MarcParis
Apr 1, 2016
3,835
2,997
No plans for this, difficult to punch the number of holes we have now without the sheet turning warping. Full perforation would make the side panel look like a potato chip.
Why not making a stylish KI or an X with holes?
Can we have same number of holes but with different pattern?
AMv8-1day
228
193
So forgive me if it's been discussed but I ran a quick search and didn't find one. Has anyone tried dropping an mATX board into the X and cramming a 60-80mm Monsta radiator into the bottom for extreme cooling surface area? With a mATX board I would expect around 100mm of clearance, hopefully 105? @fabio proved there was definitely enough for an XSPC 20.5mm TX 240 + 15mm fans with a standard length 305mm motherboard. Shortening that to an mATX 244 would give you another 61mm to work with.
This came up when I as checking clearance on my SSI-CEB board for a front mount rad + 25mm fans and I should be able to clear up to 30mm radiators. It would be more, but 4 of my SATA sockets including the 2 native 6Gb/s are side mounted toward the front, killing a lot of clearance.
KSliger
Sliger Designs
May 8, 2015
855
3,186
With mATX in the Cerberus X you will have 99mm vertical space in the bottom, that is to the side edge of the motherboard.
Might be up to about 105mm if you overlap the motherboard a little.
You will need to get some standoffs that are 7mm long.
MarcParis
Apr 1, 2016
3,835
2,997
Hi, I'd like to share my Cerberus X in White and Maple. I'm sorry in advance for the dusty side window, I have cats and they shed like crazy!
That's a pretty build!
I'm thinking seriously to move to solid top panel, due to my cats..:) They are bringing some liter particles or hair that are falling into the case, despite my filters..:):)
Don't you have any overheating issue on psu with window panel in front of fan?
jtrias21
Apr 18, 2016
Hi, good idea with the dust filters, I definitely need to grab them! I really like the magnetic top wood panel, sometimes I pop open the top wood panel for ventilation.
No overheating issues with the PSU against the window side panel, I turned off the Zero-RPM so the fan is always spinning. Every bit of airflow helps. I've considered flipping the PSU to face the inside towards the motherboard, but it wouldn't look as good.
Reactions: MarcParis
Wyd4
196
218
I was so close to ordering the Cerberus today but the postage sadly was too much. I get it it’s a heavy case no doubt so it is what it is, but it certainly puts a dampener on it paying over half the cost of the case again in postage again.
Keep saving my pennies. :)
Reactions: keshon
OutereloCarlos
Hello everybody!
I was wondering if there is any update on the previously mentioned EU store. I was looking at both this case and the SM560, but since I live in Europe I might not be able to get one any time soon.
KSliger, do you have any timeline in mind?
I've read you intend to post the SM550/560 on your website on March 1 with Newegg availability shortly after, but I'm unaware of any date regarding the EU store.
Best regards.
MarcParis
Apr 1, 2016
3,835
2,997
Here is my latest update on my setup...and I discovered horizontal Cerberus-X!
You can read more here : https://smallformfactor.net/forum/t...x-complete-build-log.2007/page-24#post-136011
@KSliger as my case was coming from pre production, are feet easily removed? Is it possible to develop a new right panel including stylish feet?
KSliger
Sliger Designs
May 8, 2015
855
3,186
That’s an idea lol..:)
Let’s see if @KSliger has any good looking solution..:)
Stick on feet are only thing I can think of right now, unfortunately the bottom of the case has them mounted on studs which don't come out easily. Focusing on new cases right now rather than more Cerberus options.
But will make it happen on Cerberus V2, whenever that happens!
MarcParis
Apr 1, 2016
3,835
2,997
Ahah feet mounted on stud..:) hopefully i didn’t dismount my whole setup to check that..:)
Thanks @KSliger
Yes it will be great to have removable feet on next gen cerberus..:)
Iwanit
and it begins... Guess it's time to see if I've forgotten anything!
