@VELKASE Michael when we will get all the details about Velka 5 v2 like dimensions etc...
In around 2-3 weeks, probably.
Or rather a velka 7 (wink wink)Could you guys do a flip version of the velka 5 where the cables exit at the bottom rather than at the top?
Kind of NZXT H1 style, it would be esthetically way better and ease the cable management.
I’ve just seen that on reddit someone made 3d printed feet and turn the case upside down. I thinl that looks awesome.Could you guys do a flip version of the velka 5 where the cables exit at the bottom rather than at the top?
Well, no actually, the space where you have your cable spewing out at the top use that volume "virtually" while ruining the esthetics of the case.This is dumb, it will make the case bigger!
I'd definitely get a Velka 5 if it was inverted so it's easier to have clean cable management!
There are other chassis offering this layout, the Velka 5 is fine as it is!
Intriguing.... Looking forward to learning about the new cases!The new Velka 7 will have hardware compatibility on the level of the original Velka 5. The new cases will no longer have any top I/O. Full info on this should be available in a few weeks.
Nice!The new Velka 7 will have hardware compatibility on the level of the original Velka 5. The new cases will no longer have any top I/O. Full info on this should be available in a few weeks.
Again, No
Velka 5 is alone....
Please edit you post, we can't see it (you must make it public)Here we go again... i believe there are more, but most of the vertical chassis are already listed here:
I've used your own table against you!
How crazy is that?![]()
Or just indicate the name and url of the case you found that fits the criterias i've mentionned.
Unless i'm blind, can't see one in the list, there are other vertical sandwich style vertical case, but none as efficient as the velka 5 and bottom cable output and top exhaust.
Also i'm mentioning a future velka 7, not to redo the velka 5.
Is the size difference between rev 2.0 of the velka 5 and current rev going to be significant? Is it going to be larger? Smaller? I'd like to know since if it's going to be smaller I can start saving for it now.
