Log SMALLEST ATX CASE : CERBERUS-X (Complete build log)
hrh_ginsterbusch
869
344
wp-devil.com
Thanks for the clarification, I was still trying to understand 😄.
I know it was only about the PSU, but Machine and more component combo left me speechless... 500€+ ITX mobo, 500€+ PSU... M2 on air should be paired with mATX for better VRM cooling, more storage, more fans header ... and reduced cost.
I mean, its what I thought first, too. If you can stuff mATX inside, then why dont ..? Could be that, indeed.
On the other hand: Its a passive PSU. At the very start of the system, the fan of the X870 board jumps on, very loud .. so that would explain why the MB is supposedly "ruining user experience" if its trying "to support double CCD chips". A lot of (m)ATX boards dont have that, acc. to the OP. They stress in the post before, that the mainboard used is the "MSI MAG X870 Tomahawk (fully passive cooling, 5Gb ethernet, allowing 2xm.2 x4 gen 5 at the same time, without hurting GPU bandwidth)".
On that topic: Lets not ignore the fact, that ATX boards got much more headroom, because .. uhm .. there is more PCB space? So the comparison is kinda wonky.
Aside of the fact that you can still disable those fans - yes, in some cases, you need to unscrew the VRM etc. pp., and certainly unplug the fan, but still, nobody hinders you to do so. Those heatsinks are massivelly overspec'd anyway. Yes, in theory, you could OC your CPU, but I guess the chances for this are much lower in an SFF scenario than eg. with a fullsize ATX or even just a simple MFF build.
cu, w0lf.
Reactions: MarcParis
MarcParis
3,792
2,946
took me a while to understand. for anybody else reading: OP is referring to the MB VRM fan. so that depends on your board.
Sorry for the lack of precision.
I was very upset by Asus, ultra expensive, board that is able to make gigantic fan noise at its startup.
Thus having a fan on mini ITX board to cool VRM for the most power hungry CPU (like R9) is a strong downside I found, especially versus ATX or Micro ATX that do not have any fan (at least on those generation..:))
hrh_ginsterbusch
869
344
wp-devil.com
Well, its Asus. They seem to be premium, but have failed repeatedly, at least in my POV, when it comes to mainboards. Been with MSI and Asrock for ages. Had one Asus board 15 years ago, because "they make solid stuff", and the failure rate with this board was horrible. Next on, "cheap" Asrock board, its still around, being used as a placeholder for anything mATX, and technically still working, too. Then there was a lot of notebooks, and fast forward to 2021, its MSI and Asrock all over again :D
This very system I'm writing this reply on, is running on an MSI Z690 mATX board. Solid, fun, no issues so far. Gonna be moved from the Asus AP201 to the Meshroom S / Mesh-mATX, when I finally finish with my optimization work on the K77 Lite workstation build (hopefully in the next few weeks).
That particular build, the K77 Lite workstation, with a 7950X, is set up with the Asrock B650E PG/ITX, which is also very solid, despite the lack of USB4. Esp. no weird VRM fan noises - because its got no VRM fan to begin with :D
TL;DR: Asus might have been good in terms of mainboards at some point, but most of the time, you pay a lot of premium you dont really need in the end. The peripherals, like monitors, or eg. the before-mentioned AP 201 case, are really solid, and most of it doesnt feel like overpaying the premium, but the rest feels .. disconnected, to say the least. Plus their current support / RMA issues 🥳 🤷‍♀️
cu, w0lf.
MarcParis
3,792
2,946
cu, w0lf.
Well I've mostly got Asus & Asrock MB since the last 20 years. I got one Gigabyte MB (OMG its bios...)
Here is my point of view.
In terms of reliability, Asrock was mediocre till 2021 (approx) where they reached the bottom...but nowadays they made very strong effort and they are back.
In terms of functionality, Asus tends to be ahead (main example are Bios and combine PWM/DC fans header), let's say during last decade.
Over the last MB generations, Asus is not so appealling, because they lost their main advantage (I would say Bios, hands down) as competitors improved a lot on this field. On top ratio functionality/price ratio is bad for Asus MB.
To be specific, the MSI X870 Tomahawk is the best AM5 MB, so far, in terms of functionality/price ratio. to switch to more expensive MB, you need to have a ultra specific needs (I see mainly extreme overclocking or mandatory needs of 10gb ethernet).
MarcParis
3,792
2,946
Cerberus-X late 2024 : Cooling the AMD Ryzen 7 9800X3D (19th December 2024)
Let’s start with the harsh facts : My Noctua C14S, paired with 2 Noctua NF-A25x14G2 was not able to cool the AMD Ryzen 7 9800X3D @stock settings during AVX512 workload (IBT2.54 with a maximum 154.34W used) without thermal throttling!!!
The AMD Ryzen 7 9800X3D is given for a base TDP of 120W but it can boost till 160W.
Based on my former experience I was expecting my Noctua C14S to be effective till 170W but based on a monolithic & central design processor, like my Intel Core i5 12600K overclocked @5.2Ghz. But facts are clear, Zen 5 (like Zen 4) is based on very small chiplets, significantly harder to cool efficiently!
On top of that, I noticed major power peaks on the R7 9800X3D during gaming sessions. “Dragon Age: the Veilguard” can consume between 80W-120W during standard gameplay, but sometimes this is exceeding this amount significantly (~140W-150W). Of course I’m excluding shader compilation as it is also a power hungry task. Those power peaks were leading to distracting & irritating fan noise…ie not acceptable from my point of view.
