Cool! Never went there! Thanks again!Reddit.com/r/sffpc
BTW, also the Supermicro C242 allows the same power input, and has also the 24pin.
BUT it miss the audio chip, but has a full 2280 M.2 support!
My nf-a9x14 PWM (under the black ridge, inside the pure case) makes an rather unpleasant noise once it gets to around 1100rpm (1100 onwards and it gets worse and worse). It sounds different to airflow, it's like a engine wine, mid range/pitch kind of sound. Does this happen with your one? I wonder if its due the thinner motor. I can set fan curve to make quiet (pretty much silent) at 1000rpm, but I wonder if this issue happens with the nf-a12x15 PWM fan too... Just due to the thinner motor. Would be nice to know as I would like to be able to run it at higher than 1100rpm while still not being bothered by it..Tested earlier and got about 4-5 degrees hotter on the CPU when pulling air down/in.
All other sensors were within 1-2 degrees either way.
Kind of a pain to swap the fan direction on the Blackridge or I would do more testing.
Super sleek build!
BTW, maybe some short has caused the smoke.
Is it possible that an usb WiFi adapter has caused issue in the USB port and the short?
I don’t wan’t to fry the second PSU! ? even if still don’t know if is still working or not or if the board and cpu are still working...
Test them next week!
Mmmh, in fact sounds strange to me as well. I try to change the psu and the wall plug, and let’s see!I have never actually seen plugging in a USB causing issues.
But also a few time before, when trying to plug the WiFi usb dongle, the system where restarting. No problem doing the same with other usb peripheral...
smallformfactor.net
Hi all. I am selling my J-Hack Pure + 2x8 2666MHz cl19 vlp adata + 200w internal psu (plus 120w plugin) + alpenfohn black ridge + noctua nf-a9x14 pwm (Im happy to sell for less without this noctua fan if you want to get your own 120mm slim fan to optimise cooling even further, will still come with 92mm fan that came with black ridge cooler). I'm not sure if you can access trademe (like ebay for New Zealand) links internationally but here is my auction for some more information (I think):
Trade Me
www.trademe.co.nz
I'm aware probably all of you are from other countries, however international shipping to US from NZ, fully tracked, with a 1-6 day estimated delivery time is $60 NZD. I'm not sure how much it would be to other countries, I can find out for you if you're interested. I am asking $400 NZD (negotiable) for all of it (it cost me $615, including shipping).
I am not sure if this is a very good value proposition for you but let me know if you are interested. Cheers.
Indeed! I was just curious if is it possible to know which cause it. Maybe is a transistor related to the USB? Or directly to the PSU? Hope the CPU is fine!Looks like a dead transistor.
This, exactlyIt's hard to know, what is on the other side?
Cool! Thank you! I've ordered a new one and sent also a contact form about the b-stock white tray.If you place another order for a second unit, I'll send you a replacement tray in addition to it. You will have to move the standoffs by yourself.
Alternatively, you can also choose to receive a b-stock white tray, or a replacement tray as part of the warranty policy (1 year for chassis). You can send me a support email for more info.
