Thank you, emailed them. Though guess many will be interested at the PSU who's interested in the cases, will post an update on it here when they answer.
Edit:
They did reply by saying yes, they will sell the power supplies too but not right away because of stock issues. So if you plan on it you can wait for it. They then went on to recommend alternatives.
I think I'll be able to wait a little more to get it with the ENP-7660B-VK PSU with shortened cables.
I'm using an ASRock B450 itx board and the m.2 slot is on the backside.
If I'm seeing it correctly, the riser cable would wrap over the m.2 drive.
Is there enough space to fit this, or can this m.2 slot not be used?
108 mm. The Linkup and Louqe risers use the same mount.@VELKASE Michael Do you by any chance know the distance between the mounting screws for the riser? I'm looking into PCIE Gen 4 cables and wanna see if I can find one with a matching screw distance.
It can be used as long as there is no heatsink on it- otherwise it will protrude into the graphics card chamber.I'm using an ASRock B450 itx board and the m.2 slot is on the backside.
Great that the Linkup and Louqe risers use the same mount!108 mm. The Linkup and Louqe risers use the same mount.
It has 108 mm spacing but I believe the outer surface of the cables is conductive and would need to be insulated to prevent shorting components on the graphics card and motherboard PCBs.ADT-Link too if I'm not mistaking. They also recently released a PCI gen 4 riser.
The default riser is 30 cm for the whole assembly and 25 cm for the flexible portion of the cable. The 27 cm Linkup and 26 cm Louqe risers are compatible.Great that the Linkup and Louqe risers use the same mount!
What is the riser length for Velka 7? (i.e. Do you know if the 260mm Louqe would be long enough for the Velka 7?)
Good call, didn't think of that.
I used the Loque riser!
Works great and I feel more comfortable folding it actually. I am seeing a 2.5% performance increase which is expected. The main reason I'm upgrading is so I can update my bios (AMD) as new fixes and stuff comes out without having to take the case apart, and use my 1030.
Always happy to push boundariesThis looks fantastic, much much cleaner bend too! Thanks for trying this out
I just installed the Louqe riser in my Velka 7 this weekend and I agree, the bend was really nice and felt comfortable. Not sure why, but it looked to me like the direction of the riser in the picture you posted (notch on the left) is opposite of what it should be, so that threw me off for a bit. But I'm probably just confused...Always happy to push boundaries
Yeah it is flipped. Just never took photos of the correct flipped. :'DI just installed the Louqe riser in my Velka 7 this weekend and I agree, the bend was really nice and felt comfortable. Not sure why, but it looked to me like the direction of the riser in the picture you posted (notch on the left) is opposite of what it should be, so that threw me off for a bit. But I'm probably just confused...
Yes, it isIs that Louqe Cobalt riser cable compatible with the Velka 3 as well? (I guess so as the case itself is smaller but I'm still curious.)
I recall measuring low resistances across some two points of the 3M cable a while back, so I am hesitant to confirm compatibility right now but might revisit this.Might look like that from the pictures but the ADT Link cable is non conductive. The insulation is just transparent / translucent. Similar to the 3M Twin Axial Cables.
