Concept ONE2 AC-DC and DC-ATX Boards - a 12V family
Thehack
Creator
Mar 6, 2016
2,779
3,592
J-hackcompany.com
Concept thread for ONE2 Plugin DC Boards.
150W Model?
250W Model?
Would pair nicely with the ONE2 Distro 400.
Any features you guys are interested in?
Thehack
Creator
Mar 6, 2016
2,779
3,592
J-hackcompany.com
Updated post for product specs and concept information
SFX-S 12V
  • Short SFX 12V AC-DC unit
  • Uses 3D printed and RPS-200-12C to create a 12V AC-DC
  • Up to 200W output
  • 62mm x 125mm x 46mm
FLEX ATX 12V
  • Uses FLEX ATX standards
  • Up to 400W output
  • 80mm x 40mm x 160mm
  • Used in conjuction with DC-ATX Boards
SHORT FLEX ATX 12V
  • Up to 200W output
  • 80mm x 40mm x 125mm
DC ATX Boards
  • Small DC-ATX boards
  • Takes 12V input, megafit connectors
  • Up to 300W Model (for now)
  • Available with angled 24 pin
InfernoZeus
98
53
Just for my own clarification, the wattage limit on such a board is used for the motherboard, CPU, and max 75W to the PCI-E slot, right?
Thehack
Creator
Mar 6, 2016
2,779
3,592
J-hackcompany.com
I'm looking at doing two versions, 1 as you suggested above, and the second version, would have 200W continuous, 250W peak, and able to power a 6 pin GPU.
I'm still trying to figure out the details of it right now. The issue is that there's few supporting AC-DC units and going about making it intuitive to integrate these 12V AC-DC units is difficult.
CC Ricers
2,216
2,522
I would like to see it have a smaller footprint like the PicoPSUs. The only issue I have with the HDPlex is that it juts out a little to far which could be a problem with tight fitting components, depending on the motherboard used.
PicoPSU makes a wide voltage plugin unit with a smaller width but also overlooked since it only provides 120W.
Thehack
Creator
Mar 6, 2016
2,779
3,592
J-hackcompany.com
So the biggest issue is minibox has a patent on direct plug psu. I haven't figured out a good way around it.
I really want to sell these units long term and legitimately in the US. I don't want to get knocked down by minibox when they're on a spree.
InfernoZeus
98
53
Out of interest, I searched for mini-box's patent - link
At the bottom, I noticed the following:
Legal Events
Date Code Title Description
2013-01-07 REMI Maintenance fee reminder mailed
2013-05-26 LAPS Lapse for failure to pay maintenance fees
2013-07-16 FP Expired due to failure to pay maintenance fee
Effective date: 20130526
Does that mean what I think it means?
Thehack
Creator
Mar 6, 2016
2,779
3,592
J-hackcompany.com
I'm not sure. I'll try to make an email or call to the patent office and see what they say about that.
It may not affect the product as much as you'd think. The way G-Unique is able to fit so many connectors is by direct solder pads, which requires more skill than normal production.
I also know that many people prefer to have customized cabling as well.
I also will have an LC filter circuit as well, which most plug in boards do not have. The ones that do (HD plex 160) are quite big.
EDIT: I called the patent office, and they said "expired" means they can reinstate the patent when they feel like, though at this time, it is not valid. WOOT WOOT. Thank you for point that out.
While this makes it easier, I'm not sure if I can design a 400W plug in unit the same way that G-Unique can. I may still use a 2 board design.
InfernoZeus
98
53
WHOOP WHOOP! :cool:
2 board, as in one DC-DC filter/splitter board, and one DC-ATX plug in unit? That still a pretty useful offering.
Thehack
Creator
Mar 6, 2016
2,779
3,592
J-hackcompany.com
WHOOP WHOOP! :cool:
Yes. Similar to the Distro board.
I'm thinking of
120W -> PLUG IN Only
200W -> DC-ATX Board
300W -> DC-ATX Board
400W -> DISTRO 400 + Plugin
Does that seem like a good spread?
Reactions: Elerek
smitty2k1
936
473
I'm thinking of
Seems reasonable.
In reality what does 200W get you that 120W doesn't? Maybe skip straight to 300W.
CC Ricers
2,216
2,522
I can run a system with a 1050Ti just off a 150W power brick so this 200W has overhead and makes sense. 120W is good enough for a Ryzen APU system (even with a bit of overclocking).
InfernoZeus
98
53
I'm thinking of
Do you think the 120W should be able to run a 65W CPU, plus a GPU if it's powered separately? Something like this:
AC/DC ---> 120W Plug-in -> EPS CPU
|-> GPU PCI-E 6/8pin
Thehack
Creator
Mar 6, 2016
2,779
3,592
J-hackcompany.com
|-> GPU PCI-E 6/8pin
Yes. I would recommend you get a load switch though. The new plug in units will have a 12V sync signal, compatible with the switches aquelito makes.
