Still working on itAny news on the Europe distributor deal?
Would it be correct to assume that pre-ordering directly instead of waiting for the deal to realize, will mean a notably earler delivery for the case?Still working on it
If you are waiting for a delivery option not even present yet how are you planning to preorder it?Any news on the Europe distributor deal?
I figure my options are:If you are waiting for a delivery option not even present yet how are you planning to preorder it?
A direct order would be quickerWould it be correct to assume that pre-ordering directly instead of waiting for the deal to realize, will mean a notably earler delivery for the case?
Currently looking to be around Monday for those placed in December, you will receive tracking info soonDo you have a tentative shipment for those who ordered early December ?
Gainward also released one and MSI made a 3060 in their popular Aero ITX card size!
I'm not sure a 3060 would see a significant difference running at PCIE4 vs 3. You can see a number of videos on Youtube that compare RTX 3070 and 3080 running at both PCIE 3.0 and 4.0, and even at 4K on high end CPUs, the difference between average, 1% low and 0.1% low FPS is small.Now if only there existed a reliable PCIE 4.0 riser on the Earth...
As I understand it, the issue is that if you have it connected to a processor that supports pcie 4, it is extremely buggy regardless of whether or not you're actually using the extra bandwidth because there exists no riser that actually meets the specI'm not sure a 3060 would see a significant difference running at PCIE4 vs 3. You can see a number of videos on Youtube that compare RTX 3070 and 3080 running at both PCIE 3.0 and 4.0, and even at 4K on high end CPUs, the difference between average, 1% low and 0.1% low FPS is small.
But you would effectively need to dismantle your system each time you do a BIOS update, because BIOS updates reset the PCIe mode.But you can manually set the pcie mode in the bios so if you know you do not need the extra bandwith build it outside the case, plug the gpu in directly, set the pcie mode to gen3 then build it with the riser inside the box. No more reliability issue.
Nice!Happy New Year, everyone. We're getting closer to the re-stock; power supplies are here and will become available in these next few days. Cases are still expected sometime in January. Thanks to all those who have been waiting patiently.
Does this case come with all necessary screws? I was excited to see that my case had shipped, and I was reading the manual online to see what I was in store for installation-wise, and it seems that page 4 lists that there are 13 total screws, but then the rest of the manual seems to indicate that there are 37 separate screws required for assembly (assuming you want an SSD). Am I reading this right?
Please email me for a button replacementHi all, I just received my Velka 3 rev 2.0 and PSU (pre ordered back in October) and its beautiful. I put everything together, however it seems my power button doesn’t work. When I plug the power switch and power LEDs in, then plug the PSU in, the computer turns on for a second then shuts down. I’ve tried another power button from another case I have and that one turns the computer on and off no problem. Is there anything I can do to fix my current power button, I would want to avoid soldering as much as possible and I’ve seen threads about replacement power switches being too long (granted these threads were about the velka 3 rev 1.X). Thanks in advance.
Just to get a better understanding, how often do you update your BIOS? I have not had to do it more than once per system to achieve stability.But you would effectively need to dismantle your system each time you do a BIOS update, because BIOS updates reset the PCIe mode.
