We are currently redesign the distro for less air bubles. I will take a look at it!
Near the Ghost, for some size comparison. Soon the gear will change, to a liquid cooling one!
Thanks man! Its because I built it specially for watercooling. Thats why its a bit bigger, the pump and tubing needs more space.Your case looks better than the ghost for sure, easier to watercool too
Just arrived! PCIe cables with printed logos on it. Its for the first production ready cases. Thanks to @yawacool from Li-Heat!
Still on the way are the aluminium case feets with anti slide rubber pads in black and white colors! They are 8mm in height but stackable with a longer screw.
@alauder Is currently testing his new tapping gear on the final acrylic design, so in a couple days we can see how the covered and the uncovered configs looks like.
A custom black power buttons that has my logo on it, are in progress. It has white light when turned on. I dont have images from it jet, but hopefully in this week I can share some. In their images it looks sick!
The TG sidepanels are still in progress but looks promising.
Thats what I got now..![]()
Thanks! I just cant wait to see the custom power buttons.Everything looks awesome
Thanks for the update. How are things with bifurcated PCIe cables?Thanks man! Its because I built it specially for watercooling. Thats why its a bit bigger, the pump and tubing needs more space.
Currently the space for it is there but I need more research on that. Especially with cables, I think it will be an "update" when I release the case, if I cant figure it out in time. But I'm on it man!Thanks for the update. How are things with bifurcated PCIe cables?
Would be a pity if it were to be delayed as an update. I can only suggest others to register their interest in bifurcated PCIe cable so we can understand the demand.Currently the space for it is there but I need more research on that. Especially with cables, I think it will be an "update" when I release the case, if I cant figure it out in time. But I'm on it man!
I dont think there will be much interest in it mate. I agree with @diceboii13 that it can wait if it was to delay the release.Would be a pity if it were to be delayed as an update. I can only suggest others to register their interest in bifurcated PCIe cable so we can understand the demand.
Till december I try to figure it out, but to be honest I cant promise you 100%. Its almost my personal project so thats a bit hard to keep everything in head time to time, but I do everything for it to finish it in this year! Thanks for your understand! I'll post every update so you will see how it will turn out.Would be a pity if it were to be delayed as an update. I can only suggest others to register their interest in bifurcated PCIe cable so we can understand the demand.
Yes it can be that simple if I cant do it in time! But hopefully I can. It will be an extra cost anyways. Just need to figure out how much because these are really special cables.Do I need to secure a pre order ? I love how this train keeps moving steady. Bifurcated pci is huge for me , so I Might just order separately and piece it together
