This case uses a vertical sandwich layout with video output extensions to keep IO at the rear and reduce the desk footprint. The result is a case that still feels compact like the Velka 3, but supports much larger 27 cm long reference graphics cards.
Price: 179.99 USD or 299.99 USD with 600W PSU
VK-7: Supports full-length graphics cards and SFX power supply under 6 liters in volume. This case uses a vertical sandwich layout with video output extensions to keep IO at the rear and reduce the desk footprint.
Price: 199.99 USD
Graphics card compatibility list
Price: 79.99 USD
A split from the original 2-in-1 design Velka 3 design, with a focus on configurations without discrete graphics, stronger aluminum construction, and improved CPU cooler compatibility.
- 4.4 L volume (4.1 L internal), 20 x 24 cm (7.8 x 9.5 in) footprint
- 70 mm CPU cooler
- Mini ITX motherboard
- Flex ATX (150 mm)
- 1x 2.5” drive mount
The latest revision 2.0 is a split from the original 2-in-1 design, with a focus on configurations involving discrete graphics. Now featuring an easier assembly process, fewer visible screws, a stronger steel frame, a 5 mm aluminum front panel, and an illuminated power button.
- 3.9L volume (3.7 L internal), 19 x 10 cm (7.4 x 3.8 in) footprint
- 600W power supply (optional, replaceable with Flex ATX)
- 37 mm CPU cooler
- 175 mm GPU graphics card
- 42 mm memory clearance
The latest revision 2.0 is a complete overhaul of the original Velka 5 design, with a smaller overall size, repositioned I/O, fewer visible screws, a stronger steel frame, a 5 mm aluminum front panel, and an illuminated power button.
- 4.9L volume (4.6 L internal), 18 x 10 cm (7.0 x 3.8 in) footprint
- 37 mm CPU cooler
- 270 mm graphics card
Price: 199.99 USD
The latest revision 2.0 is a complete overhaul of the original Velka 5 design, with fewer visible screws, repositioned I/O, a stronger steel frame, a 5 mm aluminum front panel, and an illuminated power button.
- 5.9L volume (5.6 L internal), 18 x 10 cm (7.0 x 4.4 in) footprint
- SFX power supply
- 47 mm CPU cooler
- 289 mm graphics card
- 52 mm memory clearance