That is where my quest to cool & tame the AMD Ryzen 7 9800X3D started..:)
I would target two main objectives :
  • Explore alternative CPU coolers
  • Undervolt / underclock the AMD R7 9800X3D
Best CPU Cooler (Cerberus-X)
I thought of 2 main competitors (both 120mm Tower style) of my beloved Noctua C14S inside the Cerberus-X :
  • Thermalright peerless assassin 120 mini
  • Noctua NH-D12L
Finally I decided to keep only the Noctua NH-D12L as “Thermalright peerless assassin 120 mini” fan is pretty mediocre in terms of noise and difficult to replace (due to fan clip)
Here are common parts :
  • Thermal paste : Arctic MX-6
  • Noctua Offset mounting hardware : NM-AMB13 (C14S) & NM-AMB14 (D12L)
Let’s compare the 2 cooling setups :
  • Noctua C14S :
    • Orientation : Vertical (Heatpipes are towards top of the case)
    • Fresh Air Intake : From the top of the case
    • Hot Air Exhaust : Towards the side of the case (with NM-AMB13, the Noctua C14S is perfectly aligned with the side panel aeration)
    • CPU Cooler Fans : 2xNoctua NF-A14x25G2 placed as exhaust (perfect to exhaust all the hot air coming from the GPU)
    • Other Fans : None
    • Final setup look :
  • Noctua D12L :
    • Orientation : Horizontal (I tested Vertical orientation, but it was requiring too much speed from the 2xbottom intake fans to cross the GPU)
    • Fresh Air Intake : From the vented side of the case
    • Hot Air Exhaust : Towards rear & top of the case
    • CPU Cooler Fans : 1xNoctua NF-A12x25R
    • Other Fans : 1xNoctua NFA9-25 (Rear) + 1xNoctua NF12x25 (Top)
So is there any clear winner?
Well...well...here is a comparison from IBT 2.54 Very High profile (Intel Burn Test), assuming, similar peak power consumption :
Short answer between the Noctua D12L and the Noctua C14S, inside Cerberus-X, on a Ryzen 7 9800X3D (~155W TDP) :
  • Pure Cooling performance : very similar on either CPU & GPU (RTX 4080 FE was also very similar)
  • Cooling/Noise ratio : Advantage for the Noctua D12L as 140mm tends to be too noisy for me above 1000 rpm
At least, I've my own opinion on the debate between the 2 CPU coolers within the Cerberus-X. It could be important as I read some rather too optimistic review on reddit stating some 15-20°C advantage for the D12L over the Noctua C14S.
Here are some gameplays video using both CPU cooler, at stock settings :
  • Noctua C14S :
  • Noctua D12L :
Undervolting/Underclocking the AMD R7 9800X3D
Basically this step represents most of the time I've spent tweaking my setup. However I will spare you the boring approach of trials/errors..:D
I will try to sum-up what I've experienced :
  • The most limiting factor for undervolting : Gaming. Basically undervolting PBO Curve Optimizer -30 was working fine with IBT 2.54 & Cinebench, but drivers were crashing while gaming.
  • Best undervolting setup was using PBO Curve Shaper (new feature introduced with Zen 5), instead of Curve Optimizer
  • Best undervolting setup : PBO Curve Shaper :
    • Min Frequencies : -30
    • Low Frequencies : -30
    • Med Frequencies : -30 (Max Threads performance, like Cinebench)
    • High Frequencies : -10 (Gaming)
    • Max Frequencies : -10
  • Despite PBO undervolting, I'll still experienced audible power peaks while gaming, thus I decided to test also underclocking
  • I tested 2 ways to underclock :
    • MSI Bios : TDP setup with power range
      • 120W-160W (Stock)
      • 95W-128W (no gaming performance loss)
      • 65W-88W (Gaming performance loss up to 2%, mostly equal)
    • AMD PBO / Limit / Manual / PPT : Put Wattage in W (some other MB could be in mW). Tested (& approved) at 95W
    • I recommend PBO PPT Limit as I experienced regular stutters while gaming with MSI Bios TDP Setup, especially at 65W-88W TDP
  • Overall undervolting & underclocking (TDP limit) is leading to massive efficiency "Performance/Watts" improvements (up to +52%) versus stock parameters
As I was pleased with the overall results of undervolting/unclocking (look at this Cinebench 2024 Multi score at 1303 with a 95W TDP vs 1360 at best with 128W/PBO-Curve Optimizer -15) I decided to test a tiny CPU cooler, suited for mini ITX builds, the ID-Cooling IS-47-XT (47mm tall, 92mm slim fan, 95W TDP in Theory)
BONUS : ID COOLING IS-47-XT vs AMD R7 9800X3D
Here is the almighty ID Cooling IS-47-XT :
  • 2 orientations possible ! (like most of Noctua CPU coolers)
  • Good contact pressure
  • Feeling as if it is missing something!
  • Full setup using Noctua NFA9-14 PWM fan, 2500rpm Max
  • Cooling Performance tested with a TDP of 65W-88W (Pass) and 95W-128W (heavy thermal throttle)
  • Gaming Performance (TDP 95W-128W) : Very loud and thermal throttle
  • Gaming Performance (TDP 65W-88W) : Quieter than the RTX 4080 FE, no thermal throttle!
  • Idle noise : While at 65W-88W, the R7 9800X3D was basically quiet (not audible) even I needed to setup idle CPU temperature at 65°C (thermal balance was stable)
This test was not totally innocent as I wanted to test my R7 9800X3D in smaller cases than my Cerberus-X (like my N-ATX v2). Overall I'm impressed by both the ID Cooling IS-47-XT and the AMD R7 9800X3D, even undervolted/underclocked!
The AMD R7 9800X3D is shining by its incredible power efficiency!
I hope you enjoyed this article as much as I did.
More to come...hopefully still this year!
MarcParis
3,792
2,946
Cerberus-X N-ATX v2 : Testing the AMD Ryzen 7 9800X3D inside an ATX MB 15l case (23rd December 2024)
After the successful testing with limited power limit on the AMD Ryzen 7 9800X3D inside the Cerberus-X (using PBO, power limit, PPT) I decided to test the full setup inside my SFFTIME N-ATX v2.
