Does anyone know how much room there would be between the motherboard and the other end of the case? Like, say I didn’t install a gpu, how much room would there be between the end of the motherboard and the other side?
There is approx. 156mm between the edge of the motherboard and the inside surface of the case. The space for the case fans is accounted inside that distance so if you'd be planning to use them, 146mm would be available.
would you produce filters slots on one side of the case?
I was looking for an elegant solution to attach dust filters to the side panels so many times I couldn't count them
