Ionplasma
Jun 23, 2018
I'm looking to downsize my current build and Cerberus X seems to fits the bill.
Got a couple questions though:
I plan on using the ATX PSU mount, will I be able to mount a 120mm fan at the top with this setup?
I like the look of the unvented side panel but I'm not sure how it will affect thermals with an ATX PSU and open air GPU cooler. Which should I get? Guess it would depend on if I can use a fan on the top.
kecoal2
31
okay I did an ATX Power Supply mount in the front. Here is what I have found.
ATX Front Mounted:
1. The Power Supply sits ever so slightly on the edge of the motherboard leaving a channel right beneath it to possibly mount a ssd or run wires through.
2. Getting the power supply to sit further up is a challenge to make sure you push the front IO cables to the top so they don't get crushed.The further you push them up or get thinner USB cables the clearance you have to push the power supply up higher.
3. I have a standard length GTX 1080 FTW 2 ICX card. Since I have the standard length the only clearance issue with modular PSU stuff is where the cables come out. If your big 24pin connector cable is closest to the GPU it is going to harder. I was able to get around it by spreading the cables out flatter from my PSU, which gave me the clearance I needed for the GPU.
4. There is a possibility of GPU Sag/pressure from the PSU cables. If you cable manage really well there won't be any sag. Little to no sag really.
5. Securing the Power supply was easy in my scenario. I have zip the grill of the PSU facing the front so it's pulling fresh air in. All I did is loop zip ties through to keep it in place. 4 Zip ties and it was fine.
6. Cable Management: I used the space beneath the GPU/PSU to put my 2.5 inch drives + the rest of my cables. bundled. I bet if you work hard enough you can easily have a 140mm or 120mm there if you don't bind your cables to the front mesh of the case.
7. This is a super tight fit, but it seriously allows you to put most of your standard ATX components. To be honest, I think this is the ideal setup since you can put hard drives in the area where the PSU is being cable managed and then have the entire bottom be fresh intake. Let the CPU cooler draw in fresh air from the back side. and natural exhaust to the top.
Overall after spending 2 hours cable managing that area I was actually able to do it. I have a noctua dh15 stuck in there since I don't have a compatible cooler at the moment.
Here are pictures, @KSliger, can we make a mounting bracket for this?
KerBlitz Kerman
Jun 25, 2018
I have a small question about paint jobs.
I know Sliger offers powder coating. I would like to know you guys would offer 'special editions' or a Cerberus (X) with custom panel designs.
For example maybe blued (blueing is an process for tempering steel to protect it from rust it corrosion) steel panels.
Here are some examples of blued steel:
Yeah. Pretty :cool:.
Not 'ew steel'
KSliger
Sliger Designs
May 8, 2015
855
3,186
Not 'ew steel'
We can do custom powder coat colors but doing that would require making the panels out of cold rolled steel, but anything is possible although may be costly. I've wanted to do steel panels for a while, PM me and maybe we can work something out.
Reactions: VegetableStu
Johnny0971
24
37
For those of you who consider getting this case or just like Noctua fans, this post is for you.
I did this build in december and I love the Cerberus X case, it is as close to perfection in a case that I have ever got.
Rough specs are Threadripper 1950X, a Sapphire RX Vega 64 Nitro+, a 3,5' HDD, and some other good stuff, CPU is cooled by Enermax TR4 240 AIO.
I have been using the Noctua iPPC NF-F12 fans from the start as an upgrade from the AIO stock fans, and also two additional in the front, a total of 4 120mm fans.
The system has been close to perfect, the only caveat being the noise levels generated by the iPPC fans. I have tried the regular NF-F12 fans but they did not move enough air to cool the components.
When Noctua released the new Noctua NF-A12x25 fans I got really excited, of course I had to try them out.
They finally arrived today and I got to install them, the difference is night and day. They are completely silent, the iPPC are not comparable, even with same RPM.
Funny thing is, the temperatures are equal or just slightly higher during stress testing, despite the new fans running at lower RPM and maximum being 2000 RPM, I used to run the iPPC fans at 2400-2700 RPM during heavy load.
I can wholeheartedly recommend these fans for anyone who is considering them, the color scheme is funky ( I like it ) but if you can look past that you get amazing airflow and very low noise levels.
Sancus
44
92
Yeah I bought 3xML120s for my build(best performing 120mm radiator fans at the time) and now I'm seriously considering replacing them with the Noctua NF-A12x25s because of how much quieter reviews have been indicating they are at a given rpm.
fabio
1,885
4,325
Amazing job man! I am waiting for the new Threadripper and MB to finish and close this amazing case and test the noctuas!
One question, where did you find the dust filter? The bottom one seems perfectly fitted!
Thanks for your reply!
GucksTV
254
512
www.youtube.com
Hey guys! :)
Considering to get the mATX Cerberus for my personal setup with the MSI X299M Gaming Pro Carbon + i7-7820X...this system will be equipped with the upcoming GTX 1180 (whatever it’ll be called) so I am not in a hurry. The plan would be to get a custom loop inside as EKWB released this week a Monoblock for my board and I moved from my previous In Win 301 to a open testbench for a Z390 + i9-9900K comparison.
