vpri
41
Sure this setup should be compatible with Cerberus-x except front 240aio with 25mm noctua fans as radeon vii, at least is measuring 305mm in length..:) as far as I remembered you have 329mm depth inside cerberus case.
Front radiator setup is only viable while using standard 10.5" / 26.67cm graphic cards.
Alternatives are simple :
  • Get a 120/140mm aio and keep same gpu
  • Use standard GPU length and keep 240mm front radiator
The RTX card seems it would be too big for the dimensions you've posted https://www.evga.com/products/product.aspx?pn=11G-P4-2382-KR
MarcParis
Apr 1, 2016
3,681
2,802
No RTX is good for cerberus-x and front radiator.
RTX evga 2080ti is 269.83mm length.
Radiator is 30mm thick
Fans are 25mm thick
Leading to a total of 324,83...let's say 325mm.
vs 329mm case lenght/depth it's a tight fit...but it fits.
After you can ease clearance by using noctua 120mm and 15mm thick. They have been used succesfully on several crammed setup like one from @fabio
Reactions: vpri
vpri
41
Fans are 25mm thick
Thank you for the great reply! For AIO I'll probably opt for NZXT Kraken X52, which seems compatible (height wise) with the PSU. I might even go for a SFX-L PSU with a single card to start with.
Reactions: MarcParis
MarceloSiciliano
62
51
So...i "modded" my Cerberus build and it dropped 5C on the GPU LOL
MarcParis
Apr 1, 2016
3,681
2,802
If you go on sfx-l, i advice you to put it on front position.
Thus you can opt for apogee drive ii + your choice of tube and radiator..:) full customed watercooling (powerful and quiet ddc pump, efficient and copper radiator..;) in aio size..:)
Check this option with my setup..:)
I guess you can use apogee drive ii with side sfx/sfx l psu but maybe without top radiator (easy to remove)
KSliger
Sliger Designs
May 8, 2015
855
3,186
I would like to mention several air cpu cooler from Thermalright that should be compatible with Cerberus family :
  • Silver Arrow 130 : dual tower, 120mm fan, however difficult or not yet available on market
  • Silver Arrow ITX-R : 147mm tall dual tower, black nickel (i must admit, it's beautiful..;))
Silver arrow ITX-R should be similar to Syche Fuma rev B : you could mount inside Cerberus, but without side bracket.
Best orientation should be towards top of the case to exhaust hot air from gpu and cpu.
i still wonder how such 120mm dual towers cpu cooler perform vs noctua c14s, either a cpu cooler or gpu hot air exhaust..:D
If we can gather up a good number of the compatible coolers I am happy to put them as recommended on the CPU cooler part of the Cerberus spec sheet. I will start adding up ones I find.
vpri
41
I'd prefer to use an AIO or air cooling system, custom watercooling solutions aren't for me. :)
MarcParis
Apr 1, 2016
3,681
2,802
Dislike most sff, there are a lot of compatible cpu cooler..:)
Maybe you should give some examples : c14s with front sfx, fuma scythe oriented to the top (intel) with front sfx psu, aio with side atx psu, etc...:)
7,461
@KSliger when the Cerberus is available on NewEgg, will it be using their shipping? I find that NewEgg shipping rates are decent value on most things. Just hoping that the NewEgg partnership may help a little on the NZ$530 plus taxes (NZ$133) it's going to cost me to get the Cerberus I want!
KSliger
Sliger Designs
May 8, 2015
855
3,186
Will be using their shipping rates, so should be way better. Do not have any quotes or estimates right now, but shipping for an H200 should be around the same.
