VegetableStu
1,949
2,619
The inside walls from rear to from of the case are 330.17mm. Where does MSI measure their 325mm from?
hmm no indication from them though o_o although if they counted the PCIe tab we'd actually clear a little more? (by the length of that tab) o_o
'cause the PCIe screw mount is a protrusion outside the case
fabio
1,885
4,325
I know that I said I was going to snag the Aorus Xtreme, but I couldn't resist the X399 Taichi for $300.
The Aorus apart the lack of the U.2, it’s an amazing and nearly perfect board! Finally a proper finned heatsink like in the past!
VegetableStu
1,949
2,619
actually I thought of something:
@FoskcoRS5 did you mount your strix card before the waterblock went on (while it had the air cooler)? did it fit lengthways?
EDIT: nevermind, found one! sorry and thanks!
EDITx2: ahh crap I misread the asus page. it's actually shorter than the gaming X Trio ,_, haaaang on
FoskcoRS5
Designated LMG
Jan 31, 2017
363
623
It easily fits lengthwise, just not with any sort of radiator / 25mm fan on the front panel.
Reactions: VegetableStu
optimumtech
95
Glad to see the Cerberus & Cerberus X review was well received by more experienced SFF folk here! They really are super versatile and compact enclosures.
I currently have my video editing rig in the Cerberus and I love it to pieces. Super clean and minimal aesthetic, and I love the performance overhead of the mATX form factor over ITX for now.
If you are contemplating purchasing the Cerberus or Cerberus X, I hope this encourages you to pull the trigger. You definitely won't be disappointed. They're enclosures that will last a lifetime.
Lastly, a huge thanks to KSliger for the hook up, I'll hold these ones very close and include them in upcoming SFF content on the channel!
kageiit
40
24
Just bought a cerberus case today after watching @optimumtech 's excellent video (also thanks for the discount!). I was lurking a bit here on this thread and was considering going with @KSliger 's new G case initially, but after realizing that the 9900k would need much better cooling with a 280mm AIO for OC, decided to go with the cerberus instead.
Reactions: vseddie and KSliger
kageiit
40
24
Here is the build I am going with (purchased everything except the AIO)
CPU: Intel - Core i9-9900K 3.6GHz 8-Core Processor
CPU Cooler: Deepcool - Castle 280 RGB 96.7 CFM Liquid CPU Cooler
Motherboard: Asus - ROG STRIX Z390-I GAMING Mini ITX LGA1151 Motherboard
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3200 Memory
Storage: 2 X ADATA - XPG SX8200 960GB M.2-2280 Solid State Drive
Video Card: Gigabyte - GeForce RTX 2080 Ti 11GB GAMING OC Video Card
Power Supply: SeaSonic - FOCUS SGX 650W 80+ Gold Certified Fully-Modular SFX Power Supply
Case: Chimera Industries Cerberus
Still debating whether I should get the Deepcool - Castle 280 AIO (RGB looks quite nice on this one) or get an EVGA CLC 280 and use the noctua NF-A12x25 fans on it. Any suggestions?
Also, I got the Cerberus version with the top mounting bracket. Would it be possible to mount 2 X 120mm fans up top with the Asus Z390-I board?
Reactions: vseddie
MarcParis
Apr 1, 2016
3,678
2,799
Welcome to Cerberus owner club!
Regarding your setup, if you want the best cooling (in-line with 9900K), I suggest you go to smallest customed watercooling with combination of Swiftech Apogree Drivee II (cpu block, DDC pump) and radiator/reservoir MCR220-QP-RES-R2
That's the best cooling solution with dual NF A12-25 fans..:) (full DDC pump only spinning at 1200rpm, great cpu copper waterblock, copper radiator).
For the look you can play with tubing,liquid, etc...;)
Check my setup, I've this setup in place and it works like a charm in silence and efficiency.
If you want to stick on Asetek AIO like, well they are all based on same design : asetek pump (low pressure, high rpm and fragile), aluminium radiator...they perform almost the same with same fans...so pick-up what ever you prefer in look.
On top bracket, you can put slim fan (15mm) with no motherboard compatibility issues.
kageiit
40
24
Thanks for the tips! I have never done a custom watercooling loop before and would like to get started with an AIO as it is a bit more idiot proof for me :). Seems like your setup is great though! This is also my first sff build since my last one was in an NZXT Phantom tower (76L lol) and I would like to make the transition as smooth as possible :p
The Deepcool AIO is not using an asetek pump, which is also why it cannot be purchased in the USA, but Im making a work trip to europe in a couple of weeks and was hoping to make a decision whether to pick it up or not. Good to know that 15mm fans fit without any issues as well. I may wait till I can put the motherboard in the case to see if I can fit 25mm fans, otherwise will go with 15mm.
fabio
1,885
4,325
Even this should work!! and with an ATX PSU! Never seen it!
http://www.swiftech.com/MCR-X20-Drive-Rev3.aspx