Why considering the N-ATX case?
  • Not currently used in my living room
  • Due to its size, it is fitting nicely behind my 49” screen (Position while testing my FormD T1)
  • N-ATX is compatible with a 78mm tall cpu cooler. My current thermalright AXP120-67 is compatible with 120W TDP (based on AMD R7 5800X) based on my personal experiment
  • N-ATX has pretty good GPU temperature and easy cable management
  • N-ATX is compatible with mini ITX MB (tested with my minisforum BD790i)
  • I’ve an active thread about this case : https://smallformfactor.net/forum/t...se-sfftime-n-atx-v2-complete-build-log.17997/
Here are the components I picked up :
  • CPU : AMD R7 9800X3D
  • MB : MSI X870 Tomahawk
  • CPU cooler : Thermalright AXP120-67 with Noctua NFA12x25 Chromax fan (intake)
  • GPU : Nvidia RTX 4080 FE
  • RAM : Corsair DDR5 2x24Go Vengeance 6200MTS
  • SSD #1 : WD SN850X 2To
  • SSD #2 : Samsung 990 Pro 4To
  • Rear fan : Noctua NFA12x15 Chromax as exhaust
  • PSU : Corsair SF750 platinum + custom cable for GPU (but suited for FormD T1, not the N-ATX v2..:))
What about the CPU cooling?
Well I tested using PPT (PBO power limit) of 95W and 120W with optimized curve shaper
At 95W, the performance gap between the Noctua D12L/Cerberus-X and the Thermalright AXP12-67/N-ATX v2 is nil. However in terms of thermals the Noctua D12L/Cerberus-X is slightly better ~2-6°C
At 120W, the Thermalright AXP12-67/N-ATX v2 is capable of almost match performance of a stock R7 9800X3D. The thermal gap (+5°C for the D12L with a +23W additional to cool) is not super impressive for the Noctua D12L, does it mean it is bad? I would not say that the small chiplet design is clearly limiting the heat dissipation.
What about mix/gaming cooling?
Following the good results for the 120W TDP, I decided to try this setup first.
Here is a test with power limited to 95W :
Overall, GPU & CPU thermals are very similar to the Noctua D12L/Cerberus-X. Nothing new compared to what I already found.
Regarding the TDP of 120W I experienced the same disturbing power peaks as in the Cerberus-X. Thus I’ll continue my experimentations with a TDP of 95W.
I’ll continue my experimentations with something pretty new…stay tuned!
MarcParis
3,792
2,946
CERBERUS-X : Testing MSI RTX 5080 OC (18th March 2025)
This RTX5000 launch was just a nightmare…unfortunately it is still pretty bad.
Getting my hands on one RTX 5080 was the worst challenge ever in my, pretty long life, of IT geek. I was beaten by scalpers, I was scammed by fake scalpers…but I finally got one from official retailers…I definitely caught RTX fever that leads to bad bets/decisions.
It was even harder as not so many cards are compatible with SFF, basically 4, including the ghost FE model.
I gave up trying to catch one FE. Dislike former releases, Nvidia really screwed this launch like a champion!
Here is a RTX 5080 selection I built :
RTX 5080 CardsDimensionsU-ITX
(306 x138 x 60 mm)
Cerberus-X
(330 x 152 mm)
N-ATX
ATX (67 x 388 x 163 mm)
Mini ITX (82 x 388 x 163 mm)
Asus RTX 5080 Prime306 x 126 x 50 mmYesYesYes
Nvidia RTX 5080 FE304 x 137 x 40 mmYesYesYes
MSI RTX 5080 Ventus OC303 x 121 x 49 mmYesYesYes
MSI RTX 5080 Inspire288 x 112 x 50 mmYesYesYes
Gigabyte RTX 5080 Wind Force OC304 x 126 x 50 mmYesYesYes
MSI RTX 5080 Trio OC338 x 140 x 50 mmYes with 40mm offset panelNoYes
MSI RTX 5080 Suprim SOC359 x 150 x 76 mmNoNoYes, with mini ITX only and no back fan
MSI RTX 5080 Vanguard357 x 151 x 66 mmNoNoYes
MSI RTX 5080 Shadow303 x 121 x 49 mmYesYesYes
Gainward GeForce RTX™ 5080 Phantom GS331.9 x 145.6 x 69.9 mmNoNoYes, Mini ITX only
Asus RTX 5080 TUF
348 x 146 x 72 mm
KFA2 GeForce RTX 5080 1-Click OC315 x 140.5 x 50.7mmYes with 10mm offset panelYes, barelyYes
Gainward GeForce RTX 5080 Phoenix331.9 x 133.1 x 60 mmYes with 30mm offset panelNoYes
Zotac GeForce RTX 5080 Solid OC329.7 x 137.8 x 67.8mmNoNoYes
PNY GeForce RTX 5080 Triple Fan OC330 x 60 mmYes with 30mm offset panelNoYes
Inno3D GeForce RTX 5080 X3 OC300 x 120 x 50 mmYesYesYes
Asus ROG RTX 5080 Astral
357.6 x 149.3 x 76 mm
NoNoYes, only mini ITX
Palit RTX 5080 gaming pro331.9 x 127.1 x 60 mmYes with 30mm offset panelNoYes
Palit RTX 5080 gamerock331.9 x 150 x 70.4 mmNoNoYes, only mini ITX
RTX 5080 GAMING OC 16G340 x 140 x 70 mmNoNoYes, only mini ITX
In the end, I got one MSI RTX 5080 Ventus OC:
In detail, this MSI RTX 5080 Ventus OC is the model with 4 big heatpipes (the “PLUS” version seems to have 6 smaller heatpipes, do not expect any performance gap between the 2 models). There are 3 fans of ~90mm, directly controllable by the software Fan Control (2 fan controllers, 1 for the i/o fan and 1 for the middle/last fan). Fan speed range is approx between 1000 rpm to 2200 rpm. This card is pretty light, with just 1.1kg in total weight.
