Production SFFtime presents: MNLT - elegant vertical air tunnel case with excellent air cooling support and no riser
sff9108
If I want to install 2 x 120 mm side fans, what is the maximum thickness for the GPU? Is a 2.5-slot GPU feasible? Thank you.
riba2233
SFF Time
Jan 2, 2019
1,908
2,512
www.sfftime.com
Hi, sorry for the late reply. It is not, you can use a 2 slot gpu with thinner than standard fans. For 2.5 slot you would need 12mm fans.
But you can also mount them from the outside.
