Completed Project PURE: 3L APU case, MEANWELL Support
andornaut
Am I correct in thinking that an HDPlex 400w DC would not fit?
It's overkill and requires a power brick, but I have one on hand that I may as well use if possible.
andornaut
I noticed that "Canada" is now showing up as an available option in the payment form. Selecting it still gives the following message:
> There are no shipping methods available. Please ensure that your address has been entered correctly, or contact us if you need any help.
Just a heads up in case that wasn't expected. Either way, looks like we're getting closer to international shipping!
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
Yes. I'm having issues integrating the USPS API into the system. I'm trying to avoid flat rate shipping, since it spiffs some people, while giving others a good deal on shipping.
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
The plugin units proved to be quite popular. I'm about to be out of stock, and I'm not sure I can restock them anytime soon. This may require a custom design one much earlier than planned.
Reactions: annasoh323
Samsquamptch
34
So I've got my build started, but I need an 8pin cpu (asus strix I-470) connector for the One2 plugin 120. Do you carry those?
Samsquamptch
34
Is it safe to plug in the 4 pin into the 8 pin cpu connector? I don’t plan to overclock. I’m wondering if it will even post, or run extremely restricted.
Mobo: ASUS strix I-470
CPU: 2400g
SSD: 970 pro 500g
Cpu cooler: lh9 a
Ram: gskill 3200 8x2
Aguda33
107
187
In my build I have the 4 pin plug in the 8 pin socket ( it will only fit in one way), All has been running well for the past month .
smitty2k1
977
498
Ya gotta keep up with KMPKT and his 200w plug-in boards hahaha
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
160W version under development. Right now I don't intend to have a plugin board with pcie. Pcie will likely be an additional side board using sync function.
160w version will fully replace the 120W version. It's for 2400g + overclocking.
6FeaT
Might you be able to provide some detail on the power entry mod required for the HDPlex 160W AC-DC?
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
You will need the buy the AC-DC power entry for the case, and you will need to strip/rewire the HDPLEX 160 AC-DC to use the new power entry.
You will also need some double sided tape to mount it.
princess_daphie
210
194
i'm from Canada, i checked it out. shipping prices really are prohibitive from where you live :( can't afford that much money, it's sad because your case is a beauty! :thumb:
princess_daphie
210
194
Yeah. Really sorry about that.
Unfortunately that's the issue for shipping things out of USA, in general it is expensive.
i know, not your fault. shipping prices + money conversion factors really make everything awfully expensive for us lately :( i checked, and shipping price for just one unit is 40.95$ and if i add a meanwell ac-dc, it's 59.06$, which makes a total of 193.96$, then converted into Canadian equals 255$ ouch! and that's without counting if my package is tagged for tax and import duties, which can happen at random.
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
Indeed. Though if you ever decide grab a J-hack case, you should try to source the power supply parts locally. The parts I design for are fairly easy to get.
Stevo_
449
304
I want to share my silent NAS build using the J-HACK Pure case
MB/CPU combo: Asrock J5005-itx
Memory: 16 GB
SSD: MX500 2tb
Planning to add more in the future (that's why I got the SSD bracket)
PSU: PicoPSU-80
The opening for the DC jack is wider than the Pico DC jack so I ended up placing it on the USB-C mounting point
Nice, really like this j5005 mobo for silent builds. If you want to get rid of the SSD clutter, a 2TB NVME 970 and one of these adater in link below, looks like you have just enough headroom. I have mine booting from the X1 slot no problem.
https://www.ebay.com/itm/M-2-NGFF-K...dapter-for-Samsung-950-Pro-SM951/292816336365
