well i just see in the sliger page:
But i dont know if i can fit 1080ti aourus(149,27mm) without problems
Confirming the card will fit on air cooling, I would check with @remiscs or EKWB themselves for recommendations on water blocks.
my aourus has waterblock, 149,27mm is with the block on itConfirming the card will fit on air cooling, I would check with @remiscs or EKWB themselves for recommendations on water blocks.
That side panel was discontinued 30 pages back.@KSliger Whatever happened to the side panel that was half vent holes and half window?
Could I also make a custom order for 1x side panel to have vent holes on the whole side panel for the Cerberus X? Current available order only allows for vent holes on half of the side panel.
Measurements shows that it can fit a fan in the unused space between the Side Panel and the GPU. I can use the vent holes themselves as mounting holes. This allows for better GPU cooling.
Vented Window Panels to be discontinued 6/30/18 for both Cerberus and Cerberus X. (or when stock runs out)
$20 off orders with Vented Windows.
Just check out on website and reply to the order confirmation. We will issue a refund for $50 which gets you a brand new Cerberus for $160~$175 + S&H.
For those concerned about new the future of Cerberus, there are no plans to discontinue Cerberus or Cerberus X.
There however will be new parts and options coming on 7/1 to freshen the line-up including full side window and a double 120mm fan bracket for the top of case.
www.sliger.com/products/cases/cerberus_x/
www.sliger.com/products/cases/cerberus/
As always, PM me for anything questions or help!
if it's from the bottom of the PCIe teeth to the absolute top of the card, it should fit inside I thinkmy aourus has waterblock, 149,27mm is with the block on it
Basically if your aorus GTX1080ti is this one :if it's from the bottom of the PCIe teeth to the absolute top of the card, it should fit inside I think
is it the AORUS Waterforce GPU? that's default height on the GPU side, but if (on the tiny chance) the inlet block part is interfering you miiiiight be able to change just that part (might want to check though)
it barely fit the eATX Asus X99-WS o_o that's definitely out of the question (i think)does the Cerberus X support SSI CEB boards?
Anyone know if the Enermax coolers ever got fixed? I’m floatin’ ideas around a Threadripper build.
don't get Gen 1. Gen 2 may have issues with the fans themselves (at least the few on newegg seems to be bringing that up), so unless you'd want to RMA the entire set when it actually happens or if you already have other fans you'd be using...
Enermax USA Support said:We are fully aware of the leaking issue and have stopped selling our 1st gen TR4 cooler as well as the first batch TR4 II.
The revised TR4 II coolers have fixed the problem and are arriving to our warehouse bi-weekly by air shipments since early September.
We have reserved some units just for RMA so if you are still having problems with the 1st gen Liqtech TR4 or the early production of Liqtech TR4 II, we are more than happy to replace it with the newest version.
It can be done by filing an RMA request on our website, https://www.enermaxusa.com/support.php
Feel free to PM or reply to this post for any questions. We are here to help
- Enermax USA Support Team
EDIT: yeah definitely not. VRM row is outside the ATX border on the top.
EDITx2:
okay for "normal" boards, you miiiiiight be able to squeeze a CEB board in if it's shorter in width than 329mm. definitely check ATX motherboard mounting points since the far end is usually different
Also you'd lose the SSD mounting points and maybe even the front PSU mounting point (since it might interfere with any ATX 24-pin under it
Dimensions (HxWxD)
Volume
- 12.57" x 6.78" x 14.09"
- 319mm x 172mm x 358mm
- 18.725 Liters
Case Dimensions (HxWxD)
Volume
- 14.97" x 6.78" x 14.09" (counting feet and side panels)
- 380mm x 172mm x 358mm
- 14.17" x 6.44" x 12.99" (inside dimension)
- 359.92mm x 163.67mm x 330.17mm
- 19.43 Liters
@KSliger I hate to be the specs police, but by god it still annoys me every time I see it: the volume for both the Cerberus and Cerberus X as listed on your site are less than they should be.
Cerberus:
The dimensions given for the Cerberus result in a volume of 19.6L, rather than the 18.725L listed.
Cerberus X:
For the Cerberus X, the first set of dimensions comes to 23.4L. The second set does result in the listed volume of 19.4L, but IMO it's quite misleading to use the inside volume, as no one else measures it this way. It's pretty clear also that this excludes the front panel, which itself encloses some space that should be counted. As a point of comparison, if I measured the M1 the same way it would only be 11.4L, rather than 12.6L (though this excludes the feet and non-enclosing panel extensions, which I think is a fair way to measure).
@Necere I agree, internal volume is just 'cheating'/ misleading. I'm also a fan of measurements declared excluding what they exclude. If someone is selling a case with a volume measurement excluding feet, declare itIIRC Bitfenix tried to market "Internal Volume" when they launched the Prodigy.
