It fits in cerberus-x, not sure for cerberus micro atxDoes anyone know if the NZXT G12 with a 140mm AIO would fit in the case? My Evga RTX 2080 XC is running kinda hot.
In the meantime, you can undervolt the card. I have the same card running at 875mV/1815Mhz with a max of 68C in the Cerberus X on an aggressive fan curve.Does anyone know if the NZXT G12 with a 140mm AIO would fit in the case? My Evga RTX 2080 XC is running kinda hot.
Thanks for the detailed reply!
Unfortunately, there doesn't appear to be any dual Epyc motherboards in the SSI-CEB form factor.
Could you specify what part of the case was blocking the internal I/O and RAM clips?
Would preinstalling the ram before installing the motherboard make things work?
I would definitely prefer to not sheer off the standoffs if at all possible.
Do they have to be removed, or can I simply add the correct standoffs while leaving the rest in place?
Thanks again for your time.
I've just found interesting review on Silver Arrow ITX-R :I would like to mention several air cpu cooler from Thermalright that should be compatible with Cerberus family :
- Silver Arrow 130 : dual tower, 120mm fan, however difficult or not yet available on market
- Silver Arrow ITX-R : 147mm tall dual tower, black nickel (i must admit, it's beautiful..
Silver arrow ITX-R should be similar to Syche Fuma rev B : you could mount inside Cerberus, but without side bracket.
Best orientation should be towards top of the case to exhaust hot air from gpu and cpu.
i still wonder how such 120mm dual towers cpu cooler perform vs noctua c14s, either a cpu cooler or gpu hot air exhaust..![]()
Basically Silver Arrow ITX-r is performing similarly as H7 Quad Lumi, a bit disappointing..![]()
That should help, however, as far as I've read you need to be ready to use some cable tie as stock fan is not standard (130x120).I wonder how much of that comes down to the fan. After reading the long rant on Reddit yesterday about Thermalright's weird marketing name for sleeve bearing, I'd be tempted to throw an NF-A12x25 in there and see how it improves.
But in that case, I prefer either triple U9L, dual U9S, dual/triple Fuma or dual C14S..![]()
I've directly compared the Silver Arrow 130 with the Noctua U9s.That should help, however, as far as I've read you need to be ready to use some cable tie as stock fan is not standard (130x120).
Thanks for sharing your experience.I've directly compared the Silver Arrow 130 with the Noctua U9s.
Basically, the SA 130 with one Gentle Typhoon 1850PMW perform equal to the U9s with 2x A9 PMW fans.
The noise' sound under stress is better in favor of the SA130, thanks to the 120mm fan.
BUT, I'll choose the U9s for the easier mounting system!
And actually, the U9s perform only a few degrees worse than the C14s, at least in the DA2.
FYI, the L12s with the A12x25 on top, perform 4/5 degrees worse than the U9 double fan.
Tested with a 9900K, no power limit and an ASRock Z390 ITX
Good to know it’s available somewhere..strangely google does not prioritize this site lolI've bought it on Taobao through TBfocus! One week and It was at my home
https://shop.tbfocus.com/item.php?id=582693616522
Lol i just noticed that you can order graphene customed version lolI've bought it on Taobao through TBfocus! One week and It was at my home
Sure this setup should be compatible with Cerberus-x except front 240aio with 25mm noctua fans as radeon vii, at least is measuring 305mm in length..Question around compatibility, this is the build I have in mind for now, not finalized yet:
- i9-9900X
- Rampage VI Extreme Omega (E-ATX)
- 240mm AIO front (with 25mm Noctua)
- EVGA RTX 2080 Ti XC (1st PCI-E)
- Radeon VII (2nd PCI-E)
- Extra card (3rd PCI-E)
- Seasonic Prime 1000W PSU
Do you think these components will be compatible in a Cerberus X?
It already is. I live in Brazil and i bought one@KSliger when the Cerberus is made available through Newegg, will it be available for worldwide shipping too?
