News Gigabyte/ASUS/GALAX RTX 4060 Low Profile
Gigabyte is creating an RTX 4060 low-profile card: https://www.tomshardware.com/news/g...-be-the-first-low-profile-ada-lovelace-design
3 fans, single 8-pin, 2 slots.
Pie in the sky, but would love to see an RTX 4060ti (or more crazy RTX 4070) model at some point.
___
16/01/2023 Addendum
ASUS now has a 4060 Low Profile card.
188mm, triple fan.
___
19/04/2024 Addendum
Galax has a card
182mm, triple fan, but the PCIE cable is at the front which will affect clearance without a custom solution.
Will advise to look for something slightly bigger
Cases these will fit into (double check before you buy, not everything is available):
Lenovo P3/P360 ULTRA - 182mm* - Gigabyte (May require modding)/Adapter Needed
ZS A4DC V3 - 182mm* - Gigabyte (May require modding)
ZS D2 (D Config) - 182mm - Gigabyte/GALAX (Possible PCIE cable issue)
Gemcase C9 - 182mm - Gigabyte/GALAX (Possible PCIE cable issue)
Lone Industries L5 - 185mm - Gigabyte/GALAX (Consider PCIE adapter)
Custom_Mod SL3 STL 4.8L Rev.1 - 185mm - Gigabyte/GALAX (Consider PCIE adapter)
n3rdware Yocto - 185mm** (Guidance rather than a limit) - Gigabyte/GALAX (Consider PCIE adapter)
n3rdware Yocto+ - 185mm** Guidance rather than a limit) - Gigabyte/GALAX (Consider PCIE adapter)
ZS D2 V2 - 186mm - Gigabyte/GALAX (Consider PCIE adapter)
Custom_Mod Case MINI LP edit. - 190mm - Gigabyte/ASUS/GALAX (Consider PCIE adapter)
J-Hack Pure MK2 - 190mm - Gigabyte/ASUS/GALAX (Consider PCIE adapter)
Lazer3D HT5 - 194mm - Gigabyte/ASUS/GALAX
Lazer3D Cravo - 195mm - Gigabyte/ASUS/GALAX
CAPTAIN CASE V9 - 208mm - Gigabyte/ASUS/GALAX
REVOCCASES N0RDR1 Nano EVO - 210mm - Gigabyte/ASUS/GALAX
Metalfish 2 Plus - 210mm - Gigabyte/ASUS/GALAX
LZmod A24-V5 V2.0 - 220mm- Gigabyte/ASUS/GALAX
Silverstone Milo ML03 - 223mm - Gigabyte/ASUS/GALAX
Silverstone Milo ML04 - 223mm - Gigabyte/ASUS/GALAX
Metalfish G5 - 245mm*** - Gigabyte/ASUS/GALAX (MATX Board width)
Bug C1 - 245mm*** - Gigabyte/ASUS/GALAX (MATX Board width)
SKTC A10 - 245mm*** - Gigabyte/ASUS/GALAX (MATX Board width)
Silverstone Milo ML11 - 272mm - Gigabyte/ASUS/GALAX
REVOCCASES
REVOCCASES
2,059
3,338
www.revoccases.com
Analogue Blacksheep
835
691
Reactions: REVOCCASES
REVOCCASES
REVOCCASES
2,059
3,338
www.revoccases.com
Gigabyte just launched two new models:
4060 non-OC:
3050 slot powered:
orinie
39
59
Seems like an odd card for the non OC version of the 4060? the difference is a only 15MHz?
2460 vs 2475MHz?
will be interesting to see the price delta between those two variants will be?
4060 non-OC:
hrh_ginsterbusch
441
169
wp-devil.com
I've seen some manufacturers doing the same with higher tier cards and asking 50 to 80 EUR more for those 15Mhz XD
So yeah, I'm also curious to see the price because those 15Mhz you can get for free via Afterburner :p
The OC version currently sits at 355 Euro (cheapest option) here in Germany (acc. to Geizhals), but I'm not gonna complain if we get it for a few euros less in the non-OC version instead :)
cu, w0lf.
Gingerbeer
103
92
My OC boosts to around 2725 MHz at stock, so the D version will likely still boost to around 2700 MHz, unless they're heavily binned. That's a winner if it's significantly cheaper.
Reactions: hrh_ginsterbusch
k0n
218
285
I had no idea there was a 3050 LP. Damn I've been wanting to upgrade my 1650 LP for a while for HDMI 2.1
Like @REVOCCASES said it was just launched ...and don't think of it as a 3050 LP it's a 3050 6GB LP!
Along with 2GB less the memory interface is down from 128bit to 96bit, the core count is down from 2560 to either 2304 or 2048 (some conflicting info there) and the powerlimit is down from 115W to 70W.
So whether it is a 8GB or 6GB RTX 3050 is even more important than whether it is a 12GB or 8GB RTX 3060!
(NVIDIA being NVIDIA doing NVIDIA things).
Reactions: shreebles
orinie
39
59
Oh wow.... That is quite the nerf.... more do they need to bring out the xx40 naming? because it is sounding more and more like it should be a 3040 TI :p
Reactions: steelfractal
smitty2k1
968
493
Does anyone thing a Hdplex GAN250w PSU would have a problem with the 4060 LP and a Ryzen 3600x?
RichterSnipes
39
26
Just wanted to pop in and share that the Gigabyte 4060 will fit inside an ML09 when deshrouded. But just barely!
I'm using two Noctua fans (NF-A8 PWM chromax and NF-A6x25 PWM) fastened to the case's fan mounts for the cooling, with washers added to push the fans as close to the heatsink as possible. Turns out you can't fit two 80x25mm fans in here due to the second slot's DP interface getting in the way. And with there being no chromax variant of the NF-A6x25... it just sticks out a bit compared to the rest of my build. But it works!
It doesn't stay quite as cool as the stock fans, but it's able to go up to 2790 MHz with just undervolting. Pretty satisfying IMO.
Gingerbeer
103
92
Thanks. My case, J-hack Pure-X, also has a spot for a 40mm fan to blow over the HDPlex and a Noctual L12S CPU cooler.
I have my small rig housed in my T1 at the moment while I make some mods for the A4DC, but I've just printed @msystems toastyplex fan mount for the 250w GaN. Looks like a nice solution. I don't need the extra cooling, but it's nice to try things out.