Most important : My RTX 5080 has 112 ROPS…a full chip!
I must admit I was a bit reluctant as few reviews/feedback were not so gentle, and I was not sure who was wrong…at least, now I know..:)
To test & benchmark it I used my beloved, cherished, almighty Cerberus-X!
Here is the full setup :
  • CPU : Intel Core i5 12600K, stock
  • CPU Cooler : Noctua C14S + NF-A14 (exhaust)
  • MB : Asus Prime Z690-P Wifi
  • RAM : 4x8go DDR4 GSkill Flare-X 3200MTS CL14-14-14-34
  • GPU : MSI RTX 5080 Ventus OC
  • PSU : Corsair SF750 + Cablemod 12vhpwr (3xType 4)
  • SSD #1 : ADATA SX8200 Pro 2To
  • Bottom Fans : Pair of Noctua NFA12x25 (Intake) + Spacer NA-IS1-12 chromax.black Sx2
Strangely enough, colors (silver+black) of the Asus motherboard are matching 100% the ones on the MSI RTX 5080..:D
One of the best selling points of getting an MSI GPU is that it is fully compatible with MSI Afterbuner, which remains the best software to tweak a GPU.
Please note that the MSI RTX 5080 OC does not have the possibility to increase the power limit. It is 100% and that’s the full maximum! Anyway I was never a fan of increasing the power limit.
Speaking of overclocking, I was able to apply a +300Mhz on the core (exceeding the 3000Mhz during load) and +1000Mhz on the GDDR7. These are still early numbers and I will continue playing with them later on.
At last, I did not apply any undervolting as it is impacting significantly the performance of the RT cores. I prefer to use DLSS4 mode to limit the power consumption.
Here are the benchmarks, comparing with my RTX 4080 FE and even my RTX 3090 FE!
Thanks to the “free” overclocking the RTX 5080 is a step up versus my RTX 4080 FE, especially with ray tracing.
But what about the thermals & noise of this MSI RTX 5080 Ventus OC card?
Let’s be honest, fans on the MSI RTX 5080 Ventus are miles away from Noctua’s ones, but they are at least decent. They have some parasite noise but overall they are OK. It is useful to say that “deshroudding” this card is easy & simple and is not removing the warranty. However I might wait for a retail 3D printed kit to test it properly.
Zero fan mode at idle is working fine too.
There is some coil whine but at a very acceptable level & occasional.
At last regarding thermals, within the Cerberus-X, with this very optimized airflow (tons of fresh intake air, quickly exhausted once heated up), the MSI RTX 5080 is running like a charm/champ! If I leave the original fan curve, the RTX 5080 is not exceeding 70°C under ~300W load.
Thus I decided to use a custom fan curve, limiting the fan speed to 50%, ie 1500rpm. With this setup the RTX 5080 is reaching 72-73°C under 300W load.
Here is a gameplay session in “The last of Us”
Time to conclude on this MSI RTX 5080 Ventus OC!
Let’s be simple, in an optimized airflow, this GPU is working very well. I’ve very little to complain about.
However, unlike the RTX 4080 FE, the heated air of the MSI RTX 5080 Ventus is not oriented. So within a case with little to no airflow, thermals & noise should be hurt significantly.
Stay tuned as I’m already testing it in my U-ITX.
MarcParis
3,792
2,946
CERBERUS-X : The ONE to beat ! Torturing the MSI RTX 5080 OC (22th March 2025)
Well, well, in an unexpected way, my Cerberus-X is winning back my love over smaller cases using mini-ITX motherboards. My main reason is, again, its polyvalence : to be able to cool efficiently any type of GPU (passthrough like the RTX 3090 or RTX 4080 or open air like the MSI RTX 5080 Ventus or my older MSI GTX 1080 ti..:)). This is on top of the very easy maintenance, good cpu cooling & compact size.
In fact I should have remembered that open air GPUs are not well suited for passive / low airflow cases. I had similar issues with my node 202 and also the CL530. After almost 4 years of Nvidia Founder Edition, very well suited for those smaller cases, I simply forgot or I considered getting FE as granted.
I wanted to demonstrate, in this post, the cooling (thermal & noise) of the combo of the RTX 5080 Ventus with the Cerberus-X. Solution was finally very simple : make a video of 3DMark Speedway in torture mode.
Here are numbers of the RTX 5080 Ventus :
  • Overclocking applied : Core + 420Mhz, GDDR7 + 2000Mhz
  • Power : ~350W average
  • Fan speed : 1950rpm
  • Core temperature : 69°C-70°C
  • GDDR7 temperature : 90°C
As comparable fan speed (~1900rpm) & core temperature(~70°C), here are power than can dissipate the other cases tested :
  • Sliger S620 : 300W
  • SFFTime N-ATX : 275W
  • SFFTime U-ITX : 270W but at 2200rpm (max rpm) already
I also wanted to highlight the excellent overclocking reached on my MSI RTX 5080 Ventus. Achieving +420 on the Core and +2000 on the GDDR7 without touching the power limit is a great free boost. The RTX 5080 once overclocking is getting pretty close to an RTX 4090 (within ~10-15%), not bad at all!
Here are the 3D Benchmarks results
To celebrate my return to the Cerberus-X, I finally decided to move to the black theme…and it is gorgeous!
To be continued!
MarcParis
3,792
2,946
Cerberus-X 2025 : Back to active service : R7 9800X3D + RTX 5080 Ventus (30th March 2025)
After having performed so many trials with my MSI RTX 5080 Ventus, I decided to move back to my Cerberus-X as my active setup.
I could not ignore how superior the MSI RTX 5080 Ventus was inside my Cerberus-X versus all the mini ITX cases I tested.
