When will you update the renders to the latest revision of the cases ??
Up-to-date 3D models have just been uploaded to the product pages, but they still do not appear to work in any browser other than Chrome.
I see. What about the perforated side panels? Would i be able to fit a screw through some of the holes to mount a fan blowing on the motherboard? Or would i have to zip tie it?There is room for two 80 mm fans, but no mount. You would need to zip tie them to the storage brackets next to the 215 mm graphics card.
Hey Michael. Would like to enquire about the compatibility with this cooler.
http://thermalright.com/product/axp-100-full-copper/
Or other possible combinations with it.
I have almost forgotten until now. The side panel hole pattern allows mounting 80 mm fans to it with regular fan screws, so you would be able to mount one fan next to the graphics card that way.
This has probably already been asked, but will the VK-5 1.1 revision come with a PCIe 4.0 compatible riser?
Is this true for the VK-3 side panel holes as well ??
Hi guys I’m looking to downsize may current pc, this will be my first SFF build
Do you guys know if the case Is compatible with MSI H170I Pro AC Mini ITX LGA1151 Motherboard ?
I was concerned because of compatibility of the Io shield
Thanks
Hello everyone,
I saw the video of the Velka 5 on Youtube and I'm smitten by this case ?
Has anyone shipped one of these to the UK? Just wondering how long it took for you, and how much custom fees was charged?
Thanks
Thanks, I haven't ordered anything from abroad in recent memory so I was never sure how this worked. I still assume there is an element of luck if you get hit with custom charges or not, or have they clamped down on this now?I didn't get the Velka 5, but the customs charge is always 20% of the stated value plus 8 quid admin charge
So will the IO shield prevent the Asrock X570 itx/tb3 from working in this case?
Only a PCIe gen 3 riser, which will work if you can set the PCIe on your motherboard to run in gen 3 mode. You would have to replace it with an $87 250 mm 3M riser to get 4.0 support.
