Completed REVOCCASES CUBE-P1 | Cube style ITX NAS/HTPC Case with NH-P1 and 200mm fan support
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
The CUBE-P1 is a design we came up with on my Discord channel...
As the name suggests it is meant to be used for a silent (semi-) passive build. The case has a drive cage for a couple of 2.5" drives, so you could also use it as a home-server / NAS.
Specs:
  • ITX motherboard
  • SFX (-L) PSU
  • ITX GPU or other PCIe card (NIC, SAS, etc...)
  • tall tower coolers like NH-P1
  • drive cage for 2.5" drives
  • 200mm front fan support
  • CUBE-P1.zip
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
what's the Gpu length limit on this one?
about <220mm without the 200mm intake fan
I originally designed it around the Noctua P1, PALIT KalmX and Silverstone Nightjar for those who want a truly silent HTPC/NAS system
PS: I've attached the drawings for laser cutting and bending to the first post, if someone would like to DIY a case like that.