As an ATX motherboard, I decided to not go back to the MSI X870 Tomahawk I used in late 2024. In comparison, the Asus B650E-I already performed way better (RAM compatibility, Boot time, USB incompatibilities).
MSI remains a very good brand, but mostly focused on Intel (Motherboards) and Nvidia (GPU). I wish MSI was putting the same love into AMD products.
Thus I selected to go with the Asus ROG STRIX B850-E Gaming WIFI for the following reasons :
  • Great connection bifurcation to the CPU setup :
    • GPU : PCIe 8x Gen 5
    • SDD : 3x m.2 SSD at PCIe 4x Gen 5
  • Very good connectivity : 1xUSB4, Wifi 7 (full @6.5Gbps), 5Gb Ethernet
  • Total of 5 m.2 slots, up to 3 full PCIe 4x Gen5 (CPU) + 2 full PCIe 4x Gen 4 (B850 Chipset)
To be frank, the technical specs of the Asus B850-E are close to the MSI X870 Tomahawk, but Asus is delivering a significantly better user experience on this, at a 80€ overcost.
I started with the installation of the Thermal Grizzly Contact Frame & bios flash back.
Time to install it in the Cerberus-X.
  • CPU : AMD Ryzen 7 9800X3D (default limits), PBO Curve Shaper :
  • Motherboard : Asus ROG STRIX B850-E GAMING WIFI
  • CPU Cooling :
    • Heatsink : Noctua C14S with offset mounting bars NM-AMB13
    • Cooling fan : Fan replaced by a Noctua NF-A15 HS PWM CHROMAX BLACK SWAP
    • Contact frame : Thermal Grizzly
  • RAM : Corsair Vengeance 2x24Go 7600 MTS (XMP profile). Booting time is also excellent.
  • GPU : NVIDIA/MSI RTX 5080 Ventus OC +420/+2000 (Core/GDDR7), custom fan curve °C/PWM (50:0/60:40/100:60), power limit @100% (I cannot increase it , anyway), connected at PCIe 8x Gen5
  • PSU : Corsair SF1000 with its standard cables.
  • SSD#1 : Samsung 9100 Pro 2To (Gen 5), connected to the CPU at PCIe 4x Gen5, Motherboard heatsink
  • SSD#2 : Samsung 990 Pro 4 To (Gen 4), connected to the CPU at PCIe 4x Gen5, Motherboard heatsink
  • SSD#3 : WD SN850X 2To (Gen 4), connected to the CPU at PCIe 4x Gen5, Motherboard heatsink
  • Bottom Fans #2, #3 : Noctua NF-A12x25 Chromax/black + Inlet side spaces NM-IS1-12 Chromax.black Sx2, Intake
  • Front i/o : 2xUSB Type-A, 5Gbps
m.2 SSD Beauty!
RTX 5080 @8x PCIe Gen5
As usual I’m installing Windows without a dedicated GPU. I enjoyed the full display port on the motherboard i/o. Before I tend to deactivate iGPU but finally I’m keeping it active right now.
Like on the MSI X870 Tomahawk, the Noctua C14S is perfectly aligned with the Cerberus-X side bracket! Only one fan for now. I will most probably test with 2 as it should improve the top intake.
Time to plug the MSI RTX 5080 Ventus
Inlet side spacers are great to avoid air turbulence noise!
Gorgeous view!
Very clean rear side…even if nobody will check it when the Cerberus-X is in its place..:)
By the way, by looking at the photos, I might have forgotten to remove the plastic film on the rear i/o..:D
A quick word regarding the fans setup. As for the MSI X870 Tomahawk, “Fan control” software is currently incapable to see or manage properly the fans connected to the Asus B850-E motherboard.
My main concern is mostly for the intake fans that need to be linked to the MSI RTX 5080 Ventus GPU temperature. I was finally covered by the Asus Fan Xpert software (now integrated in Armory Crate). At first I thought it was iGPU temperature, but no, it is well, the discrete GPU temperature that is monitored here. Thanks Asus for that!
Let’s finish with some benchmarks. Once again I used 3DMark benchmarks to compare versus my Core i5 12600K and versus my RTX 4080 FE & RTX 3090 FE.
3DMark Time Spy :
  • While using the RTX 5080 Ventus OC +420/2000, the R7 9800X3D is 10% faster compared to the Core i5 12600K
  • Combo RTX 5080 Ventus OC +420/2000 + R7 9800X3D is 29% faster than RTX 4080 FE + Core i5 12600K
  • Combo RTX 5080 Ventus OC +420/2000 + R7 9800X3D is 80% faster than RTX 3090 FE + Core i5 12600K
3DMark Port Royal :
  • While using the RTX 5080 Ventus OC +420/2000, the R7 9800X3D is 4% faster compared to the Core i5 12600K
  • Combo RTX 5080 Ventus OC +420/2000 + R7 9800X3D is 42% faster than RTX 4080 FE + Core i5 12600K
  • Combo RTX 5080 Ventus OC +420/2000 + R7 9800X3D is 95% faster than RTX 3090 FE + Core i5 12600K
3DMark Nomad Steel :
  • While using the RTX 5080 Ventus OC +420/2000, the R7 9800X3D is 3% faster compared to the Core i5 12600K
  • Combo RTX 5080 Ventus OC +420/2000 + R7 9800X3D is 11% faster than RTX 5080 Ventus OC “Stock” + Core i5 12600K
  • Combo RTX 5080 Ventus OC +420/2000 + R7 9800X3D is 41% faster than RTX 4080 FE + Core i5 12600K
3DMark Speed Way :
  • While using the RTX 5080 Ventus OC +420/2000, the R7 9800X3D is 1% faster compared to the Core i5 12600K
  • Combo RTX 5080 Ventus OC +420/2000 + R7 9800X3D is 10% faster than RTX 5080 Ventus OC “Stock” + Core i5 12600K
  • Combo RTX 5080 Ventus OC +420/2000 + R7 9800X3D is 40% faster than RTX 4080 FE + Core i5 12600K
Please keep in mind that the Ventus OC “Stock” is ~5% above a true stock RTX 5080 FE.
