What about this?
R3335W PCIe 4.0 x16 Extension Cable
PCIe 4.0 x16 to x16 adapter for graphics video cards extension.www.adt.link
I have seen that, it could work with 2-slot gpu's with atx or 3-slot with itx.
What about this?
Don't worry too much...SFF case remains a forever quest...time to choose ratio size/noise/heat/performance..lolWowee i'm extremely excited for this case. Unfortunately i'd just discovered sff pcs right after i had upgraded my system and gotten all the partsSpent the last two ish months drooling over a ton of cases but didnt want to get an itx mobo, sf psu and a new air cooler. Would easily be able to transfer over my current pc to this when able to get my hands on one
Is it basically the successor product to the one you are currently shipping with P-ATX? Do you consider switching to the new one anytime soon? Or at least offer it as an option?I have seen that, it could work with 2-slot gpu's with atx or 3-slot with itx.
I see, sounds sensible. I think I can afford to wait a little longer as graphics card prices don’t look like they are dropping to a reasonable level anytime soon.Not really since it is much larger than the riser I'm currently using (R33UL) and would impact the compatibility in a bad way. Also I guess it is 3-4x more expensive. I am waiting for the option that is not physically larger, I that would be something using cables similar to ones in new loque riser.
I see, sounds sensible. I think I can afford to wait a little longer as graphics card prices don’t look like they are dropping to a reasonable level anytime soon.![]()
I'm not worried about performance. I'd just rather not have to set the PCIe speed to 3.0 in the BIOS in order for the system to work. After all, BIOS settings can get lost sometimes (e.g. through a BIOS update, an accidental BIOS settings reset or whatever), and I'd like to avoid having to disassemble the system and put the graphics card directly into the slot on the motherboard in order to set the setting to 3.0 again on such an occasion.
Or should the system automatically fall back to 3.0 mode if it notices that 4.0 mode doesn't work reliably, with no need to adjust BIOS settings?
You can even consider new Nvidia GT1010...it should be PCIe Gen 3..Ok I get that. In that case the best thing you can do is get some old used low end gpu and use it to update bios. I have a spare rx460, but you can get something like gt710 or even older. It will also probably be cheaper than gen4 riser, and you will have backup for troubleshooting or if you have to RMA your main gpu.
But all of this will still require me to unplug everything, retrieve the case from behind my display, open it, and disconnect the riser cable. Quite annoying, so I’d like to avoid it if possible.
I am fine not having gen 4 pcie riser , but I do wish I dont have to do anything to the bios and just have it ready
yes & no...don't forget you need to do the full process each time you update bios.I know, but in real world usage scenario you will probably only have to do it once.
For AM4 users, it could be very difficult to resist to newer Agesa, especially with add. feature like Smart Access Memory to Nvidia GPU..![]()
lol true I'm not representative user, especially when I tried to get max OC from my R7 1700X or 3800X lol..I know, but lets be real, not counting us hardcore HW enthusiast how often do people flash bios? Do they even know that new AGESA came out? They probably don't care. Even I didn't bother to update my bios from agesa 1004AB, everything works fine, memory tuning is fine, edc bug works fine, so I didn't bother.
lol true I'm not representative user, especially when I tried to get max OC from my R7 1700X or 3800X lol..(external CMOS button is mandatory for me..
Lol on my side, just managed to launch bios recovery..due to bios corruption lolpeak OC moment is when you corrupt your OS due to failed memory OC![]()
