VegetableStu
1,949
2,619
Wait, is this waitlist for pre-production? As in either the all-black client leftover run or the one-last-run-check-before general-production run?
Is there a list for general production? o_o
4,784
I have a Sea Hawk 1080 X with a 120mm rad/fan. Kinda wanna do sli eventually with this case. Would 2 120mm radiators fit with the closed loop tubing or should I switch to Founders Edition or even the new Zotac 1080 Mini?
It can be done, just depends on the exact setup. Easiest would be a rear SFX PSU, LP air cooler on the CPU, and put both radiators for the GPUs on the front. It'll be a close fit but it should work.
Actually (assuming SFX mATX Cerberus) can one stack radiator-fan-radiator under the SFX PSU? MSI says the cooler part is 52mm, but I'm not sure if that number includes the fan itself...
52mm includes the fan.
Joined the forum just because of this case, what do I need to do to get added to the waitlist?
I've would also like to know If the waiting list applies to the general production. If so sign me up
Waitlist is only for this preproduction run. Not sure how we're going to do the next preproduction run yet
There won't be a list for general production.
Reactions: VegetableStu
4,784
Will do, but as I've mentioned before, quite a few people on it already so don't get your hopes up too high :)
bafbaf
Hello
Im very interested in the Cerberus-X but I just realized that an atx-psu wont fit in the front. I would have to mount it in the back which I don't mind since it leaves lots of space in the front which I gladly take. But how much space is left between the motherboard and the psu? What's the tallest ram I could install? (that would really help me to gauge the space)
Also what would be the best way to use an external radiator with an atx-psu installed (not that important since I can always make some holes).
Is there still a way to get the model with the changable backplate?
Thank you! (sorry bad english)
MarcParis
Apr 1, 2016
3,681
2,802
If you are atx psu in cerberus or cerberus-x, cpu cooler will have a clearance of 48mm.
As far as i know, only pre production version will have both back panels (92mm or atx psu). After, for price reduction mainly, you need to choose from start between the 2 choices.
4,784
Like Marc said, 48mm for CPU coolers but should be a bit more for RAM, probably around 52mm? But unless the ATX PSU is really long, the RAM slots should be beyond the end of the power supply on normal motherboards (non-X99 or the like).
The rear plate used with a front SFX/SFX-L PSU has holes for tubing. But that space is taken up with an ATX PSU installed, so you'll just have to find a place to make holes or maybe use one of the expansion slots if it's available.
I can add you to the waiting list for this pre-production run. No ETA yet on the next pre-production run and then general production.
Regular production will have swappable rear plates as well. The plan for the Kickstarter production run was to not have them, but that decision has since been reversed.
InZ
Feb 27, 2017
This case gives me a strange tingling sensation I have not felt since unboxing my ncase m1. You have one more aspiring customer. I shall make a nice midrange ryzen build in this. I just have one question; will extra sidepanels be available? So I can mod a window to my liking in one and be able to switch between windowed and non-windowed?
MarcParis
Apr 1, 2016
3,681
2,802
That's part of the plan to have optional panel on sell. Idea is to propose different color, plexiglas version, etc..:)
However, as usual no ETA set for that..:D I'll be also pretty interested in plexiglass side panel to show GPU..:D
InZ
Feb 27, 2017
Thank you very much for your reply, sir. I shall now assign 300 euro's to my savings account in order to be ready to throw money at kimera industries when the case is set for production.
MarcParis
Apr 1, 2016
3,681
2,802
yes that's the plan..:)
I'll make a full review of my Cerberus-x (pre production) when it will completed (I guess by Vega release).
Kwirek
186
198
Last thing I read was that they were undecided regarding extra panels due to difficulty with shipping.
That's the issue, the studs on the panels make them difficult to ship by themselves without them damaging each other. We'll see.
bafbaf
@ MarcParis and Aibohphobia
Thanks for your answers
My PSU 180mm long but I have a x99 anyway (full slotted) so the length doesn't matter. The ram is 55mm high so ill just have to remove the heat-spreaders. I hope the tubing's will fit. Does anyone happen to have a picture from the top with an atx-psu and cpu-watercooling (custom loop) installed?
So the information in this gallery is wrong? (28/29)
This is great news (at least for me). It makes the purchase less risky since it has more possibilities in case something doesn't fit.
What are the differences between the current-, next pre-production and the general production?
Cutie DarkFae
27
24
Lovely images :) Do I want black or red?
Ooh, can I get red panels over a black frame? Or perhaps a RAL7106 frame?
Much luck with getting this into full production :)
4,784
That gallery is from the Kickstarter, so some of that info is outdated.
Just minor fit and finish details so far. But there may be other changes depending on feedback from the pre-production units.
Red panels will be an option. Frames will almost certainly just stay black for simplicity.
