Production REVOCCASES - RCC-MID1 | industrial style case with 180mm fan and rad support
REVOCCASES
2,256
3,698
Germany / HK
www.revoccases.com
scythe big shuriken 3. 69mm high...
Should work.
Reactions: FischOderAal
rocklobster
98
24
It seems that a lot of people do not read a single word of the description of the cases. Frankly speaking this is very disappointing. Maybe I'm special but usually I read the specs first if I'm really interested in something.
It's like buying a car without even knowing if it runs on gas or diesel. But later complaining that the engine died.
Is there anything I can do to improve? Are the descriptions not clear enough? Do you need more pictures? Just let me know!
Should work.
I don't frequent SFF Network as much as r/SFFPC, so I'm not as used to the layout of the forum. Also, it is hard to visualize the layout of the components, especially in a form factor that is outside the usual suspects (sandwich, SG13, Cougar QBX etc).
The schematics and build video are very helpful for me understand where everything will fit. I now know where the 1 2.5" drive will sit , an I can potentially fit more if i use double-sided tape on them. I also know that a SFX-L PSU might work, since it is the width and height as SFX, just 2cm longer.
Reactions: REVOCCASES
