This makes me want to replace my Silverstone SFX-650w in my NCASE M1 for no reason
ETA is likely December. Those people who are itching to get their hands on one can PM me for a barebones kit in NOV, but it'll lack final user friendly manuals and packaging and maybe even final cable kits. It'll be available as:
Meanwell integrated kits will come 2019
- barebones, board only for modders/tinkers
- Basic Kit A, and B, includes cables and hook ups for dancase and Skyreach
- Possibly a premium kit with cosmetic CNC backplate and cover
I do not have any prototypes to sell/give at this time unfortunately.
Don't discount the silent lurker ^^I can't get over the fact that this is essentially the final solution to so many builds, yet the thread just.... sits....
Meanwell units aren't exactly small you know. Plus, I've still some doubts about running upwards of 20A in ~300W builds..
Would the Meanwell integrated kits be setup by customer or you? As I thought the Meanwell unit(s) don't come with their input and output wiring setup?
It will have pre-made wiring harness to be assembled by the user. It'll be tailored for the cases I'm designing.
For example, the J-Hack Pure you can use a 12V or 24V meanwell RPS-200, with hdplex or 12V plugin units.
Later on, with the release of the Pure XL you can use an RPS-400 to power Dynamo 360 or Distro 400 for a stupid 400W internal build.
Finally I'll have the correct wiring to hook up the meanwell 250W external brick, a high quality brick that can handle 8400+1070 build.
Realistically how much could a 1050ti + CPU consume? Is there any possible way to draw anywhere near 400w in the Pure XL?
(I'm not complaining about anything, I'm just curious)
Running upwards of 20A inside the csse for ~300W builds.What doubts do you have exactly? The distro 400 itself? Or the meanwell AC-DC units?
Thanks! Would a 200w meanwel be totally out of the question?Realistically most people would max out at 250W in a 1050 ti build if they OC the cpu.
That's pretty much what I'm doing. What exactly is the concern versus something like HDPlex? You'll have to spell it out for me.Running upwards of 20A inside the csse for ~300W builds.
It might be nothing to worry about, I know.. I'm actually down for this, planning to get and try one once @Thehack finalised it.That's pretty much what I'm doing. What exactly is the concern versus something like HDPlex? You'll have to spell it out for me.
Working on 3d printed cover.
It fits perfectly inside the S4 mini and will be powering a 2600X + GTX 1070.
You can see the industrial wago connectors, which is a key feature of the Distro 400.
SO here it is, tested live, on a 2600X + GTX 1070. The build can't be easier. Look at those (lack of) cables! 12V! No coil whine issues!
Cool, so no CNC heatsink? It's okay!
That looks awesome- Do it brickless!
