Thank you Matt! He helped me out and was able to add custom holes to the front of the case so I could snap in a game cube adapter.
Hey Matt,
I'm planning on building HTPC/home server for my living room in your xCase S.
I won't need GPU since I will be using Ryzen 2400G, and it's a server as well so I will need room for 2 x 3.5-inch drives or more. Can you make a bracket for that? Can you even fit 3.5" drives in it? Also are black/dark see-through panels doable with white everything else?? (RGB is Life)
Thank you!
I'm guessing you took one of these apart for your controller?
If you put the case in a silver, could have called it GameCube Dev kit lol
Hey Bud, Love the Case will be ordering one sometime late this year!
I noticed that you dont have a Presence on r/SFFPC
Maybe you should post some of your work/ builds
HD-Plex 400W AC-DC isn't currently supported by xCase M. Unfortunally they made the new unit too long. We're working on a solution though.
Not sure what riser you have, but if it's the one recommended/bought from modivio, all 4 fans will eventually fit. The riser you can bend very heavily without issues. And make sure the GPU is not slacking much from the pcie bracket screwdown. I commented only one fan fit for mine, but eventually I got them both installed on the GPU side without issues.Picking up my xCase S tomorrow as I missed the courier and getting my G Unique on wednesday. Looks like I get to start building this week. Exciting times!