I’ve also updated my RTX 5080 Ventus fan curve to this one : °C/PWM (50:0/60:40/100:60). It is working like a charm as the RTX 5080 is reaching low 70 even at higher power load (300-330W) that the RTX 5080 tends to reach way more than the RTX 4080.
Here is a RTX 5080 power test in Assassin’s Creed Shadows, testing how much the GPU is using while using DLSS4 modes, DLAA, Multi-Frame Generation (x4). Speaking of this MFG (x4), it is working well when FPS is reaching ~160 fps. Below it could feel sluggish.
As a simple conclusion, I’m very pleased with this final setup : it is fast to boot, very reactive, very good at data transfer, pretty powerful while remaining cool & quiet within a compact format, especially with the horizontal position I’m using.
Of course, more to come!
Allhopeforhumanity
547
538
  • CPU Cooling :
m.2 SSD Beauty!
Gorgeous view!
3DMark Time Spy :
3DMark Port Royal :
3DMark Speed Way :
I wonder if you 3D printed some ducting to connect the bottom fans to the GPU shroud, and prevent re-circulation of any side ejected hot air, how much better yet it could be!
I do find it amusing how much the SFF space has come full circle back to the Cerberus and nCASE M1 with cutting edge gear.
MarcParis
3,792
2,946
Well, I suppose SFF evolved a lot with very SFF friendly Nvidia FE card for RTX 30 & 40 series. Now we are back to open air GPU (or GPU is delegating again the entire airflow management to the case), thus we are back to former & efficient case design.
Regarding your question about 3D print duct, it should not help a lot with my current setup as my bottom are clearly forcing the airflow. This kind of duct should help a lot cases without clear airflow.
MarcParis
3,792
2,946
Cerberus-X 2025 : Benchmarking RTX 5080 Ventus Overclocked versus RTX 4090 (24th April 2025)
Sorry for the delay, crazy days currently.
Very quickly I wanted to share how close a well overclocked RTX 5080 versus a RTX 4090. I used 3DMark as a reference.
Quick note about Nvidia Drivers : I made those screenshots while using driver 572.83. Meanwhile driver 576.02 576.15 were released. Final results while overclocking are similar whatever the driver revision. However 576.15 tends to increase base performance and reduce maximum overclocking potential...but the end result is similar.
RTX 5080 Ventus manually overclocked (mOC) :
  • Core : +420Mhz (~3100-3200Mhz)
  • GDDR7 : +3000MTS (36000MTS)
  • Power limit : 100% (no increase possible on the Ventus)
  • Pwer consumption : 360W maximum
Time Spy :
  • RTX 5080 Ventus mOC : 35516
  • RTX 4090 (average) : 36323 (+2.3%)
  • Comment : This benchmark could be easily limited by CPU.
Time Spy Extreme :
  • RTX 5080 Ventus mOC : 17872
  • RTX 4090 (average) : 19448 (+8.8%)
  • Comment : Less CPU limited version than the standard version.
Port Royal :
  • RTX 5080 Ventus mOC : 24921
  • RTX 4090 (average) : 26114 (+4.8%)
  • Comment : No CPU bottleneck in this benchmark. As soon as Ray Tracing is activated, the gap between an RTX 5080 & RTX 4090 is almost closed
Steel Nomad :
  • RTX 5080 Ventus mOC : 9101
  • RTX 4090 (average) : 9222 (+1.3%)
  • Comment : No CPU bottleneck in this benchmark. The same as Port Royal but even smaller gap.
Speed Way :
  • RTX 5080 Ventus mOC : 9868
  • RTX 4090 (average) : 10076 (+2.1%)
Conclusion
  • I was expecting a gap of approx 10-20% between my mOC RTX 5080 and an average RTX 4090 on a gaming workload, but the gap was way smaller
  • Average RTX 4090 user seems impacted by "not optimized" CPU setup or by "power limit/downclock" the GPU
  • As soon as Ray Tracing is involved, RTX 5080 is basically on part with the RTX 4090
Overall this is confirming that the RTX 5080 is a pretty good card, either compared to my former RTX 4080 or RTX 4090.
And I'm not referring to "fake frames champion" Multi Frame Generation, that is not a game changer versus Frame Generation.
More to come...
MarcParis
3,792
2,946
Cerberus-X 2025 : Quest of the quiet gaming setup! (29th April 2025)
For almost two months I've been using my RTX 5080 Ventus OC. Despite the pretty poor Nvidia launch of the Blackwell architecture - actually Nvidia is, at last, actively acting to solve so many drivers issues - I’ve enjoyed my overall experience.
One of the most important lessons learned is that a RTX 5080 is significantly more power hungry compared to my previous RTX 4080 FE. Overall, the RTX 5080 Ventus (power limit at 100%) is generally sitting close to 300W-330W under gaming load. But even at idle, it is common to see the RTX 5080 using 30-50W, forcing the GPU to leave their fanless mode in a regular way.
Thus I thought about how to further improve my setup.
  • By default the fan curve of the RTX 5080 Ventus is aiming to maintain 70°C on the GPU core. With fresh ambient temperature (20°C or lower), it could be OK with the default fan curve…but while moving towards summer and hotter temperature, not really.
  • I started by playing with the GPU fan curve, trading GPU temperature for lower fan rpm. But even then fans were reaching ~1750 rpm for a GPU load of ~300W reaching GPU temperature of 73-75°C. Good start but can do better. On top, it is not solving the issue on idle fanless mode
  • I tried to overcharge the RTX 5080 by increasing the cold air intake flow from the bottom fans. However it proved to be way too loud. Even at 900rpm, resonances are appearing, making bottom fan noise very distracting.
