simple : to free maximum space for long gpu..![]()
I had an absolute HELL of a time getting my IO plate to stay put. But I eventually did it. I think the case walls might be too thick for most of the little pokey bits on the shield to through and hold it in place.Me too, i was unable to fix my i/o shield. However, on my crosshair vi hero, i/o shield is pretty thick...i don’t really know who’s fault it was..![]()
Any chance you could make the front grill 12-13mm wider to fit a standard 25mm fan in that area? It's the only thing that's holding me back from buying.
Make that happen and I'd buy this in a heartbeat over the SMA8-A that I'll be ordering tomorrow morning.
Why do you want 25mm fan on external front side?Any chance you could make the front grill 12-13mm wider to fit a standard 25mm fan in that area? It's the only thing that's holding me back from buying.
that's completely doable this one..Personally if I was going to ask for something for the future it would be an updated top panel with at least 1 USB-C port.
that's completely doable this one..![]()
mostly assemble and ship at this stage? @KSligerMight start a build in this case because it looks so sleek! Is there a hefty wait time in order to get it?
You can put a 30mm thick radiator + 25mm fan on the interior if you choose a reference/fe gpu (26.67cm +5.5cm=32.17...that fits inside 32.9cm depth of cerberus)
Nice build @dreix ! I'm happy of your happiness while building in Cerberus..
You are right about 400mm tubing of Celsius s24 AIO...I noticed that also with my customed swiftech AIO. For front radiator, you need really shorter tubes..
For airflow, it should not be that bad as you have both PSU and a "small" 140mm fan on above MB.
Is Celsius S24 pump noisy?
