CantingSoup
190
100
Simple :
  • 120mm : Dark Side Gentle Typhoon 2150rpm or Noctua NF A12-25 or Vardar evo 2000rpm (but lower quality and tends to be noisier)
  • 140mm : competition is low. Vardar is a choice by absence of true competition.
Thanks. Now to plan the loop and figure out how many fittings I’ll need.
fabio
1,885
4,325
Great build @fabio !
By definition your build is a true challenge to cool..;)
Black ICE GTS are best "slim" radiator for performance but they required a good washing and also high pressure fans (ie fans running at higher rpm)
I'm curious to see your setup with full exhaust setup.
You Know what I am thinking now? I will try next time/months, to swap the front 240 radiator with a 120, adding a 140mm fan in front of the GPU, and keeping exhaust the bottom radiator fans. Maybe I've found the sweet spot? BTW, I am trying to stay on AIR with the GPU for the easy task to swap/remove/change them! At the end is a workstation!
OFF TOPIC: Some one knows an aterlier or someone else in EUROPE that can od a job of mechanic precision? I want to CUT 4cm at the Heatkillers Tube, and re-thread the 4 aluminum bars. With the right tool and precision is an 30 minutes job, but I cannot find anyone in Brussels. That reservoir combo are amazing that I would love to have in my setup!
fabio
1,885
4,325
fabio
1,885
4,325
Will I need to buy anything else with the bitspower ddc, or is it a standalone plug and play?
Hold on: You need to buy:
https://shop.bitspower.com/index.php?route=product/product&path=65_83&product_id=3533
https://shop.bitspower.com/index.php?route=product/product&path=63_72&product_id=2651
https://shop.bitspower.com/index.php?route=product/product&path=63_78&product_id=5250
Of course as said before, you can use the EK DDC Pump 3.25 PMW as well, and the EK heatsink. The EK decoupling feet are working as well with the bitspower DDC Mini Tank.
CantingSoup
190
100
Nice! Got those three in the shipping cart. Thanks for your help and patience.
fabio
1,885
4,325
If you want to have the inlet from the top, you should get as well this, so you have a free fill port:
https://shop.bitspower.com/index.php?route=product/product&path=323&product_id=3499
And I suggest to buy as well these to mount it vertically, otherwise you need to find another way to do it.
https://www.ekwb.com/shop/ek-ddc-anti-vibration-mounting
https://www.ekwb.com/shop/ek-uni-pump-bracket-120mm-fan-vertical
CantingSoup
190
100
Added. All of this will establish the drain port as well?
fabio
1,885
4,325
The drain is something that you want to have at the bottom of your loop. I've put mine just above the bottom radiator. But There ara many options, depending from your loop!
CantingSoup
190
100
Do you think that 12 regular fittings with 4 angled fittings would be enough? I’m not gonna do anything too fancy.
MarcParis
Apr 1, 2016
3,833
2,995
Cooling multi gpu like is always an headache to be honest.
Try first to put a slim fan on side if it's cooling down gpu temp.;)
CantingSoup
190
100
Form Me 1 meters is enough, but take 2 to be sure
The pack I’m looking at has 3 meters. I’ve been able to find everything in red other than the angled fittings.
Edit:
My proposed parts list is:
https://www.google.com/amp/s/m.aliexpress.com/item/32712676032.html#ampf=undefined
Barrow 3/8"X5/8" 10mm(ID) X 16mm(OD) Soft Tubing Pipe Compression Fittings With G1/4" Thread Red (16)
https://www.performance-pcs.com/pri...tubing-3-8in-id-x-5-8in-od-bloodshed-red.html
PrimoFlex Advanced LRT 10ft Tubing - 3/8in. ID X 5/8in. OD - Bloodshed Red (1)
Bitspower DDC 3.2 Pump PWM
Black Ice GTS 240 Radiator in red (2)
DDC Mini Water Tank Ultra
Z-CAP III With G1/4" x2 (POM Version)
Bitspower Pump Cooler For DDC/MCP355 (Black)
EK-DDC Anti-Vibration Mounting
EK-UNI Pump Bracket (120mm FAN) Vertica
Heatkiller IV PRO TR4 waterblock
How does the list look so far?
Windfall
2,117
1,584
A small update, while preparing the first build log (I want to change few things, but I need to wait for example that noctua release the black chromax version of the slim fan)
The temp are under stress test and with all the panels on, no overclock: overclocking all core at 4.5ghz, the CPU temp goes at 85/90 degree.
The top Titan V run 5 degree higher, and I don't know if is better to watercool them. But I will use them for GPU rendering and CUDA job, so I don't know if is worth it.
The top Quadro is temporary (after I will put it in my small Dan Case system): I will wait november to evaluate if It will have sense to have a Quadro RTX 5000 to run Adobe Suite, Rhinoceros, Autocad and 3Ds Max, or buying a third Titan V to have more rough power.
The bottom fan are installed as intake, but as suggested by @MarcParis I think will be better as exhaust, because the GPU are heating a lot the air.
Soon a full build log!
PS: I've tried to switch off the Intel SSD Led, but even with the Intel support, seems that something doesn't work with the command line tool.
Enjoy the preview!
You think people will be impressed by that??
Hold my beer.
Wait. I can't even afford a beer, much less that much hardware. XD
But seriously, that is a beautiful build. Good job!
