Stalled DICE CASES - FLOW : expandable SFF case for watercooling enthusiast (built in distroplate)
diceboii13
620
1,644
dicecases.com
I want to order my water-cooling parts this weekend. And it will be my first build.
I'll go for soft tubes as my hardware will probably change the upcoming half year (and it seems easier for a first time build). When the hardware is final I might change to hard tubes.
Do you guys go for x-flow rads or normal ones? I was looking at the NexXxos ST30.
What diameter you'll take for the tubing? 11/8? 16/10?
Thx in advance
I'm not recommend xflow rads. Depends on the orientation, the pump or the IO shield can block the way for your tubes. I also has an ST30 and works really well with the case. If it's the 280mm one.
Tossy
84
56
Thx for your advice.
I'm planning on integrating the CPU first. The GPU later on when I got a new one.
Nonetheless I'll start with two 280mm ST30. I want to avoid compatibility issues in the future, so the normal versions seems the better choice.
Reactions: diceboii13
ChorizoNinja
82
101
To anyone interested in the 3080/3090 reference pcb, palit seems to be a solid choice.
i must admit it looks much better in real life than in stock photos IMHO. As well, for being a "cheap reference" design, this is milles away in quality and sturdiness compared to something like a 2080ti Zotac X3.
ermac318
655
510
I'd also recommend against XFlow unless there's some tube run issue that it solves. With the full-size DDC and D5 options available in this case, you should have no issue with restrictive flow. I plan on putting two HWLabs 280GTS Rads in it with an EK D5 PWM pump.
As for tubing, 10/13 seems to be the most often used tube size for soft tubing, although I use 10/16 ZMT from EK (matte black rubber rather than clear).
Just make sure you buy fittings that are correct, and note that Hardline fittings are different than soft tubing fittings. So if you switch tubing later, you will need to switch fittings.
kosta
119
70
I bought 2 240mm X-Flow rads from HWLabs... are you saying they won't fit?
Tossy
84
56
Yeah, I noticed that the fittings are different for hard and soft tubing. I went for 11/8 in the end as diameter doesn't seem to impact the performance that much while the tubing and fittings are much cheaper.
I also got myself a memory upgrade this week during the Prime Days. 32Gb Crucial Ballistics and 2Tb MX500. So no worries about the size of the gaming library anymore :thumb:
The6A
62
35
Hey, I kinda lost rack of everything and havent been paying attention. I put in an order.....how can i follow up ?
ChorizoNinja
82
101
@diceboii13 can we have some sort of an update with the cases?
As well, do you have the measurements of the pci riser. I want to grab a pci 4.0 as it will be a pain to reset the bios and the whole thing not working at all. Is it straight or it has a right angle at the end?
ywori
38
30
Hi Dice,
I haven't posted in a while and would still like to give you time for the 2 slot cases to arrive. Have you shipped them out yet?
Thank you.
ermac318
655
510
No but I can post them here when I’m done.
I guess it’s worth mentioning I’ll be using an SFX-L power supply but I don’t know how much difference it would actually make.
It's a difference of 30mm so at worst you just add 30mm to each cable.
Please do post the lengths when you get them done! Would be appreciated.
diceboii13
620
1,644
dicecases.com
Here are the dimensions:
Hi Dice,
Thank you.
First 2 slots are in the post office, as I got tracking numbers, I'll send it. Sorry for the lack of reply, I've been sick this week.. but I have more time to assemble and send the cases.
Reactions: Lexmaster
ywori
38
30
No worries Dice, I can wait as long as you keep me informed. Get well first, health takes priority.
Reactions: iwe and D10S
kosta
119
70
Do you have a particular order in which you are fulfilling the orders? Would it be possible to share rough expected shipping dates with everyone still waiting?
