There is 47mm, enough for a 90degree fitting or some nice tight bend!Hm, how long free space between distroplate and PSU? ~5cm?
Yes there will be acrylic for sure, or glass if im lucky with prices. Power buttons are just made, its got my custon logo lighting in the middleLooking for a A4 case with "real" water cooling support and i found this.
Some question to ask, will it have any transparent side panel or power on button in the future?
I am looking forward to the final results.??
Yes, it need one. I'll figure it out if it can go with the current pump holder or needed a seperate one.For D5 metal cover need thread on mount/hold plate for pump.
Thats so true! I think about that earlier. The best way will be in the middle of the case at the cpu side, in the backplate. In the current design there is no hole for this socket because I need to talk that with my manufacturer. The only problem with it is the aesthetic. But we will solve this dont worry.Hole/Socket for extension power cable can be pain, when you try connect CPU waterblock and bottom radiator with hard tube. More better if you can move this hole and cable socket to the top of backplate and hide cable at top case corner. Also it will look better then long black cord at middle of case.
Or move it to GPU side. I'm afraid about how to connect CPU->Bottom rad -> GPU with hard tube and will not be blocked by power cable/socket.
This case remind me to my Hexgear, the best case for watercooling to me (yes, he too with his little flaws, certainly)
But i think you are on the way of "masterpiece" Mr @diceboii13 !
Hi Whippler!Hi @diceboii13 My current x99, 5930k PC, almost 5 years old now, has started to show its age and has problems with running all the ram. So i looked to go SFF for my next PC and iv been lurking in r/sffpc to find a suitable case. My current fractal R6 has 360x40, and 280x45 rads. I contemplated on evolv shift X and modding it to fit one of my rads for few days before i stumbled upon this project! This case is definitely going to be it!
I think i will go with 9700k, and the Asrock z390 Phantom Gaming itx board. and 1080ti from my current PC. I'm hoping to find a good deal on black friday for the new hardware. Looks like your case is still a month or two away from final design? Ques i'll have to put the itx hardware into my R6, until i can get my hands on this case.
- Any news on the tempered glass sidepanels?
- How long gpu can you fit into the case? is the pump going to limit the length?
- I will be putting the 280x45 rad at the top. Could it be possible to fit/mount two 3.5" hard drives AND two 140 intake fans to the bottom when its fully extended? I know the HDDs will block a lot of the airflow but maybe there could be enough of a gap to do it?
You will turn to the dark side soon son! ? ? Thanks for those kind words man!I've always been an air cooling guy, and appreciated water cooling, but never wanted to fuss with it... The more you show of this case, the more I think I'm going to fuss with water cooling. This case continues to impress, and I really can't wait to see the final product.![]()
