VegetableStu
1,949
2,619
Haven't got to reading the entire thread, but kinda curious on a few things (thanks in advance :D):
  • On a horizontal heatsink setup (fan blowing onto the CPU), would it be okay to set all the case fans to pull air inwards? There's the unpopulated space on the top of the case, so I was thinking if that could be a passive outlet for air to exit...
  • Speaking of which, would be possible/feasible to mount fans there, under the top-side face?
  • If I were to use a filter for the PSU intake/fan, would it be placed on the PSU, or outside on the case?
4,793
In my testing having the fans set to all-intake works quite well, the case is small enough that the positive pressure pushes the hot air out without the need for exhaust fans.
There will probably be 120mm fan mounts on the carry handle bracket for those that get that option. There's only room for a slim fan and even then it may not fit depending on the motherboard.
With the PSU intaking from outside as typical, the filter has to go on the outside of the case, there isn't room inside.
Reactions: VegetableStu
candyman
24
I don't understand why a project that would have been to be delivered on July 2016 (old Kickstarter campaign) today isn't started yet.
Maybe the public low interest has convinced to move resources towards another projects?
mirshko
Onshape
Sep 22, 2015
25
onshape.com
I'm pretty sure due to their MOQ's having to be so much lower they had to rethink a lot of how they were going to get the case manufactured.
These things generally mess up production schedule.
Reactions: Josh | NFC
4,793
Like the others have said, having lots of money upfront gets things in gear, it's much slower going otherwise.
Reactions: Commissariat
jØrd
S̳C̳S̳I̳ ̳f̳o̳r̳ ̳l̳i̳f̳e̳
sudocide.dev
LOSIAS
Jul 19, 2015
818
1,359
Reading this thread (granted its long now) would be a great way to gain some insight into that very question!
mcbirds
What's the max radiator space you could hypothetically fit in this case? If you used a SFX PSU with a ATX mount is could you make a 240 in the front, bottom, and 140 on the bracket?
4,793
4,793
Welcome to the forum!
We could possibly be taking orders before Christmas but almost certainly wouldn't be shipping by then.
PNP
285
257
Heh, 3 radiators? I'm trying to plan out 2 and it already requires an uncomfortable number of right-angle fittings. In fact, if it wasn't possible to install a 120 in the front sideways I would have already given up.