So I am willing to wait for the updated revision with a dual 120mm mount at the top. The PSU would be the new Corsair SF600 Platinum over the mobo layout. As I am considering a CPU + GPU loop:
Can I fit two 240mm radiators in the front & bottom? What’s the maximum thickness when each radiator is equipped with two 120mm fans (guess I will go for pull to dissipate the heat through the chassi when the radiators are mounted to the frame. Is there any reason to go for push?) EK-CoolStream SE thickness: 28mm
Oh and is it possible to mount a Corsair H115i Pro RGB (280mm) in the front? 315mm x 143mm x 29mm
Kind regards from Germany!
Reactions: KSliger
fabio
1,885
4,325
EDIT: FOUND THEM ON THE FIRST PAGE, JUST ADDED 6CM TO THE FRONT ONE. :cool:
Hi guys, do you know where I can find the SKP model of the Cerberus-X or some pages with dimensions? I need the front and bottom with the holes, to order a custom made dust filter.
Thanks a lot!
kecoal2
31
Dude how are you able to close the side panel with an nh-d15?
I did not close the panel :p. My Cerberus is still half open. I ordered a Scythe Fuma Rev B that I will use with triple fans.
Hey guys! :)
I believe with ATX Power Supplies I can fit about < 35mm clearance. It says so on sliger's website. Please be careful you need to make your tubes can clear the space. They need to be right outside of PSU or have right angle nozzles like some of the corsairs. (I haven't switched to an AIO so I am going to stick with the current configuration I am doing) The enermax TR4 coolers fit and they will be coming out with the same version for all sockets.
Johnny0971
24
37
Yeah, I can really recommend these fans, so silent and moves a huge amount of air, it is crazy how good they are. I'm very surprised actually, I had the Noctua iPPC before so I did not expect them to keep roughly the same temperature, but they do.
The filters I'm using are from http://www.demcifilter.com/ , in the front I have two Ncase M1 120mm filters, https://www.demcifilter.com/demcifl...for-ncase-m1-120mm-square-2-pack-dust-filters ,and in bottom I have one originally made for Ncase M1, https://www.demcifilter.com/demciflex-magnetic-dust-filter-for-ncase-m1-v2-bottom-dust-filter .
Good luck!
Reactions: fabio
Cortsar
Its been a while since I received my Cerberus. I wanted to post pictures but it looked like garbo given how little prepared I was for such a small case. Here is my PC from beginning to end. Ended up doing my own sleeving since very few places offered such short cables. After a lot of burning and learning, it is done.
For context, the picture with my computer guts out was with the stock cables. I couldnt fit the liquid cooler on the front of the case which was the plan so I could fit a second 1080 in the future. Made my own cables and was able have plenty of space for an extra gpu and even another fan in the front if needed.
fabio
1,885
4,325
Good luck!
Thanks a lot! Ordered!
I have one question fot @KSliger, becasue my USB 3 cable arrived in blue, could you suggest one website where I can looking for a black one, of different sizes? Thanks a lot!
yosvos
Hey guys,
I have decided to overclock my i7 7820x using my current cooler Noctua c14s with x2 EK vader 2000 rpm fans running in push pull.
This set up is not cutting it for me.
I am thinking about moving to a bottom mounted AIO. Which 280mm or 240mm AIOs have been confirmed to fit in the bottom of the Cerberus X case?
I am using the Asus tuf mark 1 x299 motherboard if that matters to any of you.
Thanks in advance!
TheHig
951
1,171
Here are a couple of build shots of the Corsair H100i V2 working in mine with an AM4 Taichi. Currently back to an x58 Sabertooth for some Xeon OC fun with the same AIO and Cerberus X.
Other than height and board size support the Cerberus and X are the same.
The fans will cover some of the bottom part of your board so the case power, led, and possibly usb headers will need connected before you mount the AIO rad. You may lose an expansion slot as well due to this.
Cheers!
MarcParis
Apr 1, 2016
3,836
2,998
Good luck!
Please, please, never say that ML120 fan was ever the best 120mm fan on radiator...please never say that...as it never was.
ML120 fan have very loud motor and quite uneffective blade shape for radiator.
For radiator :
  • king of all 120mm fans is still Gentle typhoon (either Scythe or dark side)...even at 2150rpm this gentle typhoon is making far less noise than most fan at 1200rpm...not even mentionning its blade shape, oriented on air pressure...this fan was first released around 2007.
  • prince is EK Vardar. louder than gentle typhoon but sharing similar cooling efficiency on radiator
I have high hopes on Noctua A12x25 to be the 2018 version of gentle typhoon as they shared a very similar design & features.
However, what is strange, is that I didn't see any strong Nocta A12x25 review yet...especially comparing it versus its best/worst competitor...Gentle typhoon (or even vs Vardar).
Optimum tech made a good video for A12x25 as case fan.( let's wait for the second video dedicated to radiator fan)