Worth noting that at the time of order Sliger were unable to fulfil my custom order of top vented with no USB cutouts (#1 below) and were only offering #2 and #3. ETA of being able to fulfil custom orders of #1 was "at least a month, possibly two" so I went through with the stock configuration. (They were very apologetic and were able to ship the case with the USB cable detached however)
@KSliger this is not a complaint - I think it's amazing you guys are offering custom orders to begin with. Just letting the rest of the readers here know as this information hasn't made it's way back here yet. :)
Beautiful light case by the way. When I picked up the box, I legitimately thought customs had forgotten to put the case back in after opening it up! Way lighter than I expected. Most certainly a dream case!
We have these options available:
  1. Top panels with no USB cutouts
  2. Top panels with no power switch or USB cutouts
  3. Top panels with no vent holes (but does have USB and power switch)
Only downside is they are only available in black.
#1 and #3 will be available on the site in the near future, email our orders@sliger.com if you'd like to get one sooner!
Wyd4
196
218
@Iwanit Very nice, look forward to seeing your build.
It is kind of sad, but I was excited to see your fan choice.
I just purchased 2 of these for my side rad in my ncase and they are the best fan I have ever purchased. Very pricey, but absolutely worth it!
MarcParis
Apr 1, 2016
3,835
2,997
With the release of @hdplex 400W AC-DC and 800W DC-DC, i was wondering if Cerberus family could have any benefit in terms of cooling.
HDplex dc-dc 400w : 0.247200l
HDplex dc-dc 800w : 0.359370l
HDplex ac-dc 400w : 0.418528l
800w combo (800w dc-dc, 2x400w ac-dc) : 1,196426l
400w combo : 0,665728l
Sfx-l : 1.031875l
Sfx : 0.793750l
My main interest will be to have dual 120mm/140mm fans on front panel.
My initial thought was to use 400W combo but as my setup R7 1700X+GTX 1080ti overclocked can used 450W i prefer to aim for 800W setup, like my sx-800lti.
My second thought is to use back panel (below SFX front position) to install DC-DC 800W and use 2 passive 400W ac-dc bricks on top panel. But I guess 800W is too tall (need to check on my setup). It should be ok with width of 66mm, but need to check with front fan.
What do you think about this idea? For me there is potential vs ATX psu inside cerberus
Maybe we will need support of @Josh | NFC and @hdplex ..:) (great video from Josh on hdplex 400w ac-dc)
i would have some questions for them :
  • is it possible to use externally hdplex 400w ac-dc? If yes what will be recommended cable between them?
  • What will be maximum output of hdplex 800 dc-dc with 400w ac-dc, well vented? can it support 450w output?
Any support will be welcome..:)
anoldfriend
44
61
Cerberus Build
z370-i 8700k
2080 ftw3
nh c14s
sx800-lti
I am able to achieve very good temperatures with all fans on the case on a load scenario max 1000rpm.
Idle all fans drop to 400-500, gpu 0 rpm.
The nhc14s is a beast, the 8700k is not overclocked, and single fan setup on the cpu heatsink is more than enough for this build.
I might try to fit a 15mm fan on top (with handle kit) of the nhc14s, but i think it will conflict with the noctua metal fan clip. On a previous build i was able to fit a schythe slip 12mm thick fan, later a removed it because it was a 3pin fan and I like PWM control.
The psu is very nice indeed (thanks @MarcParis), on a previous build I was using a corsair sf600, but the fan on that unit was easily getting to much loud for my tastes once above a certain load threshold and took forever to spin down after the power load. I had to bend the cables alot on the connector part of the psu because there was 0 clearance between the psu and cables (with cables installed). Tough but doable. Ftw is rigid ^^
I think I`ll order some silverstone cable kits
https://www.moddiy.com/products/Pro...erStone-Custom-Sleeved-Modular-Cable-Kit.html
there is a premium silver single wired kit (very thin cables by the pictures).
Has anyone tried those cables?
Thanks all!
MarcParis
Apr 1, 2016
3,835
2,997
Cerberus Build
z370-i 8700k
2080 ftw3
nh c14s
sx800-lti
https://www.moddiy.com/products/Professional-Tailor%2dMade-SilverStone-Custom-Sleeved-Modular-Cable-Kit.html
Thanks all!
Glad to see sx800 lti was a good advice..;)
Nice build by the way!
Reactions: anoldfriend
