Necere
3,300
Excluding feet is fine IMO. I guess the main point of contention I had was over not counting the front panel on the X.
What's going on with the 163 vs 172mm width BTW?
Reactions: Arie
KSliger
855
3,186
Looked up / figured out what I did for volume on the X, does not include:
1. Front panel.
Not a usable plenum of the case, there's no cutouts to mount anything substantial between it and front of the chassis. Strictly for airflow and USB/ power switch.If it was designed to mount anything back there, it should count.
2. Thicker gauge of the panel material.
Since we upped to 2mm aluminum from .915mm steel, this was measured to ID of panels. Dimensions I calculated from do includes the panel float in the ball studs.
3. Non-enclosing flanges.
Side/top panel overhang on rear/bottom for prying panels on/off, flange on front for the USB/power switch, and card mount tab are not counted.
4. Feet.
Bothers me because Cerberus X could be under 19.6L without changing anything about the functionality, layout, and component compatibility by simply reducing the box to a unaesthetic rectangular box made of thin sheet, with all build-friendly features eliminated.
Also not sure I like establishing a hard SFF cutoff at 20L. I think it is poorly defined as well, particularly with cases that use external power bricks and external GPUs.
If your DC adapter is as big as an SFX power supply - why should this give you a smaller volume?
S4M is certainly SFF, but should a 19.99L Mini-ITX case with an eGPU and 2x 330W DC adapters be an SFF case?
Should a 23.4L EATX quad-SLI case with an ATX power supply not be SFF?
The intention, design, and compactness of internals of the case should matter more than volume if we're going to disqualify cases.
I don't think either the Ophion or QBX should qualify as SFF honestly, they're absolute units for what little goes in them, but they are <20L.
I'm going to leave it at 19.6L until something is established, because it is by all purposes of the loosely defined standards of "non-enclosing flanges and excludes feet" the case is 19.6L and is SFF.
@Necere I agree, internal volume is just 'cheating'/ misleading. I'm also a fan of measurements declared excluding what they exclude. If someone is selling a case with a volume measurement excluding feet, declare it :) IIRC Bitfenix tried to market "Internal Volume" when they launched the Prodigy.
Can you move this discussion?
I think it's a good topic that needs to be covered and fleshed out before accusations of cheating are levied, particularly when there are such loose and/or poorly defined rules.
VegetableStu
1,949
2,619
oh @QuantumBraced check this out, I think you might be in luck. inner dimensions says it's 330.17mm, not 329mm
Ankacat
41
107
1. Front panel.
If the front panel in the Cerberus X has the same amount of space under it as does in the Cerberus, I'll have to disagree with this space being unusable. My Cerberus is still hosting a working optical drive up there and another possible use for that space could be for additional ports facing sideways in some Frankenstein-ish mount system; going without the SFX front mount opens up more of the cable cutout to the interior.
TheHig
951
1,171
Cincinnati, Ohio
Not a problem, fair to enforce common metrics.
Cerberus volume was calculated based on volume of the case to the OD of each face, excluding the feet.
The dimensions listed include the feet, but the volume calculation does not.
Cerberus internal dimensions would result in a volume of 16.22L.
Felt measuring OD without feet was a fair comparison to something like the Cyorig Taku or DSE Vertex case would be oversized based on its supporting base, or just in general to cases that use tiny feet because their airflow does not require a bottom intake.
However you're correct on Cerberus X, should be 22.4L when measured to OD less feet for volume.
I will correct some of the explanation on the pages for the dimensions and update them when I can.
Personally I like seeing both hard internal dimensions AND external dimensions listed.
One shows how much I have to work with component wise and the other shows how much space it will occupy once built.
What is and isn’t SFF is a great debate that rages on. Post the specs as accurately as possible and let the world decide if it’s SFF enough. :cool:
PS. The Prodigy is and was a SFF abomination... for instance. Lol
Reactions: Ankacat
KSliger
855
3,186
@KSliger Any updates on NewEgg carrying the case? We're in the end of the second week of October now and I don't see any listing?
We have to delay a bit, we ran out of handles due to a backlog of machining work. Will have handles in 2nd or 3rd week of November. Our shop and everyone in town is booked out 4+ months. Site will be updated shortly to advise the delay.
fabio
1,885
4,325
A small update, while preparing the first build log (I want to change few things, but I need to wait for example that noctua release the black chromax version of the slim fan)
The temp are under stress test and with all the panels on, no overclock: overclocking all core at 4.5ghz, the CPU temp goes at 85/90 degree.
The top Titan V run 5 degree higher, and I don't know if is better to watercool them. But I will use them for GPU rendering and CUDA job, so I don't know if is worth it.
The top Quadro is temporary (after I will put it in my small Dan Case system): I will wait november to evaluate if It will have sense to have a Quadro RTX 5000 to run Adobe Suite, Rhinoceros, Autocad and 3Ds Max, or buying a third Titan V to have more rough power.