  • I studied the “deshroud” option, but I didn’t select it as I would need some 3D print parts, in order to keep the GPU backplate. I’m also concerned about the longevity of the 3D printed solution, especially as I’m assembling/disassembling my setup pretty often. But this option inspired my final solution.
Akasa Fan Bracket AK-MX304-12BK
As a hybrid approach between the GPU “deshroud” and the overcharge of cold air intake flow, I positioned a fan bracket just below the RTX 5080. I was worried that this kind of bracket would be prone to vibrations, but, in the end, not at all!
The assembly is very straightforward. I was able to keep the rubber corners on one side but not at the junction of the 2 fans.
The bracket is held in place by using 2 PCIe extension slots
I appreciate the final look!
I will spare you different trials to fine tune the full system, here are fans curves
RTX 5080 Fan curve
CPU Cooler Fan curve
Note that I've limited the R7 9800X3D to 90°C and I've also limited the fan speed to 70% only.
Bottom Fans Curve
Bracket Fans Curve
Enough “blabla”, what are the results?!
Let’s test on Baldur’s Gate 3, the RTX 5080 is using ~330W constantly
  • Ambient temperature : 25°C
  • Bottom Fans rpm (intake) : 730
  • Bracket Fans rpm (overcharge) : 1369 (no turbulence, no vibration)
  • CPU Cooler Fan rpm (Exhaust) : 912
  • RTX 5080 Ventus :
    • Power consumption : ~330W
    • Core : 75-76°C
    • GDDR7 : 88°C
    • Fans Speed : 1512-1508
Conclusion
While the RTX 5080 is idling, its fanless mode is staying indefinitely in place as the bracket fans are providing fresh air at inaudible rpm of 500rpm. Also the bracket fans are also speeding up the fanless mode to be restored after a GPU load.
While the RTX 5080 is underload, the whole setup remains quiet, even with high GPU load (330W). The GPU core & GDDR7 temperatures are perfectly fine.
Overall, I’m once again surprised & delighted by my Cerberus-X as it allows association with very useful accessories! The fan bracket is overcharging in cool air the GPU but it is also directing the global case airflow towards the desired orientation!
MarcParis
3,792
2,946
Cerberus-X 2025 : R7 9800 X3D cooling study (07th June 2025)
I decided to spend more time investigating the cooling of my R7 9800X3D, especially as my beloved Noctua C14S is performing way better with my Intel Core i5 12600K (OC @170W).
For that I took the opportunity while testing Thermaltake (TT) TOUGHFAN EX14 Pro, with swappable blade.
I wanted to test a reverse fan for my C14S, as it is used as exhaust.
I also went back to push-pull setup on my C14S
Overall, it is working pretty well, either on pure CPU or combined CPU+GPU workload.
To help my trials, Fan Control Software is now compatible with newer AM5 boards! (I would say update between April-May 2025)
Hopefully, it was easy to deactivate Asus Fan XPert services (Armory crate made a lot of progress on installation pollution)
The best feature from Fan Control is to have combined fan curves. For example, I’ve one curve for CPU load and another for GPU load…so convenient.
As a reminder, here are the R7 9800X3D parameters :
AMD Ryzen 7 9800X3D (Max Temp 90°C), PBO Curve Shaper :
Basically I tested this setup with IBT 2.54 & Cinebench 2024 (Multi) with different fan speeds : 1000, 1500 & 2000rpm.
Here are the results :
  • Cinebench 2024
    • 2000 rpm
      • Score : 1340
      • Max Core Temperature : 90.8°C
      • Max Wattage : 137.78W
      • Noise : Unbearable!
    • 1500 rpm
      • Score : 1337
      • Max Core Temperature : 91.1°C
      • Max Wattage : 135.45W
      • Noise : Loud, but comparable as Noctua NFA14
    • 1000 rpm
      • Score : 1328
      • Max Wattage : 133.50W
      • Noise : Very Quiet
  • IBT 2.54
    • 2000 rpm
      • Score : 553.47
      • Max Core Temperature : 90.4°C
      • Max Wattage : 139.54W
      • CPU Clock during load : ~5180Mhz (Max is 5225MHz)
    • 1500 rpm
      • Score : 554.33
      • Max Core Temperature : 90.6°C
      • Max Wattage : 139.21W
      • CPU Clock during load : ~5150Mhz (Max is 5225MHz)
    • 1000 rpm
      • Score : 557.95
      • Max Wattage : 137.77W
      • CPU Clock during load : ~5070-5110Mhz (Max is 5225MHz)
Conclusion
  • Between a CPU fan speed of 1000rpm or 2000rpm there is barely any change of performance. This leads to thinking there is a heat transfer bottleneck before the aluminium fins.
  • Most probably this bottleneck is located between the chiplet die and its IHS.
  • Thus I decided to move my maximum CPU fan speed to 1000 rpm as it would be very quiet and would lead to no significant performance loss, either on the CPU or on GPU hot air exhaust!
Reactions: NinoPecorino
hrh_ginsterbusch
869
344
wp-devil.com
  • Cinebench 2024
    • 2000 rpm
      • Score : 1340
    • 1500 rpm
      • Score : 1337
    • 1000 rpm
      • Score : 1328
  • IBT 2.54
    • 2000 rpm
      • Score : 553.47
    • 1500 rpm
      • Score : 554.33
    • 1000 rpm
      • Score : 557.95
Conclusion
are you already using any kind of offset mount? that might improve the situation by 1 - 2 C.
