The new optimum tech video looks at a new case that is basically a Velka 9, quite interesting
OT seems amazed at the 45-degree riser folding action that allows MB IO at the back. Clearly he hasn't keep up with v2.0 Velkas at allThe new optimum tech video looks at a new case that is basically a Velka 9, quite interesting
I'm sure he's aware of that type of riser bend as he has reviewed the Corsair One prebuilt. I haven't been able to send review samples yet.OT seems amazed at the 45-degree riser folding action that allows MB IO at the back. Clearly he hasn't keep up with v2.0 Velkas at all
Highly unlikely as top IO was the most common complaintWill the Velka 5 V3 have a GPU face the same way as the MB? I so would have thought about getting the 7 if the GPU was not positioned that way.
What, no, I mean, will the IO on the GPU face the baclk like the MB IO?Highly unlikely as top IO was the most common complaint
If you mean making the case horizontal with the typical sandwich layout, I don't foresee that happening because it would require a complete redesign.What, no, I mean, will the IO on the GPU face the baclk like the MB IO?
Happy New Year, everyone. We're getting closer to the re-stock; power supplies are here and will become available in these next few days. Cases are still expected sometime in January. Thanks to all those who have been waiting patiently.
The extra riser bends just make it possible to put the motherboard IO at the rear while keeping the graphics card and case in the vertical orientation. The graphics card could have been offset to make space for display cables even without the double riser bend, it just wouldn't make sense to do that because then you would have motherboard and graphics card IO on the same side and no need for extensions.I was wondering... For the Velka 7 you choose to have a double bend to make space to route display output in the back. This is because you won't have space if you rotate the GPU by 180° (one single bend of the riser cable, this way), right?
What if, instead of internal extensions, you provide cables which connects directly to monitor(s) and you have just a single bend for the riser? Doing like this would mean cables coming out from a hole of the case and probably would mean a (partial) disassembly of the bottom case if someone would want to add/remove video cables... What are the drawbacks that made you choose to have two bends instead? Higher prices of cables compared to internal extensions?
The prob. with that is?then you would have motherboard and graphics card IO on the same side and no need for extensions.
Having the motherboard and GPU I/O facing the same way compromises the case in one of a few ways. It either changes the layout of the case entirely (makes the graphics card horizontal, more like a Dancase or Ghost S1), undoes one of the main changes from Rev.1 to Rev.2 (moving the top IO to the back like a more traditional case), or wastes the vertical space and severely restricting the kinds of GPU that can be used in the case.The prob. with that is?
Just have the GPU go from front to back like the MB.Having the motherboard and GPU I/O facing the same way compromises the case in one of a few ways. It either changes the layout of the case entirely (makes the graphics card horizontal, more like a Dancase or Ghost S1), undoes one of the main changes from Rev.1 to Rev.2 (moving the top IO to the back like a more traditional case), or wastes the vertical space and severely restricting the kinds of GPU that can be used in the case.
Are all Velka 3 preorders likely to be fulfilled in the January timeframe quoted above, or are they going to be done in batches according to how early you preordered? I was quite late to the party (I preordered my Velka 3 about a week ago, and I believe preorders have been taken since September), and I don't know if I should actively start seeking out parts yet.
Awesome! Thanks so much for the quick replyYes and yes. They are all still expected to ship out this month over the course of 1-2 weeks, starting from the earliest pre-orders
