VegetableStu
1,949
2,619
That's not a bad suggestion. I'll try both and measure temps. Do you think the fans on the radiator should suck air in or push air out from the front? The GPUs draw air from the front and exhaust out the rear.
I say suck it inward, because the GPUs are all pushing the air out of the case on the IO side. Don't wanna make a tug-o-war vacuum locally at the air impellers. It might heat up the GPUs at load, but I'd guess blowing warm air at them is safer than starving them of air.
although with the vents above the case I'm not sure if outside air would passively fill and feed into the GPU fans with the low-pressure area. most definitely needs testing
jsco
60
55
huh, this is a tough one. ordinarily i would say intake is a bad idea here since it's dumping warm air on the GPU intakes, but with those stacked blowers, you really just want as much positive pressure as you can get. the temp gain from the radiator will only be a couple of degrees, max. i would add a pair of 140mm fans on the bottom of the case as intakes as well. (i plan to use something like the phanteks PH-F140HP with 120mm mounting holes on the bottom.)
if you do go this route (lots of fans blowing on the GPUs), i'll be curious to see what effect flipping the panel perforations around has on GPU temps. my experience with tightly packed, air-cooled GPUs has been that side ventilation helps a ton, but then again i've only ever done it with aftermarket-style coolers and those are a totally different game.
MarcParis
Apr 1, 2016
3,835
2,997
Yes he needs to try both configurations...:)
charlesdab
Hi All-
Looking for some follow up information:
1. There are two cables that go to the power button. One is white-and-black the other is red-and-black. Which does what?
2. What is the quantity of all screws that ship with the unit? What are they for?
3. Are there recommendations for types of filters and where/how to attach them?
FoskcoRS5
Designated LMG
Jan 31, 2017
363
623
Hi All-
1. I'll have a better answer on this when I get home, I believe white and black is LED and red and black is power button.
2. I don't remember the exact number for the screws, it will depend on the options you choose, they are primarily for the SFX bracket, hardware brackets. In the prototype unit here is what I received:
3. I used some "okay"™ 120mm filters from amazon for my front intake. More research needs to be done here.
charlesdab
Thanks for this information.
I tried connected the cables per your suggestion and it didn't work for me. The backlight on the power button was illuminated dimly but no joy. Reversed the cables and the power button functions but not the LED.
Is the LED cable supposed to be for PWR LED or HDD LED? On my MoBo the PWR LED pins are not coupled so maybe I need an adapter?
FoskcoRS5
Designated LMG
Jan 31, 2017
363
623
I'm at work and I don't have a clear enough picture. I think I put mine for the HDD LED. I recall the LED flashing with disk usage. I'll take a pic when I get home in a few hours.
Qrash
198
152
The red wire should be +3.0 V for the LED. It's your choice if you connect it to the Power LED or HDD LED pins on your motherboard. Most motherboards have the LED positive and ground pins beside each other. What motherboard do you have?
Edit: Oops. Changed "+ve" to "positive" and "-ve" to "ground", as it should have been.
3lfk1ng
919
1,718
www.reihengaming.com
Thanks!
It's super quiet (w/ modified fan speed profile in bios) at idle and load. I cannot stand noise, which is why I usually do 100% H2O loops.
The CPU idles at 32c and hits max temp of 56c when gaming, 64c under stress.
GPU floats between 69/70c at max usage.
FoskcoRS5
Designated LMG
Jan 31, 2017
363
623
Here is exactly how I have mine set up, please excuse potato:
Red/Black on HDD, Black/White on PWR. If you super zoom with a microscope you can see where it says HDD and PWR.
