Just got my Velka 3 earlier this week, and I couldn't be happier. What an awesome case!
I'm looking for some feedback on this idea
For those who would prefer having direct access to the graphics card IO in the Velka 5 and 7 without the use of HDMI and DP extension cables, another design could be used for the main body of the case with a rectangular cutout on top above the graphics card. This can be backwards compatible with the current design but require re-assembly.
To clarify, this would only add to the IO port compatibility. Graphics card clearances would stay the same, otherwise there would be visible screw holes and protrusions at the topWow, that's great! Personally, I wouldn't mind cables sticking up on the top of the case, especially when it adds more GPU compatibility!
So with the removal of the top 80mm fans on the Velka 3 v2, I started to see if perhaps 40mm fans would fit. Turns out 3 NF-A4X20mm fans just so happen to kind of fit. I fastened the fans by way of the nuts provided by Michael and used the screw from my nh-l9a for the 25mm fan. I also used zip ties to connect the fans into a straight line as seen below. Here is the placement:![]()
The issue that comes up is with the back connection of MB plate, where the 3rd fan cannot be placed flush like the other and be retained by a nut and bolt. There is a slight piece of metal which protrudes and blocks easy installation of the fans and MB plate to the external case, so I cannot fasten it. Issue seen below:
I was wondering if cutting of that slight piece would have an damaging effects on the cases structural integrity or not @micheal? If not I might try to just do that.
You are either compromising on GPU length (like velka 3) or you have to change the whole layout for that. (something like Dan A4)What about having the GPU IO on the same side as the MB IO? Honestly I would love a case like that, with enough room for a 2.5 SSD, 3.5 HDD & a slim ODD.Be better then this big RVZ2 sitting flat on my desk. Plus cases with front PSUs are a bit odd.
Having graphics IO on the same side might be possible with an ITX length graphics card around 170 mm, but anything more than that would require a completely different case with new components like the AC cord extension, new layout, new structure, etc.What about having the GPU IO on the same side as the MB IO? Honestly I would love a case like that, with enough room for a 2.5 SSD, 3.5 HDD & a slim ODD.Be better then this big RVZ2 sitting flat on my desk. Plus cases with front PSUs are a bit odd.
How much thermal improvement do you see? Looks interesting!So with the removal of the top 80mm fans on the Velka 3 v2, I started to see if perhaps 40mm fans would fit. Turns out 3 NF-A4X20mm fans just so happen to kind of fit. I fastened the fans by way of the nuts provided by Michael and used the screw from my nh-l9a for the 25mm fan. I also used zip ties to connect the fans into a straight line as seen below. Here is the placement:![]()
Dude, you're asking for a COMPLETELY different case that has nothing to do with the Velkase cases...What about having the GPU IO on the same side as the MB IO? Honestly I would love a case like that, with enough room for a 2.5 SSD, 3.5 HDD & a slim ODD.Be better then this big RVZ2 sitting flat on my desk. Plus cases with front PSUs are a bit odd.
Here's an suggestion: What if the Velka 3-RL was slightly taller to accommodate a dual slot, half-height graphics card (i.e. no riser)? I think it would be a nice solution for users who would like extra cooling height for the CPU but still want some sort of graphics solution that isn't an APU (which are hard to come by and seem to not be a very large focus at AMD these days). Existing cases of this type, like the Lone L5 and the J-Hack Pure Mk2, require a power brick, which stinks. With this layout, we could use Flex ATX instead and have a nice self-contained solution.
I would certainly be first in line to buy one! Really think that that layout would fill a niche that is somewhat neglected in the uSFF space : a simple, no-fuss case for users with minimal GPU requirements. Everything else in the < 5L space requires some combination of weird motherboard form factors, ultra short coolers, risers, external bricks, weird PSU setups, etc. I imagine that if the 3-RL had this capability, it would become the case of choice for these sort of no-gaming/light-gaming builds because of how dead simple the whole build process would be. You wouldn't even need an aftermarket CPU cooler!It will take a while but I think it can be done.
