@Matt3D Really I mean a horizontally laid-out mini itx case that supports a single slot GPU and a fullheight mini itx (not thin-itx), but also keeping the footprint as small as possible. An (ugly) example would be this![]()
In this layout though there's extra unneeded (for my use) space to the right of the mobo the pcie slot is above the mobo. Not sure how that kind of layout would work with a 1050 ti (and of course there is no vent on the top of the case). I'm sure someone could make something like this work, specially if maybe you rotate the GPU so that it sits under the mobo like some divided cases are like.
Anyway to answer your question, I think so? Except I think dan cases are vertical? I'm not sure, I am not too familiar with a lot of the builds on here, just haven't seen one that I'd jump on
We've never done such build before. Our plan is to design a back-to-back case after we finish an APU case so stay tuned.
2) plan to make one with translucent/semi translucent material? or even heat sensitive material
We can print the case with a material like PET-G which is the most common translucent material in FDM world but I'm guessing it won't give an effect you think of. For the trully translucent case it would have to be printed with SLA / DLP printer but the cost of the resin would be huge. But I'm glad you mentioned thermo-sensitive material. We have a couple of spools of the material changing the color from grey to white and from violet to pink. We could also get the material changing the color from red to white. Just imaging the case being red and then turning white when you turn the computer on.
I got my Xcase S the other week and I was actually going to make one myself! I don’t have a big YouTube channel or anything but I figured with some decent editing and my 24MP camera I could make something nice out of it. Because yeah, for how great of a concept this case is, it certainly deserves more publicity than it has.
I can't wait for it
