Concept Modular and Watercooling friendly SFF cases...
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
I think you've got a lot of good ideas going into this and I'm just half wondering if you'd find it worthwhile to sit and reflect on what you really need to make it work :)
thanks! :)
yeah, I've already put a good amount of thought into the removable 'expansion' rear chamber and how to be able to support so many different rads and drives and such. Now I just gotta do the work of actually designing it in 3D..
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
very late/very early update for today:
Got v0.1 of the main Motherboard tray built in Inventor. Took me longer than expected to figure out the mounting holes and needed sizes for the Motherboard and PCIe Slots, still more work to do on it but it's looking good for today imo.
Currently designed for 2mm aluminum. Theoretically it shouldn't be too terrible to change the material later on if need be...
Reactions: NRG and Biowarejak
Biowarejak
Maker of Awesome | User 1615
Mar 6, 2017
1,731
2,220
Looks good :) is the PCI-e slot screw-in flange supposed to have that much curve to it? Or maybe it's just the perspective.
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
The curves/bends are automatically calculated by Inventor. Here is a detail shot of the flange curve:
as you can see it's 0.079 in or 2mm from where the curve starts to the outside of the panel or 0.157 in or ~4mm from the inside of the panel to where the curve ends. This might not work since from my measurements it'd need to be 3.5mm from the inside of the panel in order to have the threaded hole for the PCIe bracket screw but there seems to be about .5mm of leeway in the bracket itself so it might work (doubtful). I might actually need to reduce the Aluminum thickness :/ Thing is that Josh said he used 2mm aluminum for the S4 Mini's inner frame and his obviously works...
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
You can either reduce the bend radius if your manufacturer allows it, or create a cut-out feature so the threads stay on a horizontal plane. I don't know what they are called, but @Aibohphobia showed how they work in his STX160.0 project.
Additionally, some manufacturers allow threaded holes to be closer to bends than others, that depends on the tooling they have.
Thanks! I actually somehow forgot about that project so I'll definitely go read up on that again. :)
Biowarejak
Mar 6, 2017
1,731
2,220
Feel like we need a "Notable Builds" Tab if we don't already :) let us keep track of the ones that really push the limits and contain useful tips and such
Reactions: royalba94
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
I'm probably missing something, but what is modular about this?
The whole back section where the radiators and hard drives go is the main modular part of it along with the fact that you could get it without the back section.
Those are the main modular bits at the moment and I know I haven't really detailed out how it will all work yet so I understand your confusion. I'm going to try and explain this more in my next update.
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
Terribly sorry for the lack of updates everyone. I was trying to get an update done yesterday but since my 3D Modeling skills are still in the works I wasn't able to get a good update made yet.
Still working on it tho and I should have a bit more time to work on it this week.
As proof here is a screenshot of one of my first feeble attempts at the front panel:
I did manage to find a solution for Front I/O that is 2x USB 3.0 ports with a low-profile header connector that I can even get in custom lengths which is nice since that means I don't have to settle for extra-long and bulky USB 3.0 cables. Oh, and it's black too so that's another bonus :)
As I said in my previous post I'm going to try and show more about how the case will be modular so that is what I am working on modeling up currently.
Hopefully that wasn't too disappointing and here's hoping the next update comes soon! :)
Biowarejak
Mar 6, 2017
1,731
2,220
Actually looks pretty awesome IMO! I like that color :)
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
So just as an update everyone, I'm still planning on working on this but things got a little crazy mid-june so I haven't had much time at all to work on it :[
Things are settling in better now so hopefully I can start back to working on this soon!
