Thus you can start watercooling without front panel.For multiple reasons:
1. 25mm fans are superior in every way to their thin counterparts, especially for radiators
2. Mounting fans on the front would open up the possibility of a custom reservoir (radikult reservoir) to the front radiator
3. It doesn't feel right to do a push pull setup with 15mm fans on front and 25mm fans on back.
4. Because, to be perfectly frank, it should've been designed this way to begin with.
For someone that talks about fans so much, you of all people should understand why someone would want 25mm fans over slim fans.
Might start a build in this case because it looks so sleek! Is there a hefty wait time in order to get it?
if you put SFX / SFX-L PSU on the back (like I did) + want to use AIO be prepared to bend the tubes on the pump - might be solved with AIO that has fittings on the side instead on the top ... With normal PSU it would be impossible for me to bend it because there would be literally no space.
Hello,
so, my build is finished, yay!
Images attached bellow, hope you like it as I do
Might help someone who is about to build or even purchase new HW:
+ BONUS - my wife took a picture of me mounting the motherboard (and decided to include Vault Boy as well). She said I had this face expression the whole time of the assembly
- you can fit 240mm AIO on the bottom and not in the front - with 40cm long tubes it was impossible to twist it comfortably (with respect to other HW)
- if you put SFX / SFX-L PSU on the back (like I did) + want to use AIO be prepared to bend the tubes on the pump - might be solved with AIO that has fittings on the side instead on the top. Even though mine has quite robust (but flexible!) tubes, it is quite a bend between pump and PSU (but all works and seems to be in the OK territory). With normal PSU it would be impossible for me to bend it because there would be literally no space.
- With no exhaust fan (I have no way to mount it anywhere - waiting for my second package with handle to arrive) it gets quite "toasty" around motherboard in this config (nothing major, but I see the difference from previous case). Especially if your case sits right above radiator as mine
- Really think through what goes where and in what order - it gets quickly compact and there was no possibility of "oh, I forgot this 15minutes ago, so I just do it now".
- Start with plugging front IO. These little bastards disappeared under tubings, sata cables, power cables and god knows what else in seconds after I put anything inside the case.
- In case this small it took me 2 hours (including cleaning mess I always do when building computers) to disembowel my old case and put everything into Cerberus
- Building in Cerberus was quite weird combination of fun and stress - right after "if this does not fit here with all cables already there I have literally no other place to put it" comes "It is coming together really, really fast in case this small. Oh...am I done already? Wasn't that hard after all!"
This is absolutely correct! For those of you with a Threadripper (*cough* @chemist_slime), the Enermax Liqtech TR4 AIO units have side-mounted tubing that allow for a standard length ATX PSU to fit comfortably (available in 240mm and 280mm for this chassis).
I personally went with the 240mm but I could see the 280mm fitting on the front if you have standard length GPUs (i.e. Not a FTW3 @ 11.8in/299.72mm)
With the Liqtech TR4, I even have access to all 8 slots of ram and the gap between the block and the PSU housing is just perfect. I don't see this ATX configuration working comfortably with any other AIO's as even NZXT's Kraken units were so tall that they hit the PSU. The best part is that the Liqtech 240 outperforms the 280mm Kraken x62 even when it was in the 41.5l iter 340-Elite chasis
https://i.imgur.com/bWQ80Z9.jpg
https://i.imgur.com/JMFuYVsl.jpg
There is just barely enough room for 'tall' memory
https://i.imgur.com/6irrj6k.jpg
Full build here for anyone that missed it.
seriously. definitely sets a FLOPS/liter high water mark.Huge congrats on the Titan V's, I am going to share your rig with everyone I know. Insane!
If i were you i will consider a celsius s24 with radiator on front with 25mm fans, BUT with shorter tubes...definitely a very good option with your four titan V (gg on that, you will a tremendously powerful Cerberus-x..OMG, thanks so much for the info. I already have a 280mm on order and was actually scared that with the standard length graphics cards, it would not fit. But it seems like it might just squeeze by. Furthermore, I ended up returning all 4 Titan Xps and ordered 4 Titan Vs instead -- that should arrive next week. Only delay might be the 280mm Enermax, I have two on pre-order from newegg and shipping is after the 15th of Dec so fingers crossed I also get it next week!
As you are going to a micro atx variant with no offset in pcie slots, i recommend you celsius s24. Its native long tubes are great to put radiator on the bottom. Furthermore you can easily shorten tubes length if required..Anyone have any experience in which CPU coolers would go best in it? I'm trying to use this for my next build, so I have a list of parts! Let me know if they'll work and if u have any suggestions for a cooler!
Core i7 8700K
ROG STRIX Z370-G
HyperX Fury 16GB
M.2 SSD
GTX 1080 TI FTW3
SF600
2.5 In SSD
Thanks for the help! I'm only used to doing full tower cases, this is a whole new ballgame. 8700K May be delidded due to the heat issue, so just lmk what y'all think!
Nice build. You could always get some 90 degree connectors and connect the fractals g1/4 fitting at a right angle, if you wanted to remove that bend in the tubing.
Thanks for the suggestion! Im curious if any type of decent air cooler would fit in there :/If i were you i will consider a celsius s24 with radiator on front with 25mm fans, BUT with shorter tubes...definitely a very good option with your four titan V (gg on that, you will a tremendously powerful Cerberus-x..)
Noctua c14s, on air cooling, should be possible but i’m not sure of clearance between heatsink and gpu, as you don’t have a pcie 1x as offset before gpu.
Thanks for your analysis...this is giving a nice picture, at least for Intel socket.oh wow the previous comment I made was a disaster. here's the correct ones:
First worry would be RAM clearance, but normal height RAM should easily go under it (my setup for RAM reference)