Other option: Switch to Thermalright Silver soul 135. This little beast has kept my UNTAMED 7950X - yes, stock settings, stock fan curve, due to an accident during removing my GPU, that reset the BIOS - at 87 C (86.5 to be exact) under 100% all-core load. Original test results: https://smallformfactor.net/forum/threads/portable-workstation-k77-lite.19886/page-3#post-292489
I retested with different fans - Arctic P12 Max - but that didn't improve the thermals much (1 -2 C), and worsened the noise levels at high fan speed.
Still, 87 C with a much more power-hungry CPU is a decent number. Should keep the cute lil 9800X3D at even more reasonable temperatures.
MarcParis
3,792
2,946
Yes I'm using offset Noctua mount. On this kind of CPU ( 1 chiplet) and cooler (C14S), it is pretty doing nothing..:)
Based on this trial+other on my R9 7945HX, at the same TDP, it is way easier to cool 2 chiplets instead of 1 chiplet (less heat concentration).
I tried also tower style (NH-D12L) inside the Cerberus-X. It has similar cooling performance compared to the C14S. However global case airflow case is better with the C14S as it is exhausting GPU hot air in a more efficient way. Thus it is better suited to my use case (more GPU than CPU).
My only recent Thermalright cpu cooler is the AXP120-67 and I noticed their mounting mechanism is stronger/tighter compared to the Noctua. Maybe that's helping on temperature.
MarcParis
3,792
2,946
Cerberus-X 2025 : RTX 5090 FE, at last! (15th June 2025)
Lucky
Sometimes, improbable events could happen!
After months I decided to buy a RTX 5090. The only model available at MSRP was a pre-order of the RTX 5090 Ventus, 325mm long.
After checking the Cerberus-X would be physically compatible (in theory, up to 329mm) I confirmed my pre-order..was forecasted only 2 days later.
Note that we need to remove some screws and the front USB/power button to bend the front panel. Pretty simple & straight forward.
That’s when the improbable event occurred : a new drop of the RTX 5090 FE on the French official store! I won’t be far from the truth by stating it was the first since the launch, back to January!
One minute after the discord alert, the RTX 5090 FE was bought and the RTX 5090 Ventus order cancelled!
RTX 5090 FE, the beautiful card
The card is pretty heavy, especially versus my RTX 5080 Ventus. This is clearly an engineering prowess!
At first I noticed a small misadjustment on the top cover
But it is not generating any parasite noise whatever the case orientation, vertical or horizontal…so all is good!
Other than that, the card is working pretty well, no issue on PCIe bandwidth, missing ROP, burning connector or catastrophic coil whine.
However it is keeping similar issues as my former FE models (RTX 4080 FE or RTX 3090 FE) :
  • Minimum fan speed remains high at 1200rpm. This is audible in a quiet environment. Good improvement, there is no longer parasite noise related to air turbulence.
  • Fanless mode is long to occur at the system startup. It is difficult to identify the proper root cause (core frequency? power usage?) but it is happening a couple of minutes after the startup. Once activated, without any additional airflow, like my fan bracket is doing, the fanless mode is not lasting long.
  • Under load, coil whine is audible but reasonable, even at 575W. It is masked by fan noise at approx 1400rpm. It is also not audible while wearing a headset.
Inside the Cerberus-X
I like this subtle white lightning! The RTX 5090 FE sits very well inside the Cerberus-X. I wish to have more black fans… (it would happen)
I kept the Akasa Bracket with my dual Noctua NFA12x25, located at 20mm from the RTX 5090 FE. This is helping a lot to keep the fanless mode of the GPU active, pretty indefinitely!
Undervolting vs Overclocking
Let’s be honest & pragmatic, the RTX 5090 is generating a lot of heat, way more than the former consumer GPUs.
Undervolting the RTX 5090 FE remains an interesting option that I used with my former GTX 1080 Ti or RTX 3090…but not my RTX 4080 nor RTX 5080.
Undervolting is too specific…it would work with some applications but suddenly would fail with others.
I'm especially fed up with some “Youtubers” stating : “Yes I can fit a RTX 5090 FE inside a FormD T1, while losing no performance/thermals versus open test bench or bigger case”...this is total BS.
Personally I’ve spent a couple of hours testing undervolting on my RTX 5090 FE at 0.905mV…it was working fine for 3DMark, Clair Obscur…but suddenly failed for Stellar Blade, the new furnace, as it is pushing all GPUs to their max power…:)
Finally, the only advice I have is if you want to fit a RTX 5090 FE inside a tiny SFF case, just apply some power limit. Even at power limit at 69%, the RTX 5090 FE is only -15% slower while using 400W maximum instead of 575W. Even with this setup, the RTX 5090 is still faster than a RTX 4090.
Here is an example with the power limit set at 69%
Like my RTX 5080 Ventus, I decided to overclock my RTX 5090 FE, without increasing the power limit. It is a similar process as undervolting, as we are searching for the sweet spot.
I’m reaching +300Mhz on the core and +3000Mhz on the GDDR7 (use the same tweak as the RTX 5080). The only difference, that I also implemented on my RTX 5080, was to use the curve frequency/voltage to apply this overclocking. Basically I start the overclocking only after 825mV in order to help fanless mode activation. It is pretty effective on both RTX cards.
Depending on the load, this represents a +5%-7% improvement versus stock
A last word regarding the thermals & noise of the RTX 5090 FE within the Cerberus-X. After adjusting case fans speed - I needed more intake - the RTX 5090 FE is breathing very well inside the Cerberus-X, even at 575W.
Stellar Blade while fully overclocked
  • Core : 75°C Max
  • GDDR7 : 92°C Max
  • Fan Speed : 1640 rpm Max
  • Ambient Temperature : 28°C
Conclusion
Very simple
  • The RTX 5090 FE is a very good card, even though there are still some issues.
  • Stellar Blade is the furnace, pushing all the GPUs to their power/thermal limit!
  • Cerberus-X can host a RTX 5090 FE with no compromise on performance / thermals / noise
