With the release of @hdplex 400W AC-DC and 800W DC-DC, i was wondering if Cerberus family could have any benefit in terms of cooling.
HDplex dc-dc 400w : 0.247200l
HDplex dc-dc 800w : 0.359370l
HDplex ac-dc 400w : 0.418528l
800w combo (800w dc-dc, 2x400w ac-dc) : 1,196426l
400w combo : 0,665728l
Sfx-l : 1.031875l
Sfx : 0.793750l
My main interest will be to have dual 120mm/140mm fans on front panel.
My initial thought was to use 400W combo but as my setup R7 1700X+GTX 1080ti overclocked can used 450W i prefer to aim for 800W setup, like my sx-800lti.
My second thought is to use back panel (below SFX front position) to install DC-DC 800W and use 2 passive 400W ac-dc bricks on top panel. But I guess 800W is too tall (need to check on my setup). It should be ok with width of 66mm, but need to check with front fan.
What do you think about this idea? For me there is potential vs ATX psu inside cerberus
Maybe we will need support of @Josh | NFC and @hdplex ..(great video from Josh on hdplex 400w ac-dc)
i would have some questions for them :
Any support will be welcome..
- is it possible to use externally hdplex 400w ac-dc? If yes what will be recommended cable between them?
- What will be maximum output of hdplex 800 dc-dc with 400w ac-dc, well vented? can it support 450w output?
Would really love to see someone pull out a mod incorporating this. I looked at a very similar concept back when I built my WC Cerb X. I originally wanted to put two hdplex ac-dc’s connected by a y inside the case on the top panel connected to two dc-atx’s (this was before the 800w released and I wanted two 400w) connected with the pairing cable. I even bought a hdplex 300w ac-dc to help figure out how to make my plan work with relation to tolerances and mounting.
The goal wasn’t to lower temps in my case, but rather free up the space at the mobo rear for me to mount my hdd’s to the side bracket. Unfortunately I had clearance issues with the pump and rad at the top and abandoned it.
Really wished hdplex would (or could,I know nothing of psu engineering) make a 800 ac-dc to go along with the 800 dc-atx. But really, by the time you combine the two’s size I guess it’s about the same size combined as a flex psu.
