Company's website - www.modivio.com
xCase is a line of console-style computer cases perfect for your next gaming PC, workstation or an elegant PC for your living room. It supports the best processors and graphics cards on the market.
The main component of xCase is a 3D printed bezel. Bezel contains mounting points for all main components and ensures structural integrity of the case. It's manufactured using high-strength ABS material. Side panels are laser cut from acrylic glass.
Hole pattern on side panels of xCase allows you to mount 80mm, 92mm and even 120mm inlet fans wherever you want. Furthermore xCase S, M and L support up to 6 60x60x10mm exhaust fans while xCase SE, ME and LE support up to 6 80x80x10mm exhaust fans.