The bottom fan are installed as intake, but as suggested by @MarcParis I think will be better as exhaust, because the GPU are heating a lot the air.
Soon a full build log!
PS: I've tried to switch off the Intel SSD Led, but even with the Intel support, seems that something doesn't work with the command line tool.
Enjoy the preview!
CantingSoup
190
100
Ok, just made a quick IMG to understand... Which one will you suggest of the following configuration, based on your experience?
While installing my ATX psu, I realized that my AIO tubes were extremely difficult to bend. With that being said, I have decided to go for a custom loop (setup #2) for my next build.
My questions are:
What are the best slim radiators to use (Black Ice)?
Can I do front 280 (push) + bottom 280 (push), or does it have to be bottom 240 (push)?
Is the Heatkiller Tube 100 D5 the best pump+res combo to use in this case?
Where is the best place to mount a fill and drain port?
What does it mean when it says fan inside/outside?
fabio
1,885
4,325
In bold my answer:
My questions are:
Or the Black Ice GTS, or the new XSPC TX are just 20.5mm
I suggest to stay with both 240, it will be easier for the cables behind the front one, but of course depends which MB you will use, ecc.
Depends, where you will mount it? How many GPU you will have? After this answer, I can suggest you few things.
Fill from top of the reservoir for me, and drain in the bottom (check my build just posted)
I mean with the fan facing the CPU (INSIDE) or the fan facing the exterior/side panel (OUTSIDE)
CantingSoup
190
100
In bold my answer:
My questions are:
I will mount it in the back from where the internal SFX psu used to be. I will have 2 GPUs for the loop. I was thinking of using the X399 Aorus Xtreme for this, but I could drop down to an ATX MB if makes things easier.
fabio
1,885
4,325
So, If you mount the GPU in the 1st and 3rd x16 slot, there's not enough space to mount a D5 combo where do you want to mount it, apart going with a Swiftech Maelstrom 50 and the XSPC TX slim and a slim fan, otherwise the fittings will go against the PSU. I couldn't mount it because I have one SSD on the side bracket, so I had no space in between that and the ram. You should at a DDC combo, there are 3/4 options that fits! (DDC tank of Hetakillers, Tank Plus of bitspower, EK DDC 100, I think also the Alphacool Eisdecke reservoir DDC...)
And take a low profile ram, like the Corsair LPX. The G.Skill Trident Z in my case were going against the EK combo.
CantingSoup
190
100
Are these the ones you're talking about?
http://www.performance-pcs.com/bitspower-bp-ddct2-cl-ddc-mini-water-tank-plus.html
http://www.performance-pcs.com/watercool-ddc-tank-lt.html#Details
http://www.performance-pcs.com/watercool-ddc-tank-pro.html#Details
http://www.performance-pcs.com/watercool-ddc-tank.html#Details
I've also found some Corsair Vengeance LPX 4x8GB 4000MHz Samsung B-die ram and these radiators:
http://www.performance-pcs.com/blac...-stealth-u-flow-low-profile-radiator-red.html
KSliger
855
3,186
Enjoy the preview!
Look forward to the build log, beautiful work!
Speaking of builds accidentally found this video on YouTube - which one of you is this? Nice work.
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
In bold my answer:
My questions are:
Great build @fabio !
By definition your build is a true challenge to cool..;)
Black ICE GTS are best "slim" radiator for performance but they required a good washing and also high pressure fans (ie fans running at higher rpm)
I'm curious to see your setup with full exhaust setup.
CantingSoup
190
100
I like the red radiators so I go with red barrow fittings to match. Which high pressure fans would you suggest?
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
Simple :
  • 120mm : Dark Side Gentle Typhoon 2150rpm or Noctua NF A12-25 or Vardar evo 2000rpm (but lower quality and tends to be noisier)
  • 140mm : competition is low. Vardar is a choice by absence of true competition.
CantingSoup
190
100
Simple :
Thanks. Now to plan the loop and figure out how many fittings I’ll need.
fabio
1,885
4,325
You Know what I am thinking now? I will try next time/months, to swap the front 240 radiator with a 120, adding a 140mm fan in front of the GPU, and keeping exhaust the bottom radiator fans. Maybe I've found the sweet spot? BTW, I am trying to stay on AIR with the GPU for the easy task to swap/remove/change them! At the end is a workstation!
OFF TOPIC: Some one knows an aterlier or someone else in EUROPE that can od a job of mechanic precision? I want to CUT 4cm at the Heatkillers Tube, and re-thread the 4 aluminum bars. With the right tool and precision is an 30 minutes job, but I cannot find anyone in Brussels. That reservoir combo are amazing that I would love to have in my setup!
fabio
1,885
4,325
