if you deliver thourgh fedex or like, it should be fine
Last time Sliger sent my top cover, it took 2 days to come from Sliger to France..
It should be fast, definitely
Shipito from CA offered approx $84 USD to Singapore via FedEx in 2-4 days.
I have not check shipping on the order form but will decide when I order tonight or tomorrow.
Ok the web page for ordering works really well on iPhone (good job !), shipping is $104 and up... Makes for an expensive case after options but order will be made
Shipping is always going to be brutal to APAC but this is something with nothing else like it in the market and if you want small and pretty and performs then it will cost a bit. Of course and local method in future to ship would be appreciated as I am sure it won’t me my last build.
C14S is working with 2x25mm fans and with hinge, no issue.Correct me if I'm wrong, but for the Cerberus, I thought cooler clearance was 142mm w/ side hinge and 148 without.
Also, @Aibohphobia and @MarcParis, from those pictures with the NH C14s, it does not seem like there is room for cooler + 1 fan on the hinge. Unless the clips on the cooler fan can be offset from the heatsink.
EDIT: Checked the product page and don't see clearance numbers.
Oh interesting, how did you find out about them? o_o
I might go the vpost route actually. Seems to be cheaper:
Admittedly Fedex would ship the fastest (and already includes Insurance), but I might be only be able to afford the slow
- Fedex straight from Sliger:
- $128.05 Economy
- $146.48 Priority
- Shipito: $15.24 from Sliger to CA + $84.24 via Fedex Priority (economy's barely any cheaper: $83.49)
- Total: $99.48 minus tax
- vPost: $15.24 from Sliger to OR + $43.80 (USD) via vPost Economy
- Total: $59.24 minus tax
- Going by sea might be the bit cheaper ($46.58 total), but it says in site it has to be more than 10kg ._.
boatairship now ,_,
Won't be online till next week, first build people will need to post questions here (there's only 4 different screw for whole box, and they're kitted up to make sense where to use them).
How did that rate compare with the calculator on our site? I may get in touch with them if they're able to get things overseas cheaper than our direct rates.
Well I'm not so sure about this 155mm cpu cooler clearance...
Here is picture from @Aibohphobia using a Cryorig H7 cooler (145mm height)...without the hinge it just barely fits in Cerberus.
Post : https://smallformfactor.net/forum/t...matx-usa-made-enclosure.454/page-29#post-9241
As far as I remembered, CPU IHS should be like/approx 8mm tall.
