A 3080ti will not get released before chinese new year, so the earliest date would be end of february or at the beginning of marchThe real build will start once I get a 3080 Ti, hopefully in January but we'll see.
Getting off topic here, but NVIDIA has some big virtual announcement around CES timeframe (late Jan) so maybe a Feb/March launch makes sense. Whether there will be any availability at all is a different question.A 3080ti will not get released before chinese new year, so the earliest date would be end of february or at the beginning of march
Sad. Maybe I'll just put the CPU on water and keep the 2080 Ti on air for now.Getting off topic here, but NVIDIA has some big virtual announcement around CES timeframe (late Jan) so maybe a Feb/March launch makes sense. Whether there will be any availability at all is a different question.
@diceboii13 No problem, I sent an email the other day so we can move the conversation to their. Thanks for your response here as well.
To those running two radiators (non-x-flow) I'd apprecaite seeing how you're doing your setup/tube routing
Sorry for such a basic question, but I want to be 100% certain.... the inlet holes are at the top of the distro and the outlet is in the lower right corner?
I think the 2x90 at the bottom to give you a straight run from the pump is a great idea, I may steal thatAny thoughts about building these types of fitting/extender constructions to better align ports to keep the tubing as straight as possible? I'm using soft tubing so it seems a bit redundant but I'm thinking it might look cleaner. Worried about leaks due to all the extra fittings and the amount of pressure it might put on the ports...
Also, which way are you orienting the fans? All intake, all exhaust, intake+exhaust....?
And finally, I installed fans on the inside as on the pics, but now I'm realizing that will make it harder to swap out fans if needed because I'll need to unscrew the entire radiator to do it. Would placing the fans on the outside be a smarter setup?
Thanks for all the advice so far!
Generally speaking, each 90 fitting increases restriction in the loop. It’s by no means a deal breaker, it’ll still work fine, but you probably want as much pressure heading into the CPU input port as possible. The less restriction you have, the higher the potential flow rate will be. The higher theoretical flow rate lets you keep pump speeds lower and gives you more flow rate headroom.Any thoughts about building these types of fitting/extender constructions to better align ports to keep the tubing as straight as possible? I'm using soft tubing so it seems a bit redundant but I'm thinking it might look cleaner. Worried about leaks due to all the extra fittings and the amount of pressure it might put on the ports...
5 blocks in this case?For example, I’m using an MCP35x because it has some of the highest head pressure for a single pump setup. Although, I am running 5 blocks, 2 radiators and a filter.
3 of the blocks are extremely low restriction/pressure. 2 are VRM blocks and 1 SoC block for the X570 chipset since I am doing lots of work through the IO and I understand this chipset gets hot. I need the VRM blocks because I’m overclocking a 3950x so they throttle otherwise.5 blocks in this case?How did you fit all that?
I'm using the D5 pump with HWLabs X-Flow radiators which are meant to have very low restriction. I don't plan to have more than two blocks (GPU+CPU) so I think I should be good, but I do intend to run the pump as low as possible so keeping the number of 90 bends to a minimum is probably a good idea.
I think you know this, but others might not be aware of the relative restrictions that fittings vs blocks and rads cause.Generally speaking, each 90 fitting increases restriction in the loop. It’s by no means a deal breaker, it’ll still work fine, but you probably want as much pressure heading into the CPU input port as possible. The less restriction you have, the higher the potential flow rate will be. The higher theoretical flow rate lets you keep pump speeds lower and gives you more flow rate headroom.
I guess it also depends on what pump you’re running, and how many blocks and radiators you are going to be pushing water through.
The never ending debate on angled adapter fittings can now go to rest. Do angled fittings reduce flow rates? Yes. Will overuse of angled adapter fittings completely kill your flow rates? No. So the next time someone yells at you and tells you that you need to ditch as many angled adapter fittings as you can, just tell them to “keep calm and use the angled adapter fittings”. Compared with all the water blocks and radiators, a few extra angled adapter fittings will go unnoticed in any cooling loop regarding the performance.
Another beginner question, this time about "hard fitting chain". I assume you mean a connection that consists of nothing but fittings? I saw these in some builds but I was always confused about how they are meant to be screwed in considering they are not flexible in any way? Is it through use of rotating fittings at the ends? Would love to know the secret, thanks!Back to Side 1: hard fitting chain down from rad to distro plate inlet.
