The Chimera MachOne: For the pros. Small meets flexible.
zugok
Wahaha360 IMHO, the case looks too wide to really compete.
The Cerberus (+X), Ncase M1, Louqe Ghost S1, Thermaltake G3, Raijintek Ophion, ect are all under 175mm (under 7") in width.
There is literally only three full sized ATX sized cases that are under 175mm in width (slim/narrow) , the Cerberus, P-ATX and the Thermaltake G3
There are tons of cases over ~175mm most of them in the same range as the one you posted.
Necere
3,300
If you count cases that sit horizontally, all of SIlverstone's GD-series HTPC cases are 175mm and under. There are probably others too, those just came to mind.
Reactions: zugok
kami_sama
49
Hey, just learnt of this case today. While it is not as small as others, I feel that the gamer option is awesome for GPU compatibility, and it provides a lot of cpu cooling in the 280 radiator support.
I hope we get to see more of it in the future.
VegetableStu
1,949
2,619
2020 Q1, 23L, 280+240 Rad support or 165mm Air Cooler support.
few questions:
  • is the side panel tempered glass or acrylic?
  • will there be a rear plate (above the IO shield) that holds a fan? if so how big?
  • how's the strength of the handle? how much weight can it handle (maybe in terms of the kinds of hardware e.g. NH-U14S or the recently revealed ProSiphon by icegiant)
  • will there be a separate thread for this case? ,_,
Boil
1,266
1,102
Grand Junction, CO, USA
Looks like that is where the PSU goes...
More important question is, what is the airflow in this chassis...?
To me, it looks like only the front & bottom have any intake/exhaust; so the options are intake from the front, exhaust out the bottom, or intake from the bottom, exhaust out the front...?
Wahaha360
a.k.a W360
2,131
10,697
USA
You can't support 165mm tall air cooler at 175mm or less.
I have seen the case in person, making it 15mm more narrow is not going to make it visually much different, but you will loose compatibility.
Wahaha360
a.k.a W360
2,131
10,697
USA
few questions:
Side window might offer both TG and Acrylic. Timing not sure, one will come first.
There is a rear plate that supports 120mm fan
Handle is solid. You can have the handle and Noctua D15 / 165mm cooler at the same time. @PlayfulPhoenix and I have lugged it around fully loaded. I see the handle as something useful for small moves, not for you to hold onto for hours, so for that purpose its fine.
New thread for this case https://smallformfactor.net/forum/t...tx-that-should-have-been-made-long-ago.12028/
  • Love
Reactions: VegetableStu
Wahaha360
a.k.a W360
2,131
10,697
USA
The airflow is front (intake) to back (exhaust) and bottom (intake or exhaust).
Kit
163
75
Agreed, I'm loving the metal aesthetic of this case. Looking forward to see some more developments!
VegetableStu
1,949
2,619
the recent pictures are of an entirely different case project. the mach one should prevail (with the exception of dropping mATX for DTX)
