Completed Project PURE: 3L APU case, MEANWELL Support
NinoPecorino
Tweezer Squeezer
495
486
my only suggestion is mostly aesthetic: extend the vent pattern to cover more area and be symmetrical.
Windfall
2,117
1,577
Anyways. This about wraps up the first iteration of the case. I only have one or two stock left.
I have big plans for Mk2. Expected release date... 3 months from now? Let me know if you guys have any recommendations.
RGB MOUNTS!!!
@GuilleAcoustic Gamer fam, you agr33?
In all seriousness though, I can't imagine what big plans you could have. It's very simple, and very perfect.
Stevo_
449
304
USB ports of some type in the front, nearly pulled the trigger before I got my K3 but was a deal killer
smitty2k1
936
473
Nice to see that review and glad to hear they are selling well and you plan to keep producing and improving!
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
2,801
4,127
guilleacoustic.wordpress.com
RGB MOUNTS!!!
Ind33d !
Side note: I'm pretty sure the guy made a mistake when assembling the power socket. He should have inserted the wire and then the socket body through the hole....
Thehack
Creator
Mar 6, 2016
2,779
3,592
J-hackcompany.com
Thank you for the support everyone.
Right now there is currently 2 Black and White available for grabs. This will be the final stock of Ver 1. I only made a few to clear out some extra trays I had.
See you 2020 for version 2.
Reactions: rfarmer and jaro
vlad1966
46
26
J-H, Any new on version 2 of the Pure X? Exactly what will be new & when the black/white will be available? Definitely looking to pick up one of these. Thanks.
Thehack
Creator
Mar 6, 2016
2,779
3,592
J-hackcompany.com
Pure X? It is currently available. I will updating be stock after vacation so you should see some black/white available.
ondert
298
143
This first version seems so tempting now after reading the leaks about 4700G can surpass i9-9900kf and reach gtx 1050 level on gpu side. My next build might without gpu.
Aguda33
104
181
The original Pure is no longer being made check out the Pure Mk 2 ;
You will probably find it suitable.
